POV-Ray : Newsgroups : povray.off-topic : Why I don't do design Server Time
11 Nov 2026 23:39:12 EST (-0500)
  Why I don't do design (Message 18 to 37 of 37)
<<< Previous 17 Messages Goto Initial 37 Messages
Subject: Re: Why I don't do design
Date: 12 Oct 2009 08:09:28
Message: <4ad31c78$1@news.povray.org>
>> I notice the brackets around the fraction aren't tall enough to enclose it
>> properly. You can fix it like so:
>>   ( \frac{...}{...} )
>> becomes
>>   \left( \frac{...}{...} \right)
> OK ... this was helpful ... thanks.
Works with any delimiter, by the way:
   \left[ ... \right]
   \left| ... \right|
etc.
If you wanted to be flashy, you could replace min(...) with those funny
bent-angle brackets - but I don't suppose anybody except a mathematician
would understand what the hell that means, so leave it.
>> I should perhaps also point out that, technically, when TeX sees
>> <math>cat</math>, it interprets it as "c * a * t", which probably isn't
>> what you want. Use <math>\text{\it cat}</math> instead. (There's a subtle
>> difference in the letter spacing - and also the typeface is slightly
>> different.)
> The \it tag (italics?) was causing me grief. It gave a lexing error ...
> failed to parse. With the \text tag alone I get normal typeface, without it
> I get the italics typeface. it doesn't seem to be behaving as you suggest.
It's quite possible the Wiki doesn't support arbitrary TeX markup, but
only supports a specific subset of commands. You could try
\text{\emph{distance}} or something. That should typeset it in text
italics, which is subtly different from math italics (especially
spacing). The AMS-LaTeX \text{} command also adjusts the spacing subtly.
I will admit that all of this makes a fairly subtle difference to the
final output though.
> Here's what it looks like now:
> http://wiki.povray.org/content/Documentation_Talk:Reference_Section_4
> I think it looks like what Mike was getting at ... correct?
Change "min" to "\min" to have it typeset correctly. (I.e., in Roman
type, like all function names. It might even fix the spacing on the
brackets following...)
The spacing of the superscripts looks slightly odd, but I couldn't tell
you why...
Date: 12 Oct 2009 08:42:36
Message: <4ad3243c@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4ad31c78$1@news.povray.org...
>   \left[ ... \right]
>   \left| ... \right|
another nugget ... thanks
you are probably correct ...
> You could try \text{\emph{distance}} or something. That should typeset it
> in text italics, which is subtly different from math italics
no joy with this markup either ....
> Change "min" to "\min" to have it typeset correctly. (I.e., in Roman type,
> like all function names. It might even fix the spacing on the brackets
> following...)
worked ... thanks for the assist!
Date: 12 Oct 2009 08:50:13
Message: <4ad32605@news.povray.org>
>>   \left[ ... \right]
>>   \left| ... \right|
This method makes the brackets just big enough to contain the interior
text. You can also set the bracket size manually (e.g., if you want the
outer brackets big and the nested brackets smaller, to aid visibility),
but we won't worry about that. In this specific case, the brackets come
out reasonable sizes, so no need to fiddle.
You can also do stuff like this:
             | -1  if x < 0
   sign x = <   0   if x = 0
             |  1   if x > 0
Use "\left\{" to get the stretched symbol (you have to balance it with
"\right."), and then use an array environment to typeset the multiple rows.
I don't suppose for 13ms that there's any *documentation* for what the
wiki actually supports though...
Really? That's odd. Well, I guess the difference is quite small.
>> following...)
In general, any function name (sin, cos, tan, min, max, lim, etc.) wants
to be handled this way (\sin, \cos, etc.)
Now, in LaTeX there's a way to define new function names - but you have
to write the declaration in the document preamble. Not sure if you can
access this particular feature from the wiki...
Any further questions? :-D
Date: 12 Oct 2009 11:58:42
Message: <4ad35232$1@news.povray.org>
>> what you want. Use<math>\text{\it cat}</math>  instead. (There's a subtle
>> different.)
	In math mode, if you want text to appear in italics, and not be treated
like a formula, use \textit{...}.
	There's also \textrm if you want it to be nonitalicized. Bunch of
others - see the links below.
	Check out the page now - the 2nd formula is using \textit
	Ever been to the LaTeX Wikibook:
http://en.wikibooks.org/wiki/LaTeX
	I don't know how good it is for learning LaTeX, but it's fairly good
for either quick lookups or for "recipes" to achieve certain effects:
http://en.wikibooks.org/wiki/LaTeX/Mathematics#Adding_text_to_equations
http://en.wikibooks.org/wiki/LaTeX/Formatting#Font_Styles_and_size
A tautology is a thing which is tautological.
