POV-Ray : Newsgroups : povray.off-topic : Arrrgh Server Time
15 May 2026 15:08:48 EDT (-0400)
  Arrrgh (Message 1 to 9 of 9)
Subject: Arrrgh
Date: 23 Jul 2009 09:55:20
Message: <4a686bc8@news.povray.org>
This is why there is a burn-in period for new hardware...
New MB decided it didn't want to boot anymore. Rebooted after adding
software: System would beep, The MB logo would show, screen would blank,
system would beep, the MB logo would show, screen would blank ...
Pulled 1 memory module, same thing
Swapped memory module, same thing
Unplugged drives, same thing
Shorted CMOS reset jumper, same thing
Unplugged power cable, wait 30 sec, plug in, same thing
Called Gigabyte support, rep did all of the above plus
Unplug keyboard, same thing
Remove CMOS battery wait 30 sec, replace, same thing
Support rep concluded "Dead Board, here's our website for RMA"
crap.
~Mike
Subject: Re: Arrrgh
Date: 23 Jul 2009 10:03:02
Message: <4a686d96$1@news.povray.org>
Didn't you mention that the PSU you were using was a bit on the low side for
your hardware?  Maybe the CPU and GPU combination all firing up to max at
boot is enough to reset the PSU?
If you haven't already boxed it up, maybe you could try with an older 3D
card that isn't as power hungry...
Just an idea.
Subject: Re: Arrrgh
Date: 23 Jul 2009 10:41:36
Message: <4a6876a0$1@news.povray.org>
> for your hardware?  Maybe the CPU and GPU combination all firing up to
> max at boot is enough to reset the PSU?
It is, but within range for the requirements, just not a lot of
headroom. Using the same graphics chipset with the older processor
worked fine.
Watching the voltages in Speedfan when the system was running show no
fluctuation, even when running processor and GPU heavy software. The
system appeared stable otherwise.
I did at one point have everything unplugged from power except the GPU
and fans, and motherboard; no drives or external devices.
I wouldn't think the GPU would cause high demand without being
instructed to run 3D.
Maybe I'll walk the board down to the local shop and have them test it out.
I did some reading on the issue I'm seeing, and it seems as if it's
likely a bad board, many people who have this board have encountered the
same problem.
My older 3D card is AGP, this board uses PCIe... ;)
~Mike
Subject: Re: Arrrgh
Date: 23 Jul 2009 11:05:00
Message: <web.4a687b342baf2684aca5323b0@news.povray.org>
Bought a new AMD machine as a secondary (to run time-consuming renders on) a few
months ago:
- Hooked it up to the VGA input of my 2-year-old 19" LCD; never used that input
before IIRC, just the DVI; had the computer run overnight, to wake up the next
morning to the smell of fried capacitor: LCD dead, after using the VGA input
for only a couple of hours.
- Only a few days later (using a spare 15" LCD meanwhile), computer fails to
boot up: Cannot find operating system; mainboard still detects that there is
*some* SATA device connected, but fails to make out any details; swapping SATA
ports with the CD/DVD drive (which was detected ok) doesn't change a thing:
Hard disk electronics dead, after only a few days.
Subject: Re: Arrrgh
Date: 23 Jul 2009 14:47:27
Message: <4a68b03f$1@news.povray.org>
Was it the monitor that took out the computer or the computer that took
out the monitor?
~Mike
Subject: Re: Arrrgh
Date: 23 Jul 2009 22:29:04
Message: <4a691c70$1@news.povray.org>
>> blank, system would beep, the MB logo would show, screen would blank ...
> Just an idea.
Well, at the advice of some people on the support forums, I decided to
try the board outside of the case, with nothing but the monitor and
keyboard connected.
Worked perfectly...
I'm wondering now if the USB hard drive that was plugged in was causing
it to reboot itself. The cable has been a bit dodgy lately, and I
noticed it flaked out a bit on the old MB, vista complained about it
being an unknown device... so, maybe that was it... <shrug>
Vista stayed activated. Neat-o.
Subject: Re: Arrrgh
Date: 24 Jul 2009 03:58:19
Message: <4a69699b@news.povray.org>
So.. You actually did plug out the internal hard drives etc, but not the
external one?
-Aero
Subject: Re: Arrrgh
Date: 24 Jul 2009 11:45:00
Message: <web.4a69d66f2baf26846e32850e0@news.povray.org>
> out the monitor?
In all likelyhood it were independent acts of suicide.
I was a bit worried that the computer might have fried the display, but they
gave it some thorough checking at the shop and found no fault. As both display
and hard disk were replaced free of charge, I also had no reason to try find or
construct any connection between the two events.
Subject: Re: Arrrgh
Date: 24 Jul 2009 12:34:39
Message: <4a69e29f$1@news.povray.org>
> external one?
<sheepish> ehmmm.. rrrright. Didn't stop to think the external USB
device would have any effect on whether the system would boot or not.
~Mike
