![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I don't understand why linux would modify the frequency/timings of cpu
> and
> memory, and even if it did, why it would have to modify BIOS to do that.
> (What good would it do to modify BIOS anyways? It would have to re-boot in
> order for the changes to become effective. BIOS is not something which is
> constantly running in the background. It just sets up the hardware and
> starts
> the OS and that's it.)
I thought this to be so, too. I was astonished to see that people seem to
have had some problems with this.
And I was not sure if this is true or not, so I asked.
BTW:
I did try the Ubuntu Live CD and it did reset my computer's clock to either
daylight saving time or universal time - both -1:00, so I cannot be sure
which.
This is no real problem, though, merely a very minor annoyance. Still, this
should not be.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> which.
> should not be.
The Linux Way(tm) seems to be to set the system clock to UTC and compute
local time from that depending on your timezone configuration. (Which,
on a live CD, is probably not set right anyway.) The Windows Way(tm) is
to set the system clock to local time...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp schrieb:
> I don't understand why linux would modify the frequency/timings of cpu and
> constantly running in the background. It just sets up the hardware and starts
Well, /nowadays/ that's how it is. Used to be different in DOS times.
Then again, that's quite a long time ago...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
DOS could change the CPU/memory frequency by modifying BIOS and without
having to reboot?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> having to reboot?
No, but BIOS did more back then than just start the OS. For instance,
hard disk access or keyboard input would be handled by the BIOS.
Back then, the role of the BIOS was still closer to its name ("Basic
Input/Output System) than it is nowadays: It really did basic input and
output handling even while the OS was running, and was far from evolving
into a hardware configuration interface. (Remember how CPU and memory
frequency would be configured via hardware jumpers or DIP switches, port
I/O addresses would be jumpered on the /expansion card/ the ports were
on, etc?)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Jim Henderson wrote:
> openSUSE 11.1 and 11.2 RC (which is in final testing now) should include
> ntfs-3g, so should be able to mount the NTFS partitions without a problem.
I have no problem using ntfs-3g and mounting NTFS drives RW from my OpenSuse
11 that I downloaded many months ago. I don't know it's on the live CD, but
it's definitely in the distro somewhere.
> With the live media, everything runs of the media - no need to perform an
> installation. The media is primarily to permit a user wanting to "test
> drive" Linux to see some of the features/functionality and to ensure
> system compatibility prior to installation.
Yeah, I learned that one the hard way. :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Actually, during boot-up, something along the lines of "installing new
microcode" or "installing new firmware" or something like that scrolls by.
That always worried me, but I figured it either got reversed at the next
reboot or it was too late to do anything about it, and it never caused any
trouble.
I am curious what that's all about, tho.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That pretty much went away when OSes started running in real mode. By the
time you got away from 16-bit code, nobody used the BIOS for basic I/O any more.
But you knew that.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 30 Oct 2009 18:17:49 +0100, Darren New <dne### [at] san rr com> wrote:
> by. That always worried me, but I figured it either got reversed at the
> next reboot or it was too late to do anything about it, and it never
> caused any trouble.
http://kerneltrap.org/node/2678
Typically, microcode updates are loaded by the BIOS, but not everyone
updates their BIOS when new microcode is released for their CPU.
FE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
