POV-Ray : Newsgroups : povray.off-topic : You thought 4K graphics demos were impressive? Server Time
23 Feb 2026 17:40:28 EST (-0500)
  You thought 4K graphics demos were impressive? (Message 11 to 20 of 42)
Subject: Re: You thought 4K graphics demos were impressive?
Date: 28 Aug 2009 12:46:24
Message: <4a9809e0@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Warp wrote:
> >   It's one of the best self-replicating programs I have ever seen.
> FWIW, this is called a "quine", after the philosopher Quine.
> http://en.wikipedia.org/wiki/Quine
  I wonder what a quine in haskell would look like.
Date: 28 Aug 2009 13:10:00
Message: <web.4a980e6ca684af8f958421d50@news.povray.org>
>   It's just incredible how he could store the *shapes* of all four programs
> inside a single self-replicating program.
I don't know exactly how he did it, but if I had to do it, I would use 1/3 of
the junk at the beginning to define each image (It actually looks like he's
divided them in half).  I would RLE compress the image and add or subtract a
constant until the ascii values were all in the printable range.  If you just
reprint the data section each time with different whitespace and the same
program at the end, maybe you could pull it off.  That's a million miles away
from actually pulling it off, but maybe it would work.
 - Ricky
Date: 28 Aug 2009 13:15:01
Message: <web.4a98101ca684af8f958421d50@news.povray.org>
Not sure, but this is a particularly short quine, written in c:
http://www0.us.ioccc.org/1994/smr.c
http://www0.us.ioccc.org/1994/smr.hint
 - Ricky
Date: 28 Aug 2009 14:50:04
Message: <4a9826dc@news.povray.org>
On Fri, 28 Aug 2009 08:34:34 -0400, Warp wrote:
>   Most self-replicating programs just replicate themselves, and that's
>   it.
> No ascii art either.
One of the most impressive of these that I've ever seen was from the
IOCCC - I can't seem to find the right keywords, but it did something
similar to this but used more than one programming language (ie, #1 was
C, #2 was maybe Pascal, #3 was C again).  Wish I could find it now.
Jim
Date: 28 Aug 2009 14:56:43
Message: <4a98286b@news.povray.org>
  That program doesn't link. The linker cannot find the main() function.
Date: 28 Aug 2009 15:11:35
Message: <4a982be7$1@news.povray.org>
>>   it.
I found a program (I forget what it did) that was runnable in multiple
languages simultaneously...
http://blog.orphi.me.uk/
Date: 28 Aug 2009 18:24:43
Message: <4a98592b@news.povray.org>
I  saw that.  And not similar languages. Like, javascript, awk, Haskell, and
C++ or something.
The one I liked was the one that output its own source code in the shape of
a maze, and then solved itself.
   Understanding the structure of the universe
    via religion is like understanding the
     structure of computers via Tron.
Date: 28 Aug 2009 18:30:36
Message: <4a985a8c$1@news.povray.org>
>>>   it.
Hmmm, maybe that's the one I am remembering - though I was sure there was
a code generator involved in it...
Jim
Date: 28 Aug 2009 19:15:00
Message: <web.4a9863cba684af8f958421d50@news.povray.org>
I think the hints said there was some tricky compile flags to force it to
compile.  Turns out this is how you compile it:
cp smr.c smr
chmod +x smr
That doesn't seem valid, but I guess that's how you abuse rules and get them
changed.
 - Ricky
Date: 28 Aug 2009 22:54:20
Message: <4a98985c$1@news.povray.org>
> and C++ or something.
I actually encountered something close to this in real-life work: It was
a file designed to be included in both a C program and a makefile, to
define certain constants.
And typically, pulling this off is even easier if the languages are
quite different, as the most typical way to do it is by having one
language see comments where the other one doesn't.
For instance, to fuse POV-Ray SDL and Lua code, you can use the
following pattern:
#version 3.7; /* (Lua ignores first line if it starts with "#")
   -- Lua code goes here
   // POV-Ray SDL code goes here
