POV-Ray : Newsgroups : povray.off-topic : Suggestion: OpenCL Server Time
30 May 2026 08:17:01 EDT (-0400)
  Suggestion: OpenCL (Message 43 to 52 of 72)
Subject: Re: Suggestion: OpenCL
Date: 17 Aug 2009 09:05:29
Message: <4a895599$1@news.povray.org>
scott wrote:
>> When some rays hit an object and others don't,
>> you add them to different queues.
> Why add it to a different queue?  All rays that still need to be traced
> (whether they are reflection, refraction, primary or shadow rays) simply
> need to be intersected with the scene geometry.
I was thinking more along the lines of each surface possibly having a
different code path for computing illumination. Rays in the same bundle
can't take different code paths.
> In that way the GPU will just process as many rays as it can in batches
> until the scene is complete.  The CPU would handle preparing the queue
> at each step, ie removing rays that have terminated and inserting new
> rays for shadows and reflections etc.
Depends on whether you're thinking of running the whole computation on
the GPU, or just the ray intersection tests, or what.
> Of course to be able to do efficient scene intersection on the GPU it
> would probably be best to only allow triangle-based scenes
I see no especial reason why you can't do arbitrary intersection tests
on a GPU. The math isn't that complicated. The only real problem is
going to be trying to run something like isosurfaces, which use adaptive
space division; a GPU probably won't like that. But something like a
Newton iteration should be fine. [That obviously isn't applicable to
general isosurfaces though...]
> and figure
> out some way to store a Kd-tree of triangles efficiently in a texture.
Also depends on whether you're trying to write your code as a shaper, or
use a real GPGPU system. (Such as the OpenCL in the title.)
> Sounds like the sort of thing someone has already done a PhD on :-)
Indeed, that's where I read about the render queue approach. (No, I
don't remember where *exactly*.)
Date: 17 Aug 2009 10:07:07
Message: <4a89640b$1@news.povray.org>
Sure they can, you just have an "if" in the shader code based on some flag
in the ray data.
> Depends on whether you're thinking of running the whole computation on the
Some things I think the CPU still needs to do, like preparing the ray data
to put on the GPU at each step. It is quite hard to write a shader that does
anything other than return one "output value" per "pixel", ie you can't
write a shader that returns a veriable number of rays, the only thing you
can do is return a flag set that means "spawn another ray".
> I see no especial reason why you can't do arbitrary intersection tests on
I was thinking more about how to store the scene on the GPU efficiently, if
you just have a triangle list it is relatively simple.
> The only real problem is going to be trying to run something like
> isosurfaces, which use adaptive space division; a GPU probably won't like
> that.
Nah it's no problem :-)  Modern GPUs don't have any limit on loops or number
of instructions or anything like that.
I think something like a raytracer will be too complicated for a computer to
try and figure out how to put it on the GPU the best way, needs to be hand
coded by an intelligent person :-)
> Indeed, that's where I read about the render queue approach. (No, I don't
Damn.  If you think up *anything* you think is new, you can be guaranteed
that someone else somewhere has already thought of it :-)  The internet just
makes it easy to find that person!
Date: 17 Aug 2009 10:44:09
Message: <4a896cb9$1@news.povray.org>
>> bundle can't take different code paths.
> flag in the ray data.
I was under the impression that all cores in the bunch would have to
take the same branch of the if - you can't have half go one way and half
go the other. (That's what makes it a SIMD architecture.)
I was also under the impression you can have predicated instructions,
however. (I.e., a single instruction that executes or doesn't based on a
condition. But not a whole alternate execution path.)
> data to put on the GPU at each step. It is quite hard to write a shader
> that does anything other than return one "output value" per "pixel", ie
> you can't write a shader that returns a veriable number of rays, the
> only thing you can do is return a flag set that means "spawn another ray".
> if you just have a triangle list it is relatively simple.
Again, depends on whether you're writing a shader, or using a GPGPU system.
>> like that.
> number of instructions or anything like that.
But they don't allow recursion. That's the issue.
>> or use a real GPGPU system. (Such as the OpenCL in the title.)
> computer to try and figure out how to put it on the GPU the best way,
> needs to be hand coded by an intelligent person :-)
...and?
All GPGPU does is allow you to run programs on a GPU which don't
necessarily have to be shaped like shaders. You still have to write the
code yourself. It's just that you don't have to pretend it's
graphics-related even if it isn't.
> guaranteed that someone else somewhere has already thought of it :-)
> The internet just makes it easy to find that person!
I've had the same problem with mathematics my entire life.
Do you know how hard it is to draw a cube made of 8 cubes and measure
all their sides? Do you know how long it takes to expand (x+y)^9
manually, by hand? Do you have any idea how long it takes to figure out
what the pattern is and where it's coming from?
...and then I discover some entry-level textbook that tells me how some
dead guy already figured all this out several centuries ago. AND FOR
ARBITRARY EXPONENTS!! >_<
Why do I bother?
Subject: Re: clipka I'll answer you here...
Date: 17 Aug 2009 12:10:45
Message: <4a898105$1@news.povray.org>
keep diluting/lying yourself, you're doing a great job, keep it up!
Date: 17 Aug 2009 12:13:41
Message: <4a8981b5$1@news.povray.org>
Chambers wrote:
> Saul Luizaga wrote:
>>> No, you didn't even ask a question.
>> news://news.povray.org:119/4a850da7@news.povray.org, check the last
>> paragraph, proves you wrong. Did you liked to be corrected?
> Yes, I do as a matter of fact.  I don't like being wrong.
> ....Chambers
yeah, right.... hahaha
Date: 17 Aug 2009 12:27:34
Message: <4a8984f6$1@news.povray.org>
That would be "deluding", not "diluting".  :-)
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 17 Aug 2009 12:50:42
Message: <ei2j85prd9nij7psofehqd05jhpaqc3e3k@4ax.com>
Like it makes any difference? Just show him where the fluoride lake is.
Regards
Date: 17 Aug 2009 13:41:20
Message: <4a899640$1@news.povray.org>
Most speakers of english-as-a-second-language around here seem to appreciate
learning the right words, is all.
Date: 17 Aug 2009 14:30:53
Message: <4a89a1dd$1@news.povray.org>
LOL
Date: 17 Aug 2009 14:34:02
Message: <uj8j859007galva686s9584t6bpc80fvtf@4ax.com>
Sorry, I thought that you were stoking the fire.
Regards
