On 07/22/09 05:21, Warp wrote:
> Invisible<voi### [at] dev null> wrote:
>> IME, programs written in C are almost always unreadable. But I'm biased. ;-)
> Your problem is that you refuse to aknowledge readability even for examples
> which clearly are, probably because of some principle.
Well, just because C is more readable than Haskell doesn't mean it's
readable.<G>
If David is still reading, I can sympathize with him being scared of
OOP if he was introduced to it via C++ or Java. Constructors can be a
pain in C++, along with other problems. I'd suggest some "simple"
language like Python where the syntax won't get in the way of
understanding the OO principles.
When the lion was given his courage, he promptly ate up the Wizard,
Dorothy, the scarecrow and the tinman.
On 07/22/09 04:13, David H. Burns wrote:
> I was told I was off topic in the programming group -- or maybe it's
There's a newsgroup for discussing ideas about POV-Ray 4:
povray.pov4.discussion.general
/ \/ \ u e e n / \/ a w a z
>>>>>>mue### [at] nawaz org<<<<<<
anl
Invisible <voi### [at] dev null> wrote:
> >> I see. So you still have to manually define what needs to be linked somehow?
> > How else is the compiler going to know which files are your source files?
> > By reading your mind?
> Well, that's what I was puzzled by, yes. You guys seemed to be
> suggesting that you just give VS a bunch of files and it somehow "knows"
> how to produce a runnable executable out of them.
Well, that is how an IDE works. You give it a bunch of source files and
it knows how to create a runnable executable out of them.
> > That's what dynamic linking is all about. That's why they are called
> > "dynamically linked libraries". The OS performs runtime linking when the
> > program is launched: It goes through the program and sets jump addresses
> > to their proper values.
> This implies that an executable file contains some metadata in addition
> to the executable machine code itself.
That's correct.
Well, certainly you give it a bunch of files and it knows how to compile
them. But do you want it to link them all into a single executable? Or
maybe two seperate executables? Or perhaps you're trying to produce a
DLL? Presumably you have to configure this somewhere...
> That's correct.
Interesting. I thought it was only object files that contain linker
tables...
Mind you, having just said that... various programs have custom icons
and so forth. That's definitely not executable code. Hmm...
[Now the old MS-DOS *.com files really *are* just bare machine code,
always loaded at a specific machine address...]
Invisible wrote:
> 1. How does it know which files depend on which other files?
Trivially, it compiles the file and sees which other files it opens during
the compilation. With GCC, you can even give a command-line parameter to
generate a makefile from the compilation. (-M or some such)
> 2. A header file is what defines what can be accessed from outside a
> given source file. Without a header file, how do you determine what's
> supposed to be public and what isn't?
No. You're thinking that header files are part of the language or something.
It's just a convention. If you're accessing something outside of the file
you're compiling, you declare it "extern". It's convenient to put the
"externs" in a separate files, but it isn't necessary.
> (C is a lot simpler, it's
> just astonishingly easy to shoot yourself in the foot with it.)
Yes. Maybe you should try something intermediary first, like C# or Java or
Pascal or some such.
"We'd like you to back-port all the changes in 2.0
back to version 1.0."
"We've done that already. We call it 2.0."
> something. It's just a convention. If you're accessing something
> outside of the file you're compiling, you declare it "extern". It's
> convenient to put the "externs" in a separate files, but it isn't
> necessary.
I see...
I know a header file can theoretically contain anything. But I always
thought that the idea was to put only public things in a header file,
because if it's not in the header file, other files can't know it exists
so it can't be accessed.
>> (C is a lot simpler, it's just astonishingly easy to shoot yourself in
>> the foot with it.)
> or Pascal or some such.
Java and Pascal I already have quite extensive experience with.
(Although I imagine since the last time I touched Java the APIs have
been changed *again*. Oh, and I hear they kludged in generics?) Both of
these languages know the difference between a pointer and an array, however.
Invisible wrote:
> True. But presumably if you #include a file that defines a function
> prototype, you also need to compile and link whatever file it is that
> contains the source code for that function?
Nope. Only if you actually call the function. Don't confuse dependencies on
source files with dependencies on library files.
> (Except for the OS header
> files; I have literally *no clue* how that works...)
Exactly the same way, except the compiler by default knows where to look for
those libraries.
If you want two separate executables, you create two separate projects.
(In most IDEs you can create multiple projects inside one single "solution",
as Visual Studio calls it.)
If you want to build a DLL, you tell it that in the project settings.
Neeum Zawan wrote:
I am still reading and enjoying.
