POV-Ray : Newsgroups : povray.off-topic : Iterated derivatives Server Time
15 May 2026 22:52:38 EDT (-0400)
  Iterated derivatives (Message 4 to 13 of 93)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Iterated derivatives
Date: 16 Nov 2009 08:08:41
Message: <op.u3hn4rey7bxctx@e6600>
On Mon, 16 Nov 2009 13:51:11 +0100, Invisible <voi### [at] devnull> wrote:
> Oh, I did Google it. I just didn't comprehend the answer. (In
> particular, I've already read the Wikipedia entry.)
What is so difficult to understand about it? I thought function
composition would be one of the areas of math that you were actually good
at, given your fanatical obsession with a certain functional programming
language.
Anyway:
The derivative of f( g(x) ) is f'(g(x))*g'(x).
Substitute the inner function into the derivative of the outer function,
and then multiply by the derivative of the inner function.
In your example, we want the derivative of f(f(x)) (i.e. the outer and
inner functions are the same), and we know that f'(x) = g(x) (try not to
mix up all the f's and g's).
df(f(x))/dx = f'(f(x))*f'(x) = g(f(x))*g(x)
FE
Date: 16 Nov 2009 08:14:28
Message: <4b015034$1@news.povray.org>
One formula appears to say the derivative is f(x) * g(x), and another
appears to say it's f'(g(x)) * g'(x), which is different, but these are
supposed to be different notations for the same formula...?
> I thought function
> good at, given your fanatical obsession with a certain functional
> programming language.
Function composition I get. It's what that does to the derivating I
can't quite wrap my brain around.
> Anyway:
Right. So basically, the function I'm looking for is f'(f(x))*f'(x)?
So presumably the derivative of f(f(f(x))) is going to be something like
f'(f(f(x))) * f'(f(x)) * f'(x)? And in general, the Nth composition will
be ever more complex as N increases?
Oh dear.
Date: 16 Nov 2009 08:15:52
Message: <4b015088$1@news.povray.org>
Fredrik Eriksson wrote:
> Basic high-school level math. I am slightly surprised that you did not
> know it, though I am not in the least surprised that you did not bother
> to google for it.
...what I *should* have done of course is
http://www.wolframalpha.com/input/?i=derivative+f(f(x))
*facepalm*
Date: 16 Nov 2009 08:19:46
Message: <4b015172$1@news.povray.org>
> Oh dear.
Ooo, but wait... The Nth derivative of a polynomial will be zero if N
exceeds the order of the polynomial. Hmm.
Date: 16 Nov 2009 08:32:01
Message: <4b015451@news.povray.org>
>> like f'(f(f(x))) * f'(f(x)) * f'(x)? And in general, the Nth
>> composition will be ever more complex as N increases?
>> Oh dear.
...which doesn't help, because the derivative of the Nth iterate will be
   f'(x) * f'(f(x)) * f'(f(f(x)) * f'(f(f(f(x))) * ...
which involves only the first derivating of f and the iterates of f.
Damnit, I really suck at math. :'{
Date: 16 Nov 2009 08:34:10
Message: <4b0154d2@news.povray.org>
D f[n](x) = D f[n-1](x) * f'(f[n-1](x))
Maybe this isn't so bad...
Or maybe I just need to GROW A FRIGGIN' BRAIN! >_<
Date: 16 Nov 2009 08:34:51
Message: <op.u3hpcdj97bxctx@e6600>
The first one is obviously wrong, unless you mixed up all the f's, g's and
little circles. It is difficult to tell without context.
Yes.
> And in general, the Nth composition will be ever more complex as N
> increases?
Yes.
Except that it is the wrong answer, or rather the wrong question. Wolfram
thought you meant (f <dot> f)(x), when what you actually meant was (f
<circle> f)(x).
Just one more reason why it is better to learn the formulas yourself
instead of relying on a computer to help you all the time.
FE
Date: 16 Nov 2009 08:38:26
Message: <op.u3hpibxk7bxctx@e6600>
 From what I can tell, you basically suffer from a lack of education. That
can be remedied, if you are willing to make the effort.
FE
Date: 16 Nov 2009 08:41:14
Message: <4b01567a@news.povray.org>
>> are supposed to be different notations for the same formula...?
> and little circles. It is difficult to tell without context.
Well, one formula says something like dy/dx = dy/du * du/dx, while the
other says (f.g)'(x) = f(g(x)) * g(x).
> Yes.
Nice to know I got something right today...
>> increases?
> Yes.
Hmm.
Yes. The query should be f[f[x]] instead of f(f(x)). If you ask for a
higher iterate, it quickly becomes obvious that something is wrong.
Oh, sure. But I find it useful to check against the computer. If the
answers are the same, you probably did it right. If the answers are
different, either you asked the computer the wrong thing or you stuffed
up the math.
(For example, (Sqrt(3) a)^3 = 3 a^2. Or NOT, in fact - as Wolfram
rightly pointed out...)
Date: 16 Nov 2009 08:42:06
Message: <4b0156ae@news.povray.org>
Well, I _did_ go to a school for stupid people.
> That can be remedied, if you are willing to make the effort.
I'm more concerned about the time and cost aspect of it, but sure.
