POV-Ray : Newsgroups : povray.off-topic : Shamelessly lazy question Server Time
24 May 2026 01:53:02 EDT (-0400)
  Shamelessly lazy question (Message 11 to 20 of 20)
Subject: Re: Shamelessly lazy question
Date: 12 Sep 2009 10:46:26
Message: <4aabb442@news.povray.org>
Jim,
I have experience with that sort of application.
In one case I have a C# program that downloads share data from a certain
site.  One file per day in CSV format.  The format of the file has
varied over time so the program does some cleansing.  The raw data is
then loaded to a database where the heavy duty work starts.
Doing something like day to day deltas and producing a report or data
extract to be distributed is easy from there.  My main product is a
database query and reporting tool that can work on pretty much all DBMSs
/ data sources (including Excel (.XLS) and .CSV).  It includes a script
language suitable for automating exactly this sort of process.  Results
can be produced in various formats including Excel, CSV and PDF.  An
email script command can send results out.
Give me some sample data (say 3 days worth) and I'll mock something up.
  Don't know if a custom application or the general purpose tool is the
way to go without seeing some data.
I have done things like this in Excel using VBA.  C# or VB.Net are so
much richer that I wouldn't contemplate using VBA any more.
Paul
Date: 12 Sep 2009 13:03:25
Message: <4aabd45d$1@news.povray.org>
Darren New wrote:
> SharkD wrote:
>> Too bad it relies on Excel. It would be a lot easier with SQL.
> SQL is a language, not a file format. You can't download SQL off the
> intarwebs.
> Now, posting it as a CSV would have made more sense, were it really just
> tabular data.
Hey, some TLC data we access using dumb terminal (3270?) emulation and
CICS!  Remember those days?
Date: 12 Sep 2009 13:15:45
Message: <4aabd741$1@news.povray.org>
I'm almost embarrassed to admit I do.
Date: 12 Sep 2009 13:25:43
Message: <4aabd997$1@news.povray.org>
I know a lot of "serious" programmers look down on it, but this is
exactly the kind of thing that VB shines at: quick & dirty programs that
have simple requirements, and interface with other MS apps.
...Chambers
Date: 12 Sep 2009 14:16:20
Message: <4aabe574$1@news.povray.org>
Paul Fuller wrote:
> Jim,
> Regards,
> Paul
Wow Paul, thank you. I may take you up on that.
If you are interested in taking a peek, and as of right now I would need
to confirm everything I am saying, but I believe the list is published
on this page:
http://www.nyc.gov/html/tlc/html/current/current_licensees.shtml
The list in question is this one:
'TLC Licensees with NYS DMV Status Issues'
Column A appears to be the license number to match on.
In Column C we would filter for 'For-Hire-Vehicle Driver'
That's all that is needed.
Column B obviously just confirms the name and
Column D is presumably the revocation/suspension date.
So if I understand it correctly a 'hit' against this list would mean a
driver could not be dispatched.  A 'miss' would mean he is okay.  'Hits'
could then be printed out for further investigation, individually, on
the separate system.  (Probably that CICS emulation thing I mentioned to
Darren.)
So the basic problem is that these bases have many drivers, so a daily
batched lookup from a list of their own drivers, which would print out
revoked drivers, would be a convenience for them.  Checking even say 100
numbers, individually, against the list every day would be cumbersome
and a bit ridiculous in this day and age.  But paying $10,000 for a
'program' to do it? Whoa.
-Jim
P.S.
(I have a little Python script I use to download the files on this page:
http://www.nyc.gov/html/tlc/html/courtadmin/court_hearing_calendar.shtml
I have to remember to run it manually every week or so, my code checks
for any new files I haven't already gotten.  It is also quite messy
because these are PDF files so it uses some code I found, but don't
understand, to translate into plain text.  I then use string
manipulation and pattern matching to extract what I need, the counts for
the numbers of times different violations are scheduled for court
hearings.  But this is just a little scripted tool I use myself with the
Python interpreter installed. And there is no error catching or bullet
proofing of any kind.  I wouldn't have the first clue about distributing
a compiled version of such a thing.)
Date: 12 Sep 2009 14:43:50
Message: <4aabebe6$1@news.povray.org>
FWIW, this is the whole "Software as a Service" kind of thing. Have *them*
send *you* a list of their licensees whenever they hire or fire someone,
then run everyones lists against the excel sheet and mail them back any
hits.  Then you don't have to compile it, bullet proof it, etc etc etc.
Date: 12 Sep 2009 14:48:11
Message: <4aabeceb$1@news.povray.org>
Alternately, I don't know how one scripts Open Office offhand, but that
might be easier also.
Date: 12 Sep 2009 20:42:15
Message: <4aac3fe7@news.povray.org>
Jim,
After I replied I found the TLC website and grabbed some data.  Looks
really straight forward.
Is there some reference list that maps drivers to companies ?
Then you could list the suspended drivers by licensee.  Those licensees
that sign up for your service get a list of their drivers who have
changed status.
Paul
Date: 13 Sep 2009 06:23:24
Message: <4aacc81c$1@news.povray.org>
Paul Fuller wrote:
> Jim,
> changed status.
> Paul
I will pitch this idea to my boss.
Date: 13 Sep 2009 11:42:30
Message: <4aad12e6$1@news.povray.org>
Or, when they sign up, they provide you the list of drivers, which you then
keep and let them update remotely.
