![](/i/fill.gif) |
I'm trying to export data from Blender.
If you have ever used Blender you will see that the Y axis is pointing
forward and the Z axis is pointing up.
My problem is that I need to flip everything so that the Y axis is up
and the Z axis is forward, so basically swapping the two.
For vectors it's easy, just swap y and z :
[x, y, z] becomes [x, z, y]
and after a lot of searching on the internet I even how to flip a matrix:
{ rx, ry, rz, 0 }
{ ux, uy, uz, 0 }
{ lx, ly, lz, 0 }
{ px, py, pz, 1 }
becomes
{ rx, rz, ry, 0 }
{ lx, lz, ly, 0 }
{ ux, uz, uy, 0 }
{ px, pz, py, 1 }
Both of these seem to work but I can't find how to flip a quaternion.
![](/i/fill.gif) |
![](/i/fill.gif) |
If all else fails, you can always use a rotate about the X axis by 90
degrees, followed by a scale by <1,-1,1> to flip direction of the
then-up Y axis.
Or just export the whole scene to use a fitting coordinate model, by
defining appropriate up/right/direction and sky vectors in the camera
statement.
![](/i/fill.gif) |
![](/i/fill.gif) |
A rotation quaternion is defined as (w,x,y,z) where xyz is the axis to
rotate around and w is related to the rotation angle. Would simply swapping
the y and z elements around do what you want?
![](/i/fill.gif) |
![](/i/fill.gif) |
> swapping the y and z elements around do what you want?
Now I've resorted to leaving the coordinates the same and just flipping
the camera around instead,
and I've got everything working like that, but now I'm having problems
flipping a matrix.
So for now I'm just going to leave it like it is and maybe come back to
that later.
![](/i/fill.gif) |
