POV-Ray : Newsgroups : povray.off-topic : Quick C++ question... Server Time
15 May 2026 09:42:39 EDT (-0400)
  Quick C++ question... (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Quick C++ question...
Date: 11 Nov 2009 19:00:19
Message: <4afb5013@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
>  > class dfbScreen::MyIDirectFB: public IDirectFB
> I'm not sure what this means, but I'm pretty sure it's not going to work
> well. :-) DirectFB is all built on top of C, with fake OO stuff, so there's
> no way to get one of these for real.
  Why wouldn't it work? dfbScreen::MyIDirectFB *is* IDirectFB (this is OOP,
after all). Wherever an object of type IDirectFB is expected, you can pass
a pointer to an object of type dfbScreen::MyIDirectFB. And yes, even if you
are passing it to a C function.
  Just to make sure, I made a complete test to see that, indeed, it works:
  SomeCStruct.h
#ifdef __cplusplus
extern "C" {
#endif
struct SomeCStruct
    int i, j;
void someCFunction(struct SomeCStruct* object);
#ifdef __cplusplus
#endif
  SomeCStruct.c
#include "SomeCStruct.h"
#include <stdio.h>
    printf("i=%i, j=%i\n", object->i, object->j);
// MyClass.hh
class MyClass
    class SomeCStructWrapper;
    SomeCStructWrapper* obj;
    MyClass(const MyClass&);
    MyClass& operator=(const MyClass&);
 public:
    MyClass();
    ~MyClass();
    void foo();
// MyClass.cc
#include "MyClass.hh"
class MyClass::SomeCStructWrapper: public SomeCStruct
 public:
    SomeCStructWrapper(const SomeCStruct& init): SomeCStruct(init) {}
MyClass::MyClass()
    SomeCStruct instance = { 5, 10 };
    obj = new SomeCStructWrapper(instance);
MyClass::~MyClass()
    delete obj;
void MyClass::foo()
    someCFunction(obj);
// test.cc
int main()
    MyClass obj;
    obj.foo();
  Compiled with:
gcc -Wall -O3 -c SomeCStruct.c
g++ -Wall -O3 MyClass.cc test.cc SomeCStruct.o
  Works just fine.
Date: 11 Nov 2009 19:26:23
Message: <4afb562f@news.povray.org>
Here's another idea - a bit kludgey as well, but what the heck:
   struct MyIDirectFB;
   class dfbScreen
       MyIDirectFB* dfb;
and in your .cpp:
   struct MyIDirectFB
     IDirectFB data;
Requires a bit more effort in coding, but as I said: what the heck...
Or you might cheat a bit on the compiler, using something like:
   #ifndef _DIRECTFB_H__INCLUDED_
     // (or whatever symbol directfb uses in the header)
     struct IDirectFB;
   class dfbScreen
       IDirectFB* dfb;
and include <directfb> from your implementation instead of from your
header file.
There's more than one way to skin a cat...
Date: 11 Nov 2009 19:47:43
Message: <4afb5b2f@news.povray.org>
>    struct MyIDirectFB;
>    class dfbScreen
>        MyIDirectFB* dfb;
> and in your .cpp:
>    struct MyIDirectFB
>      IDirectFB data;
  Inheritance achieves the exact same thing, except that it makes MyIDirectFB
to be of type IDirectFB directly.
Date: 11 Nov 2009 20:42:19
Message: <4afb67fb$1@news.povray.org>
I'm not sure what I was thinking of. I'll have to look at this again (and
look up some syntax to see what "x::y : z" means :-) when I'm not at the end
of a day.
Date: 11 Nov 2009 20:47:14
Message: <4afb6922$1@news.povray.org>
clipka wrote:
> Darren New schrieb:
>> What I'm doing right now is declaring
>> struct _IDirectFB; struct _IDirectFBFont; ...
>> class dfbScreen {
>>   struct _IDirectFB* dfb;
>>   struct _IDirectFBFont* font;
>> But that seems wrong, given that I have to grope around in someone
>> else's headers to pull out private declarations to make it possible to
>> compile a header that doesn't depend on those declarations.
> Yes, that's why you normally /do/ include the headers... after all,
> that's what they are for.
It seems wrong that I should have to expose the DirectFB declarations to
classes that don't care about the directfb declarations, simply because the
private parts of one of the classes they use has a pointer to something in
the directfb libs. That's what's the "seems wrong" part.
> I'm not sure, but you might also be able to directly use
>     struct IDirectFB;
IDirectFB isn't a struct or a class. It's a typedef. Therein lies the problem.
> Unfortunately, C++ doesn't natively make a good job at separating
> interface from implementation (the bane of allowing direct access to
> data members, and "inlining" of classes as data members).
Yeah. Plus having to declare everything *and* define it.
> Speaking of interfaces, you might make dfbScreen abstract (serving as
> what would usually be declared as an interface in Java), so that you can
> keep the actual implementation of it in the background - private data
> members included.
What I did for the "real" library interface was to have a Player and a
Player_p object, and the Player.h forward-declared Player_p and the
Player.cpp included the actual definition. It's just an extra level of
indirection and another header file and such, which seemed unnecessary for a
unit-test helper function. (Only the fact that I expect to have to do unit
tests for multiple GUI bits drove me to make it separate from the unit tests
to start with, and then I got sidetracked down to figuring out how to do it
better. :-)
Date: 11 Nov 2009 20:51:54
Message: <4afb6a3a$1@news.povray.org>
Hmmm. I remember.
You get an IDirectFB by calling
   IDirectFB* myIDFB;
   good = DirectFBCreate(&myIDFB);
You get a "screen" by calling
   IDirectFBScreen* myIDFBScreen;
   good = myIDFB->GetScreen(myIDFB, this, that, &myIDFBScreen);
In other words, DirectFB is allocating and initlaizig the space, as well as
filling in pointers (like the GetScreen pointer) for each one, and then
putting the space it allocated into the pointer whose address you passed in.
I'm not sure how to cleanly turn that into a class without wrapping every
single function. None of those functions take a pointer to your own class,
so there's a bunch of casting on every creation at a minimum, and you have
to hope your class is laid out the same as the parent struct and all that.
Maybe it'll work, but it's 9 hours of working on this stuff today already, so...
Date: 11 Nov 2009 21:05:03
Message: <4afb6d4f$1@news.povray.org>
> every single function. None of those functions take a pointer to your
> own class, so there's a bunch of casting on every creation at a minimum,
> and you have to hope your class is laid out the same as the parent
Fun fact about structs in C++: They /are/ classes. Only major difference
(IIRC) being that their members default to "public:".
Classes only start to really diverge from classic C structs when you go
for stuff like virtual methods or multiple inheritance. In the former
case there'll be a few hidden data members that C++ will automatically
add, while in the latter case... heck, I have not the slightest clue :-)
Date: 11 Nov 2009 21:08:35
Message: <4afb6e23$1@news.povray.org>
No, you can pretty much mash that all together (not that I'd advocate
it, because /then/ you really need to give up ever inch of
implementation-hiding.)
Date: 11 Nov 2009 21:39:31
Message: <4afb7563@news.povray.org>
I guess if you really want to recompile your entire library inside every
source file that uses any of it, yah.
Besides, I'm not sure Qt works that way. It has to run a preprocessor on
stuff, and putting code in .h files is a good way to make that not work.
Date: 11 Nov 2009 21:46:15
Message: <4afb76f7$1@news.povray.org>
That much I knew already. But I don't know if C structs are C++ structs for
sure. :-)