David
> somehow?
Lets just say I'm working with source files right now where the line used to
compile the file takes up more than one screen of text in the editor.
> - You write foo.c that contains a function called foo().
OK. A function *definition*.
> - You write foo.h which simply states that a function called foo()
> exists somewhere.
A function *declaration*.
> - main.c does a #include "foo.h"
Which is exactly the same as if you had copied the text of foo.h into main.c.
> - When main.c is compiled, it produces main.o, which contains several
> references to a foo() that should exist somewhere, but we don't know
> where yet.
No. Only if main() actually calls foo().
> - The linker takes main.o and foo.o, and replaces every jump to foo()
> with a jump to an actual machine address. The resulting program is
> actually runnable.
Sort of. That's called "linking." Then there's "loading", which is when you
put it into memory and *again* adjust a bunch of addresses.
> What I can't figure out is what happens if foo() is actually a function
> somewhere in the OS kernel.
It isn't. The read() function in C, for example, is in the C runtime library
(glibc or uclibc on Linux). The linker always searches that library as part
of the linking process (unless you're doing something funky like compiling
the kernel). The read() function in that library is written in assembler
(because C is really not very useful for this sort of work) and that
assembler code copies items off the stack into machine registers and then
invokes an assembler instruction that causes the CPU to set certain flags in
the CPU registers that control permissions, change memory maps, and
eventually winds up branching to a particular address in memory which the
kernel has previously set to be a branch instruction to the code to handle
read(). So read() is normal, except it's in a library the compiler always
searches and contains assembly language.
> Presumably in each version of the kernel,
> the base address of this function is going to be different... so how the
> hell does the linker know what it is?
It doesn't. It executes a machine-code instruction that's essentially a
software interrupt. (That's why you see things like DOS functions being
described as "Int 21h" functions.)
It's an instruction that invokes an indirect branch.
> The way this works on the Amiga is that you can't just *call* an OS
> function.
There's no memory protection or kernel mode on AmigaOS. It can't be multiuser.
> Like, if aux.c contains foo(), bar() and baz(), which of these should be
> available from elsewhere? Normally if you only wanted foo() to be
> public, you'd only put foo() in the header file.
Header files are 100% orthogonal to visibility. You're being confused by
convention.
If your program defines foo(), it's visible. I.e., if you write
int foo() { ... }
then foo is visible in any source file holding that text.
If you write
extern int foo();
then foo is visible in any source file holding that text, but if you invoke
it, you need to define it (see above) somewhere at link time.
That's your two choices.
When you actually call foo() from inside some other function, it has to be
visible. (Actually, the C standard says it gets a default declaration, but
nobody relies on that, because it was such a bad idea.)
> (And for God's sake
> remember to update the header file when foo() changes its type signature!)
And for God's sake, remember to include the header file where you invoke it.
It hasn't anything to do with header files. You could build a whole OS with
no header files. But if you changed the defintion of foo(), you'd have to
find every file with an "extern int foo()" and change it to "extern long
foo()", which is why people put them in include files.
Chambers wrote:
> This is similar to Java, although it is
> not platform independent (there is a platform independent open source
> version, called Mono, which is able to execute many .Net applications).
Actually, the CIL is indeed platform independent. What isn't is a large
number of windowing libraries and a few others that are per-OS, primarily
because you *can* get to some low-level stuff. There's virtually nothing in
the definition of the libraries or language that would be difficult (as
opposed to tedious) to implement on other OSes. Of course, if you do things
like inspect the Windows message pump, or you query the X server's WM
properties, you're going to have unportable code. A Windows service is going
to have different wrappers than a Linux service, because the two have
fundamentally different operational mechanisms. *That* is where the
non-portability bits come from. Well, that and that it hasn't been ported
too much yet.
> There are other technologies and features, of course, mostly aimed at
> interoperability of various system components (for instance, LINQ, which
> allows SQL-type queries from languages such as C# and VB).
There's also a tremendous focus on being able to use different parts of the
systems from different vendors. The whole bit of managing "components" is
that. So if you don't want to write it and it doesn't come with, chances are
good you can buy it already built for you.
Yes. That's what the separate "projects" in one "solution" are, in VS.
Sure. You set flags on the project properties pages.
> tables...
Depends on the OS and CPU. For example, on CP/M, you're right. The binary
.COM file is just bytes of machine code that load at 0x100, and the OS jumps
to 0x100 when it starts. That's responsible for setting up the stack (based
on an address left in global memory) and parsing the command line (at 0x80).
