POV-Ray : Newsgroups : povray.off-topic : Swell. Server Time
30 Jun 2026 03:51:24 EDT (-0400)
  Swell. (Message 11 to 20 of 312)
Subject: Re: Swell.
Date: 9 Nov 2009 04:44:49
Message: <4af7e491$1@news.povray.org>
On Mon, 09 Nov 2009 11:42:48 +0200, Stefan Viljoen wrote:
>>> (Then again, I don't have any hard data on the reliability of HD
>>> verses tape verses CD. I've heard that spinning HD up and down wears
>>> it out faster than keeping it spinning, but I don't know if that's
>>> true...)
>> Well, I didn't say anything about shutting the drive down.
> I've seen this phenomenon on older drives. Had a HDD in a system here
> that was left on for years, probably been turned off 20 or 30 times in
> its useful life. The fortieth or forty-fifth time the server was turned
> off, the HDD died - after running reliably (while not being turned off,
> ever) for 5 or 6 years. Ok, old hardware and an old drive, but just goes
> to show. Keep 'em spinning is better than spin-up / spin-down on a daily
> basis.
I don't know, I've got a drive that I take to the office with me about
every 2 weeks.  It sits at home off usually (unless I need something off
of it).  It's actually 2 500 GB drives in an enclosure that Maxtor sold
about 4 years ago now.
I bought two of 'em.
One stayed plugged in 24x7 for 3 years and then it croaked - most likely
a head crash.  The other has had periodic use for 5 years and shows no
signs of slowing down.
Of course the first showed no signs of slowing down either - right up to
the minute that it croaked.
Jim
Subject: Re: Swell.
Date: 9 Nov 2009 04:48:49
Message: <4af7e581$1@news.povray.org>
On Mon, 09 Nov 2009 09:42:27 +0000, Invisible wrote:
>>> I don't know, man... Backing up spinning disk to... spinning disk? Is
>>> that such a sensible idea?
>> Mirroring (or duplexing) provides a pretty good degree of data
>> protection because the odds of both drives dying at the same time are
>> pretty small.
>> It's been used for a very long time.
> This is not the same as a backup.
> RAID will protect you from physical failure of a single drive. It will
> not protect you if you accidentally delete a file, or if some virus
> infects your PC and deletes your stuff, or if the filesystem becomes
> corrupted somehow, or...
It depends a lot on what you're trying to protect yourself from.  There's
nothing, though, that says you can't create a mirrored set, let the
drives mirror, and then "break the mirror" and take one drive offline.
I've known people who have done that and used that for disaster recovery
when upgrading systems.
>> But I also back up directories from several systems to other systems
>> using rsync.
> Now that's more like it.
> An often-encountered backup strategy is to copy everything onto an
> external USB HD and then put that somewhere. I'm not sure that all this
> turning the drive on and off won't just wear it out faster.
See my anecdotal evidence in reply to Stefan.  Two identical units, one
powered on and off regularly, one that was left on 24x7.  Guess which one
failed?  Not the one that has been turned on and off regularly for 5
years now.  The one that was plugged in and running for 3 years solid.
> PS. I've yet to find a consumer RAID controller which actually works
> properly. They all seem to be hopelessly unreliable. And most of them
> are software RAID anyway; the controller is a normal IDE or SATA
> controller, and the Windows driver does all the actual RAID functions in
> software. It seems that only the £££ server-grade controllers actually
> do the job properly.
Software raid exists for some platforms - and for mirroring for backup
purposes, that's really all you need.  Heck, you could do it over iSCSI
with a fast enough connection (I've seen that done as well).
Jim
Subject: Re: Swell.
Date: 9 Nov 2009 06:44:34
Message: <4af800a2$1@news.povray.org>
scott wrote:
> What connector does the actual drive have?  Can you plug that directly
> into a desktop PC?
That's the first thing I checked--but it's that newfangled eSATA stuff,
and housemate's computer is ordinary EIDE with normal power connections.
Tim Cook
http://empyrean.freesitespace.net
Subject: Re: Swell.
Date: 9 Nov 2009 06:53:00
Message: <4af8029c@news.povray.org>
Invisible wrote:
>>>> guess there isn't a convenient modality for backing up 500GB of data?
>>> There is - but not for sane prices, no.
>> A 1.5 GB SATA Seagate Barracuda drive costs a mere $95 from newegg.
You mean TB, mayhaps?
