![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> ...all of which is true. However, a simple experiment with a wavetank
>> quickly demonstrates that, for some reason that I don't comprehend,
>> large waves won't go through small gaps, and yet small waves will.
>> This is the precise opposite of what you would expect, but the results
>> are clear.
> Hum... I hate to admit this, but it seems you're right: I just hacked
> together a POV-Ray script to simulate a wavetank-kind-of-apparatus (very
> idealized, but still...), initially to disprove your statement - only to
> find that indeed small gaps will not let low-frequency waves pass.
> Changes in gradient will pass through - but not oscillations.
Weird, isn't it?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Tim Cook schrieb:
> clipka wrote:
>> Strictly speaking, there's no such thing as a "pulling" force in air.
> Sure there is. Ever heard the phrase "nature abhors a vacuum"? That's
> a pulling force. Any decrease in pressure in an atmosphere will cause
> molecules to be drawn to the source of the pressure difference.
"Natura abhoret vacui" is a very old misconception. At 0 degrees Kelvin,
nature has no problems with vacuum.
What is commonly percieved as a pulling force of the vaccum is in
reality a stronger pushing force (due to collisions of molecules) from
the high-pressure region than from the low-pressure region. As a matter
of fact, *both* exert a pushing force.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 08/11/09 03:51, Tim Cook wrote:
> Sure there is. Ever heard the phrase "nature abhors a vacuum"? That's a
That's a push, not a pull.
If you dip a straw into a glass of water, and "suck", all you're doing
is forcing your diaphragm to go down a bit, causing your lungs to
expand. This creates a region of low pressure in your lungs, and the
atmospheric pressure *outside* is what will actually push the water into
your mouth - it's a push by the atmosphere, not a pull by you.
Whose cruel idea was it for the word "Lisp" to have a "S" in it?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> doing is forcing your diaphragm to go down a bit, causing your lungs to
*thinks about it* Seems to me like six of one, half-dozen of another,
but then again, centrifugal force is a nonexistent force conjured up to
describe motion in a particular frame of reference, too...from an
outside point of view, the math is easier/makes more sense when you
reduce everything to a single set of common elements with no overlap.
But having a word for 'suck' is handy for us lay-people--lets us
describe life in a shorter phrase than "region of low density of
pleasantness at self causes misfortune to be pushed onto me", as "life
sucks".
Tim Cook
http://empyrean.freesitespace.net
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 11 Aug 2009 21:39:33 -0400, Tim Cook <z99### [at] gmail com> wrote:
>"life sucks".
No! Death pushes ;)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Oh sure. If your goal was just to have simple models, then your
interpretation is fine (and even more accurate than centrifugal force).
Note that I didn't say there _isn't_ a force on your part. Pulling down
that diaphragm requires force - about the same amount of force that the
atmospheric pressure applies to push the air in.
Same as a vacuum cleaner. The mechanism requires a force/energy to
*push* air out from the back. This causes a vacuum and atmospheric
pressure then pushes the air into the tube from the other end - taking
the mess along with it.
Well, I didn't imply you don't suck (no pun intended).
Just think of the process of moving that diaphragm down as sucking
(which it is).
If Wile E. Coyote had enough money to buy all those Acme goods, why
didn't he just buy dinner?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 08/12/09 06:59, Stephen wrote:
> On Tue, 11 Aug 2009 21:39:33 -0400, Tim Cook<z99### [at] gmail com> wrote:
>> "life sucks".
> No! Death pushes ;)
Obligatory:
http://www.theatrecrafts.com/humour_darksuckers.html
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 12 Aug 2009 09:38:55 -0500, Neeum Zawan <m.n### [at] ieee org> wrote:
>>> "life sucks".
>> No! Death pushes ;)
>Obligatory:
LOL
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A sound wave can be diffracted, this helps it to travel.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Actually, it does. It like big vacuums better than small vacuums, tho.
http://en.wikipedia.org/wiki/Casimir_effect
"We'd like you to back-port all the changes in 2.0
back to version 1.0."
"We've done that already. We call it 2.0."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
