![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://blogs.ngm.com/blog_central/2009/10/a-grander-k.html
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
...and here I was thinking that 12g of C12 was *defined as* one mole of
C12 atoms...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> C12 atoms...
Hence the definition of 'mole' depends on the definition of 'kilogram',
not the other way around.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Why can't the kilogram be defined as the weight of exactly 1 litre of
pure water at a certain temperature? After all, that has been the de-facto
definition for forever.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Perhaps they could _change_ the definition to that, but I'm willing to
bet that it's off by a bit from the current definition.
A tautology is a thing which is tautological.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
AFAIK kilogram *was* originally defined as the weight of 1 liter of water,
but for whatever reason they changed it to the weight of a specific object
(I really can't understand why).
According to wikipedia, one liter of pure water at 4 degrees celsius (the
standard temperature for measuring SI units) is 0.9999720 kilograms.
If they changed the definition of kilogram back to its original form, the
change would be less than 0.003% from the currently accepted value. Would
that be a huge catastrophe?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It may be that it's too difficult to measure "pure water" at "exactly 4
degrees celsius" for modern measurement precision.
Plus, of course, if you make *everything* circular, then you have nothing.
If a kilogram is the weight (well, mass) of a liter of water, and a liter is
1000 cubic centimeters, and a centimeter is the length of one gram of carbon
atoms lined up (or some such) then the whole thing falls down.
Given that a cm is defined in terms of the speed of light, and time is
defined in terms of a cesium atom at rest at 0K, I guess we already have
unusable base metrics, tho.
Only for scientists working on 15 digits of precision in their scientific
experiments. Kind of like "would it really make a difference if we skipped a
leap-second every 3 to 5 years?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> C12 atoms...
Ah, I see.
Couldn't they just reverse it? I mean, just say that 1 Kg = the mass of
XXX C12 atoms?
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Not more difficult than measuring the exact speed of light (which is needed
to define the unit of length) or an exact magnetic force (which is needed to
define the unit of electric current).
But a centimeter is not defined like that. It's defined from the speed of
light in vacuum. There's no circle.
Unusable base metrics?
Given that the object which is currently the measurement of 1 kg changes
weight every time it's measured, does it really matter? It would simply be
one more change, but then it would be fixed, and that's it.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, I saw that.
0K is unreachable even in theory.
True. I don't know how they work it now.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
