POV-Ray : Newsgroups : povray.off-topic : Now that's cool Server Time
7 Apr 2026 23:10:43 EDT (-0400)
  Now that's cool (Message 29 to 38 of 38)
Subject: Re: Now that's cool
Date: 27 Aug 2009 12:42:31
Message: <4a96b777$1@news.povray.org>
clipka wrote:
> As for /arriving/ at the same time: Yes. As for being /sent/ at the same
> time: No.
If X and Y are very close together in space when the beam is sent, sure. If
X is on the tracks and Y is on the train, and they each set off the
flashbulb as the arm on the side of the train strikes the pole stuck by the
side of the tracks, wouldn't that be a simultaneous event? I mean, the
contacts touch once, and there's only one contact, so how could it not be
the same time for both flashbulbs?
   Understanding the structure of the universe
    via religion is like understanding the
     structure of computers via Tron.
Date: 27 Aug 2009 15:39:01
Message: <4a96e0d5$1@news.povray.org>
clipka wrote:
>> We can't get out of the medium to observe light waves as we can with
>> water waves.
> Well, then compare it with the perspective of a person actively
> swimming: Despite obviously being inside the medium, from his point of
> view water waves going in the same direction as he is appear to be
> slower than those going in the opposite direction.
Does he? Or does he just observe a frequency change, i.e. see the crests and
  troughs closer together or further apart, as with the doppler effect
in sound and light?
> You don't even have that with light, no matter how fast you "swim".
>> I have heard the apparent decrease in the velocity of light is
>> explained by the interference of light
>> re-emitted by the material so as to give the appearance of a decrease
>> in velocity. But the "true" velocity
>> of the light remains that in free space. (I did not altogether
>> understand this and may have it wrong.)
> Given that refraction normally occurs due to different /phase/
> velocities of light in two materials, but at the same time there have
> been experiments reducing the /signal/ velocity of light almost to a
> standstill... no, I guess that's oversimplified.
I wasn't convinced by the explanation and couldn't find a physicist to
comment
at the time.
>> That may be what I was getting at, but also the fact that the
>> "relativistic" effects
>> such as time dilation or increase in mass that I would observe in an
>> object
>> (say a space ship) moving with 99.99% the speed pf light relative to
>> me are *not*
>> observed by its occupants and my observation is no more (or no less)
>> valid than theirs.
> Which basically boils down again to saying that your /frame of
> reference/ (which includes sort of a local definition of length) is no
> more (or no less) valid than theirs.
Exactly, according to the relativity principle observations from within
any frame
of reference are valid for it alone.
A curious result of this is that any mass measurements contain two
components,
the inertial mass (the mass that would be measured if the object were at
rest with
respect to the measurer) and the relativistic mass due to the relative
velocity of the
object with respect to the observer.
David
Date: 27 Aug 2009 16:09:20
Message: <4a96e7f0$1@news.povray.org>
> Does he?
Yes.  As I've said, you can boat faster than your wake, and you can fly
supersonic. In both cases, all the waves look to be going backwards.
Date: 27 Aug 2009 16:44:37
Message: <4a96f035$1@news.povray.org>
Darren New wrote:
> You can put an atomic clock on Southwest Airlines and measure the error
> you caused at the other end by being out of the gravity well and
> traveling at velocity.
> You can just leave one in the basement and one at the top of a
> skyscraper for a couple months and measure the difference.
Nahhh, that just shows the clocks are inaccurate, with moving them,
uh...jostling the atoms so they vibrate differently.
...yeah!
> Assuming X and Y are both the same distance from Z when you start
> counting, why wouldn't they? Even with regular waves, that'll happen.
Well, sure, if you make *that* particular assumption...but the example I
was reading didn't specify, so I was confused.
Still am.  Observation being one thing and actuality being another,
things do happen simultaneously.  Saying that they don't because you
can't have an 'outside' frame of reference is hubris, imo.  Like saying
nothing in the universe exists outside the radius of light being able to
travel since the big bang, with the observer (us) at the centre.  It's
the whole earth-centric universe all over again.
Tim Cook
http://empyrean.freesitespace.net
Date: 27 Aug 2009 17:10:28
Message: <4a96f644@news.povray.org>
Well, if they're not the same distance from you when they flash, why would
you expect to see the flashes at the same time?
Or maybe I'm confused. You might be right. There's a "regardless of
distance" clause at the end that makes the thing nonsensical except for
c==infinity.
I read it more along the lines of "the bullet goes the same speed regardless
of how fast the gun is moving when you fire it" sort of thing.
Only if they're close to each other. There really is no "at the same time"
for objects widely separated.
No. If you can have two events happen in one order for me and another order
for you, and there's *nobody* who can say what "at the same time" means,
then how do you have simultaneity?
Basically, you can't have "equal times" unless space has "equal places".
OK, so take a vector. What you're saying is "I can't believe the Z component
of a vector is sometimes zero and sometimes not zero, regardless of where
you put the origin and how you rotate the axes."  The only way the Z
component stays zero regardless of where you put your axes is if the other
components are zero also.
 > Like saying
It's not earth centric because it's true of everyone. And "exists" means
"capable of having any sort of affect on the observer", in which case the
sentence is true. :-)  It's as "non-existent" as the future is.
Date: 27 Aug 2009 19:38:12
Message: <4a9718e4@news.povray.org>
>> same time: No.
Not even then. It would reduce the "simultaneity window" accordingly,
but never reduce it to zero. And note that the other effects you want to
observe diminish with the scale of your experiment, too.
> If X is on the tracks and Y is on the train, and they each set off the
> the side of the tracks, wouldn't that be a simultaneous event? I mean,
> the contacts touch once, and there's only one contact, so how could it
> not be the same time for both flashbulbs?
Note that the flashbulbs won't go off simultaneously with the
establishment of the contact: Electric signals, too, only propagate at
the speed of light (if not slower).
Date: 27 Aug 2009 19:46:26
Message: <4a971ad2@news.povray.org>
Yes, but this time we have a solid scientific reason: Because /we/ are
living on the earth, and it's where /our/ frame of reference happens to
be "centered" at.
So what's wrong with /us earthlings/ to be earth-centric? (After all,
that's the place where the vast majority of us is bound to be living in
for the next couple of millennia - so maybe a bit more earth-centricity
would do us some good, or we may not make it that long.)
Date: 27 Aug 2009 19:53:50
Message: <4a971c8e$1@news.povray.org>
> and
>  troughs closer together or further apart, as with the doppler effect in
> sound and light?
Try it out, and you'll see that the crests and troughs will actually
apear to be moving at different speeds depending on direction - while
the distance between them will remain constant (which is /why/ they'll
appear to change their frequency).
> components,
> rest with
> velocity of the
Yup. E = mc^2: From an outside observer's point of view, pumping energy
into some thing to speed it up to light speed also pumps up its mass.
Date: 27 Aug 2009 20:55:53
Message: <4a972b19$1@news.povray.org>
clipka wrote:
>>> same time: No.
Well, sure. Epsilon and all that.
X and Y, not X and Z. :-)
Certainly, modulo that stuff, yes. But if Z is light-days away, it's going
to be close to simultaneous.  Unlike if, for example, X is light-days from
Y, where it makes no sense to talk about "one event."
It's a thought experiment, see.
Date: 27 Aug 2009 21:04:51
Message: <4a972d33$1@news.povray.org>
> going to be close to simultaneous.  Unlike if, for example, X is
> light-days from Y, where it makes no sense to talk about "one event."
Still, those minor differences make... well, the difference.
