POV-Ray : Newsgroups : povray.off-topic : This is great Server Time
5 May 2026 00:24:31 EDT (-0400)
  This is great (Message 11 to 20 of 94)
Subject: Re: This is great
Date: 21 Aug 2009 08:48:50
Message: <4a8e97b2@news.povray.org>
Invisible wrote:
> It burns! IT BURNS!! >_<
> I especially like the claims of "every time we added debug code, the bug
> went away". Surely it is impossible to work under such conditions...
Heisenbugs are always lots of fun. ;)
~Mike
Date: 21 Aug 2009 09:38:36
Message: <4a8ea35c$1@news.povray.org>
Well, I tell you that's pure reality. Last project I was working on,
"let's just ship the device with debug output X enabled by default" was
quite a common suggestion during troubleshooting. We managed to keep it
a joke though - the customer would not have been amused.
And some issues we did indeed fix using the "if you're falling through a
hole, don't do it" kind of approach, because the errors occurred so
infrequently that we just had no chance of ever finding the root cause.
Yeah, it's kind of fun developing software for devices where
occasionally the only way to get any helpful debug information out of
the thing is by switching an LED on or off, and errors might just as
well be hardware-related.
Date: 21 Aug 2009 09:43:03
Message: <4a8ea467$1@news.povray.org>
Invisible schrieb:
> It certainly makes me realise that I prefer safe languages over
> efficient ones any day of the week. :-P
You can get such issues with "safe" languages, too: All you need is some
race conditions that kick in when performance is particularly good, but
don't if performance is bogged down a deal by debug output.
Date: 21 Aug 2009 10:01:23
Message: <4a8ea8b2@news.povray.org>
  That was a relatively common problem in C and C++ years ago, but nowadays
especially C++ compilers have got much better at debugging such things. For
example Visual C++, when compiling in debug mode, will add bounds checks to
all STL code and IIRC raw array accesses (although there are limits to the
latter, as it's quite difficult to check bounds when pointer arithmetic is
being performed). gcc has a precompiler constant which, when defined, turns
on similar checks to all STL code. Then you can use valgrind to catch the
rest.
  The only situation nowadays where you might end up having such heisenbugs
in C++ which are not caught by the compiler even in debug mode is if you
use dirty raw pointer arithmetic hacks, which is something you seldom really
have to do in clean good-quality code, not even if you aim for maximum
efficiency.
Date: 21 Aug 2009 10:08:27
Message: <4a8eaa5b$1@news.povray.org>
>> bug went away". Surely it is impossible to work under such conditions...
Wouldn't this make it scientifically impossible to deliver a working
product?
Date: 21 Aug 2009 10:10:02
Message: <4a8eaaba$1@news.povray.org>
Safe languages don't permit race conditions in the first place.
Date: 21 Aug 2009 10:33:17
Message: <4a8eb02d$1@news.povray.org>
> rest.
> efficiency.
Maybe you're right, I don't know. I just find it makes me kind of
nervous working with something which can break just because you changed
the order of a few statements in a way which, conceptually, shouldn't
change anything.
(Notice that guy who said he couldn't just add a new integer field to a
data structure because it would break a few thousand other functions?
Does that sound like good abstraction you to?)
Still, I guess that's why I'm not a games developer...
I was also puzzled when I looked at Gentoo and discovered just how many
C programs break horribly just because they were written for IA-32 and
got recompiled for AMD64.
Date: 21 Aug 2009 10:58:00
Message: <4a8eb5f8$1@news.povray.org>
> data structure because it would break a few thousand other functions? Does
It's not because it's a game, it's because it's being made for profit.
Writing any software as a hobby is very different than writing it to try and
make money.
Date: 21 Aug 2009 11:10:09
Message: <4a8eb8d1@news.povray.org>
  And then you wonder why safe languages are so slow.
Date: 21 Aug 2009 11:12:04
Message: <4a8eb944$1@news.povray.org>
>> a data structure because it would break a few thousand other
>> functions? Does that sound like good abstraction you to?)
> and make money.
 From what I've seen, only games programmers go to the extremes of using
obscure and elaborate low-level hackery to squeeze every last
femtosecond of performance out of the machine. Other programmers usually
don't have such ardent performance limits to worry about. (Usually.)
Which is not to say that all codebases that aren't games are beautifully
written... just that games typically have ludicrous performance
requirements and insane release schedules.
