POV-Ray : Newsgroups : povray.off-topic : Bar codes Server Time
15 May 2026 10:56:03 EDT (-0400)
  Bar codes (Message 11 to 20 of 53)
Subject: Re: Bar codes
Date: 14 Oct 2009 09:01:09
Message: <4ad5cb95$1@news.povray.org>
>> Also it probably has some checksum, you'd need a shed load of stamps to
>> figure it out probably.
> Well, if you were going to reverse-engineer it, sure. But if you could
> figure out the algorithm...
How are you going to figure out the algorithm without access to lots of
stamps you know are valid?
> If you *knew* how they generate the barcode, you could put an arbitrary IP
> address in there.
Isn't the problem here that you're trying to work out how to generate the
barcode?
>> A bit like that system on Blu-Ray discs, where every player plays back a
>> very slightly different version, so when someone rips and uploads to
>> BitTorrent, they can tell exactly which player it was ripped from.
> Really? That's news...
http://www.freedom-to-tinker.com/tags/aacs?page=1
Date: 14 Oct 2009 10:26:00
Message: <4ad5df78$1@news.povray.org>
>>> to figure it out probably.
I suppose the fatal assumption here is that the encoding of the
information into the barcode is trivial. If these guys are sensible, it
won't be...
>>> back a very slightly different version, so when someone rips and
>>> uploads to BitTorrent, they can tell exactly which player it was
>>> ripped from.
Interesting. So the film actually ends a different way depending on
which player you play it with?
I bet that'll be popular...
[But then again, all these copywrite notices and "piracy is stealing"
ads and aggressive copy-protection systems only piss off paying
customers. They have no effect on criminals...]
Date: 14 Oct 2009 11:17:25
Message: <4ad5eb85@news.povray.org>
> Interesting. So the film actually ends a different way depending on which
LOL, I suspect they can do it slightly more subtly than that!  They only
need to make some tiny changes to some of the pixels to be detectable.  In
theory they could do what you suggest though, would be fun :-)
Date: 14 Oct 2009 11:33:38
Message: <4ad5ef52@news.povray.org>
> In theory they could do what you suggest though, would be fun :-)
Well, the article states that it's supposed to resist somebody pointing
a video camera at their TV screen, so a 1-pixel alteration won't do.
What I suppose they might do is have maybe a 1-frame difference in how
long a given scene is. Like, on some disks the shot of the ocean is 1362
frames long, and on others it lasts for 1366 frames. The difference
should be reliably detectable no matter how you film it.
Still, it seems like a hell of a lot of work considering that it doesn't
actually stop illegal copying, it just makes it hypothetically possible
to find out who did the illegal copying...
Date: 14 Oct 2009 12:35:40
Message: <4ad5fddc$1@news.povray.org>
With the understnading that a "player" in this context means "model number"
at least in the hardware players. I.e., they can tell it got ripped by a
Sony XYZ-1230 brand blu-ray player, not Joe's blu-ray player.
The idea is to identify it enough to black list the leaked keys, not to
catch the person who distributed the movie.
Date: 14 Oct 2009 12:36:48
Message: <4ad5fe20$1@news.povray.org>
Probably different watermarks encoded, without actually looking visibly
different in a way you could tell. Otherwise, someone might just rip it
twice and change the file to use (say) 1364 frames of ocian.
Date: 14 Oct 2009 14:16:17
Message: <4ad61571$1@news.povray.org>
>> pointing a video camera at their TV screen, so a 1-pixel alteration
>> won't do.
Well, to lots of people digital watermarking is the Holy Grail of
digital technology, the thing that will finally stop the pirates.
Trouble is... it's extremely hard.
If the watermark is encoded in a way that's perceptually
insignificant... well guess what lossy codecs are specifically designed
to do? Yes, that's right: *remove* perceptually insignificant information!
I'm thinking things like small timing differences would be too subtle to
notice, but significant enough for encoding to not screw them up. And
you could try to correct it yourself, but you'd have to know exactly
which bits of timing are varied in order to know what to change...
http://blog.orphi.me.uk/
Date: 14 Oct 2009 14:17:40
Message: <4ad615c4$1@news.povray.org>
> number" at least in the hardware players. I.e., they can tell it got
> ripped by a Sony XYZ-1230 brand blu-ray player, not Joe's blu-ray player.
The article suggests that the system *is* supposed to be able to narrow
it down to a specific machine or possibly a small number of such
machines, not just a specific model.
Of course, it depends on whether the makers bother to fit each player
with semi-unique keys or not... One commenter pointed out that hardware
manufacturers have no vested interest in making DRM work. Only studios do.
Date: 14 Oct 2009 14:49:51
Message: <4ad61d4f@news.povray.org>
Certainly.
Well, you can spread it across lots of media, a few bits at a time. Xerox
had a mechanism where you could vary the spacing between words in a
document, and encode maybe a couple dozen bits per page of a document, for
example.
But yes, it's difficult. Anything else is open to fairly simple subversion,
tho.
Could be, until you convert PAL to NTSC. :-) What you'd want is to have
something where it's difficult without the key to even know where the data
is encoded.
But you have the different pieces all on the disk. All you need is the keys
from two different players and you can tell what's different.
Date: 14 Oct 2009 14:51:13
Message: <4ad61da1$1@news.povray.org>
No, that's what I'm saying.  "Player" in *this* context means a set of keys
(obviously). Software players can each get a set of keys from the
manufacturer when you install the machine. But people don't, in general,
program a unique key into each hardware player.