Date: 12 Oct 2009 12:18:39
Message: <4ad356df$1@news.povray.org>
Invisible wrote:
> I wonder - is there anything that SketchUp *is* the right tool for?
Getting people to talk about how cool Google is.
Date: 12 Oct 2009 13:30:51
Message: <4ad367cb@news.povray.org>
"Neeum Zawan" <m.n### [at] ieeeorg> wrote in message
news:4ad35232$1@news.povray.org...
Jackpot! Exactly what I was going for, with them next to each other it's
easy to see the difference in font spacing.
> I don't know how good it is for learning LaTeX, but it's fairly good for
Yes .... there is a lot of good stuff on Wiki's .... bookmarking links ....
Thanks
Jim
Date: 12 Oct 2009 14:14:06
Message: <4ad371ee$1@news.povray.org>
> treated like a formula, use \textit{...}.
Ah. I knew about \textrm, but \textit wasn't mentioned anywhere. (I know
it works in text mode, but I wasn't sure about math mode.)
Good work.
http://blog.orphi.me.uk/
Date: 12 Oct 2009 14:14:46
Message: <4ad37216$1@news.povray.org>
Does anybody else detect a subtle hint of cynicism here? ;-)
Date: 12 Oct 2009 15:14:10
Message: <4ad38002$1@news.povray.org>
On 10/10/2009 2:01 PM, Orchid XP v8 wrote:
> Isn't that just nausiating to look at?
That looks exactly like the decade old Mitel phone in my office.
Excellent work!
~Mike
Date: 12 Oct 2009 15:17:29
Message: <4ad380c9@news.povray.org>
> Excellent work!
Please tell me it doesn't use those colours. o_O
Date: 12 Oct 2009 15:28:33
Message: <4ad38361$1@news.povray.org>
	For me it was the opposite.<G> I thought they were meant primarily for
math mode, and only found out they work in regular mode when I posted
the Wikibook links...
An unbreakable toy is useful for breaking other toys.
Date: 12 Oct 2009 17:13:25
Message: <4ad39bf5@news.povray.org>
Welcome to my humble home.
This took 11 minutes to draw. And no, the house isn't *really* that
God-awful colour...
[And no, technically it's my mum's house.]
Download 'a01.png' (47 KB)
Preview of image 'a01.png'
Date: 12 Oct 2009 17:18:38
Message: <4ad39d2e@news.povray.org>
  Why does this remind me vividly of The Sims 2?
Date: 13 Oct 2009 05:50:44
Message: <4ad44d74$1@news.povray.org>
I don't know. Does The Sims 2 feature horrific colour schemes and badly
drawn stairs?
Date: 13 Oct 2009 11:10:57
Message: <4ad49881$1@news.povray.org>
Well, no. It's not as fancy as yours. It comes in a nice shade of beige.
~Mike
Date: 13 Oct 2009 11:26:27
Message: <4ad49c23@news.povray.org>
Ah, OK.
I was actually purposefully going for a retro look, if only because back
in the old days straight lines were cool.
(The colours were so I can tell WTF I'm looking at while I model it.
SketchUp isn't very easy to navigate...)
Date: 13 Oct 2009 13:03:12
Message: <4ad4b2d0@news.povray.org>
Invisible escreveu:
>> something it really isn't designed for.  If you really want to design
>> stuff like that phone with nice smooth surfaces then put the effort in
>> to learning something like Blender rather than SketchUp.
> Every single time I mention it, everybody says I should use Blender
> instead...
It's much better at architectural creations than Blender.  Blender and
other polygonal-based modellers are not the right tool for product
design either.  That truly demands fine and precise NURBS tools.
a game sig: http://tinyurl.com/d3rxz9
Date: 13 Oct 2009 13:48:18
Message: <4ad4bd62$1@news.povray.org>
http://www.wonderhowto.com/how-to/video/how-to-model-a-house-in-blender-3d-242095/
Which is not to say Blender makes it easy, but it's not *too* bad.
Date: 13 Oct 2009 14:02:11
Message: <4ad4c0a3@news.povray.org>
Darren New escreveu:
I've learned to use that technique too.  Sketchup still has a large edge
over it.
Date: 13 Oct 2009 14:39:17
Message: <4ad4c955@news.povray.org>
> over it.
I see what you did there. ;-)