On even simple UNIXes, you have things in the headers to set up how big the
stack is, how big the "zero out this memory space" area is, and which
addresses have to have the start address where you loaded the executable
added. Any OS taking advantage of memory protection is going to have
metadata in the executable format.
Yep, that too.
Yes, left over from CP/M.
No, it's so that there's only one place to change it when you change it. The
same reason you'd use an "include" in any other language or document or
whatever.
If it's not declared, you can't easily use it from outside where it's
defined. One declares it in a header file so one doesn't have to type it out
all the time or risk getting the declaration wrong.
However, sometimes when I'm debugging stuff that's just breaking deep in the
bowels of someone else's program, I'll do something like
{ extern int write(int,char*,int); write(1,"#1\n",3); }
just to put in a debugging line to tell me whether it crashed before
or after that point, which prevents me from having to #include the
right pile of header files to declare write() properly.
> however.
True. C doesn't have arrays, really. At least, none with actual names.
So you have a lot of experience with Java, and you find *C's* syntax unwieldy?
Actually C *does* have arrays. For example, this is an array:
int table[10];
Here 'table' is *not* a pointer to a memory location containing space
for 10 ints. 'table' is an array of 10 ints. While it behaves a lot like
a pointer (and is implicitly cast to an int* when necessary), there are
significant differences compared to a pointer. For instance, sizeof(table)
is not the same as sizeof(int*). Also, you can't make 'table' "point" to
somewhere else (because it's not a pointer).
These are stack-allocated arrays. It is also possible to create
heap-allocated arrays, although not directly. You have to enclose it
inside a struct, like this:
struct ArrayContainer
int table[10];
Here 'table' is also *not* a pointer, it's an array. Now you can allocate
instances of that struct with malloc() and you will effectively have a
heap-allocated array.
(Granted, C arrays are a bit rigid and non-dynamic, but they are still
arrays by any definition.)
Warp wrote:
> For instance, sizeof(table) is not the same as sizeof(int*).
Yes, OK.
I thought "table" was essentially a constant pointer to the first element. I
forgot about the sizeof() bit. I.e., that "int table[10]" made table be a
constant pointer to the first element of an anonymous block ten integers in
size.
int* table = malloc(10*sizeof(int));
creates an anonymous array, then sets "table" as a pointer to the start of
it. So you can have heap-allocated arrays, you just can't give them names. :-)
Now we're picking nits, tho. You're right, C does have arrays.
The other difference is that there's no way of retrieving the size of that
"array".
On 22-7-2009 10:39, Invisible wrote:
> clipka wrote:
>> Once you've embraced the OO paradigms, you'll no longer wonder whether
>> it's a
>> step back or sideways - you'll know that it's a step forward.
> This is where I mutter something about functional programming being the
> future, and everybody agrees with me...
Nah, it was a long tome ago when these were the future (roughly between
'54 and '58).
On 22-7-2009 1:26, David H. Burns wrote:
> andrel wrote:
>> That you see your smiley does not mean everybody else will.
> Thanks. Did you see it? I did when I read my own post. I don't think it
> shows up in the text in
> my "sent" file. These matters get complicated.
> :) (smiley ?)
I do. In your post, not when replying :) , neither yours nor mine.
The point I tried to make earlier is that it depends on the mail reader
of the person *reading*. You don't have an influence on it. You type a
colon followed by a bracket, that is what you sent and what is supported
by NNTP. After that somebody is trying to cleverly replace them by
rotated smileys, which is OK as long as they get it right :/
IIRC they have problems with exotic ones like \o/ perhaps because they
can conceivably be in a real post or in /ASCII art/.
In short, there is a big chance that what you will see is not what I
wrote. Perhaps it is what I intended.
On 22-7-2009 11:13, David H. Burns wrote:
>>> (Laugh) I love it! What can be off-topic to off-topic? What you mean, I
>>> think, is that
>>> this topic is forbidden! Or maybe simply unwanted.
>> On-topic. Your conversation is clearly about Pov-RAY, so it would
>> naturally fit onto the on-topic groups better than to shit-chatting
>> off-topic group :-).
>> -Aero
> just what
> I say, or how I say it, not the subject that's off-topic. But my critics
> are right;
> I don't know enough detail to really discuss OOP.
That did not stop other people here to start a lot of threads. ;) So,
welcome. Take a seat, relax and try to find a role in this bunch of
looneys. AFAIK we don't have an on-topic poster here yet, so if that is
what you like...
> I just voice my objections which apparently aren't shared.