>> I guess that arguably is an insane price - insanely cheap.
> (Then again, I don't have any hard data on the reliability of HD verses
> tape verses CD. I've heard that spinning HD up and down wears it out
> faster than keeping it spinning, but I don't know if that's true...)
As for myself, I've never had much luck with optical media.  Trust them
way less than hard drives.  But I'm planning on getting a new desktop at
the end of the month with 2x1 TB and was going to use this external
drive as the backup for *that* (until I need a second one)...
As I said, I *hope* it's just the enclosure that croaked, and the drive
itself is just fine.
If it's not...I dunno.  Data recovery places are expensive, and I don't
know if I can justify $1000+ even on the ~year's worth of data I had, at
the moment.  How time-critical are these kinds of things?  Can I just
keep it and when I have more money in a few months send it to a data
recovery place, if I can't get it working myself?
Tim Cook
Subject: Re: Swell.
Date: 9 Nov 2009 06:56:45
Message: <4af8037d@news.povray.org>
>> true...)
Depends. We have a batch of archive CDs which have all gone unreadable.
We have other, much older CDs (like ten years older) which are still
readable to this day. Seems to depend on how cheap the disks are.
If it's a mechanical fault, every single time you try to turn the thing
on, you could be doing more damange and destroying more data.
If it's just an electrical fault, it's probably not time-critical at
all. (Although I imagine getting replacement parts gets harder - but
then depends on how long ago the drive was manufactured, not how long
ago it failed.)
Subject: Re: Swell.
Date: 9 Nov 2009 07:42:01
Message: <4af80e19@news.povray.org>
> Jim
The way of the world*
* By William Congreve - premiered 1700
Best Regards,
Subject: Re: Swell.
Date: 9 Nov 2009 08:10:18
Message: <4af814b9@news.povray.org>
Hmm... well, no contest there. I guess there can be other factors involved
besides on / off frequency then? My personal experience with server-grade
hardware I've worked with differs though. It does seem (at least in my
personal experience) that turning HDD's on and off less makes them last
longer. But as you say, anecdotal. :)
I've written a simple cronjob which uses bash scripting and some
command-line PHP to automatically tar/7zip our primary server's vital sites
and databases once every 24 hours, and then FTPs that over to our over
server in a different datacenter automatically. Works fine too. The data
centers are about 10km away from each other.
That way we can lose only one day's worth of changes, which (cause we're
small!) usually isn't much. But I can see the point of some kind of "live"
solution if you do a TB a day or whatever.
Stefan Viljoen
Subject: Re: Swell.
Date: 9 Nov 2009 08:13:25
Message: <4af81574@news.povray.org>
See my other reply too... granted, but you refer to an "enclosure" - is that
a mobile drive? E. g. one which you pull out of its enclosure at work, then
you put it in an enclosure at home if you need something off it?
*brrr* - I shiver at the thought of a mobile HDD as a backup device...
How do you feel about the statement that the fact that if a drive is mobile,
inherently it will never last as long as a "traditional" statically mounted
drive that just sites in a cradle internally in a climate controlled server
rack / box?
Stefan Viljoen
Subject: Re: Swell.
Date: 9 Nov 2009 08:19:15
Message: <4af816d2@news.povray.org>
Same here! I've had more than one DVD-R or RW go bad. If I archive important
stuff to a R or RW disc, I usually make another archive copy 6 months or so
down the line. A year later I rotate, throwing out the "tail end" disc and
writing a new one. More than once I had to "bring forward" the
backup-backup disc, 'cause the "real" archive copy had gone south.
In the olden days on the Apple ][ with CP/M I had three - the grandfather,
father and son (and holy ghost! :) - I still remember the stomach churning
dread of those horribly loud floppy drives grinding and grinding and
then "BDOS ERROR" on the monochrome green-screen... Those were the days!
Isn't that hoping against hope? I mean, the most mechanically vulnerable
components are in the -drive-, no the enclosure? The enclosure is just a
port and physical container?
Not sure, but I think the quicker you do it the better the results you might
get?
Stefan Viljoen
Subject: Re: Swell.
Date: 9 Nov 2009 08:26:18
Message: <4af8187a$1@news.povray.org>
Typically an external enclosure contains some kind of controller to
convert from IDE/SATA/whatever to USB. This is a non-trivial piece of
electronics, and it's not inconceivable that it could break.
Seems kinda unlikely though...