They are to a certain extendthey are. The main problem though, apart
from this being the wrong group is that you restarted a useless
discussion for the 42nd time.
"David H. Burns" <dhb### [at] cherokeetel net> wrote:
> > Yes, I personally do advocate going for strong OOP-support with POV-Ray 4 SDL. I
> > do so as a POV-Ray user, and I do so as a contributing developer.
> > Yes, I did present a serious proposal for a new, OOP-enabled SDL in the povray 4
> > newsgroup some months ago.
> > Yes, being active in the development of POV-Ray 3.7 I *may* happen to personally
> > get my hands dirty on the code of POV-Ray 4's SDL engine.
> So it is so after all
So it is *what* after all? Me single-handedly going to take over the world or
what??
Mwahahaha - Yeeees - I've always wanted to do that...
Ah, BTW & FYI: Me being a contributing developer to POV-Ray doesn't mean that
I'm member of the official dev team. I do contribute code now and then, but as
for making decisions about which direction to go, the buck does *not* stop
here.
> > Once you've embraced the OO paradigms, you'll no longer wonder whether it's a
I have the uncanny feeling that in some years from now I might even agree with
you... >_<
> The question is... are any POV-Ray "programs" large enough to benefit
> from the extra structuring? I believe the answer is yes, but it's
> somewhat debatable.
I'm quite sure they are - provided we count in a nice set of standard data
containers (variable-size arrays, stacks, queues, lookup lists aka associative
arrays, and maybe some more geometry-oriented like BSP trees, octrees or the
like), and don't want to code them all "hard" into the language or want to stay
flexible for users adding their own (graphs as you might need for physics
simulations, just to give one example of where one could go).
Not quite true: They could be loaded at any segment address... OS calls would be
done via invoking INT 21h with particular register values though, if that's what
you mean.
On Wed, 22 Jul 2009 04:05:45 -0500, David H. Burns wrote:
> but it
> apparently allows,
> maybe encourages, writing code so complex as to be almost
> undecipherable.
Google "IOCCC" for some wonderful examples of this. ;-)
Jim
Why, anything that's on-topic, of course. ;-)
Jim
On Wed, 22 Jul 2009 07:00:37 +0300, Eero Ahonen wrote:
> shit-chatting
Wonderful faux pas. ;-)
Jim
>> it shows up in the text in
>> :) (smiley ?)
Thanks, again, Andrel. The smileys work, :/ and \o/ came through as the
Ascii characters.
I'm using Thunderbird.
David
> Jim
Obviously, but I hadn't thought of it that way.
David
Invisible wrote:
>> it's a
There is still some debate about that, of course :)
For one, OOP more closely models how many people think of problems,
while functional programming more closely models how mathematicians
think of problems. It is not yet clear which one is better for managing
large, complex programs in general (especially since there are many
things a computer does that are still more closely aligned with
imperative programming. These things are easier to wrap in OOP, which
has concepts for both data and actions).
Chambers
clipka wrote:
> the buck does *not* stop here.
Shouldn't that be "the Buck"? ;)
Chambers
andrel wrote:
Unfortunately, it seems to be in the nature of things that useless
discussion drag
on and recur while the useful ones appear only once for a moment. But
this one hasn't
been entirely useless to me. :)
scott wrote:
> A lot of people just find it makes more sense to
> have one file that neatly shows the interfaces and another to actually
> contain the implementation code.
In fact, one of my biggest complaints with C# is the lack of class
prototypes. I miss having a public interface which fits entirely on one
(maybe two) screen(s). Somehow, it seems to make things easier for me.
Chambers
>> Jim
That's perfectly OK - I was just kidding around, had hoped the smiley
would tip that off. ;-)
Jim
> function. First you have to look up its base address in a table.
> Basically, memory address 0x00000004 contains a pointer to a table. Every
> OS function has a unique ID which is an offset into this table, which
> enables you to lookup the function's base pointer. And then you can jump
> to it. All of which takes about two-dozen assembly instructions...
On the Acorn there was an instruction called SWI (software interrupt) for
calling OS and other module functions. In the assembler it took a number or
a string as a parameter (the assembler converted the string to the correct
number), which defined the specific function you wanted to call. I assume
when the CPU got to the SWI instruction it jumped to a few lines of OS code
which figured out where to actually jump to execute the instruction.
When you loaded "modules" to the OS (they were like services under windows)
each module could register some functions with the OS. Then you could call
them with the SWI instruction. It was pretty easy to use.
You could easily hack the system though by redirecting the interrupt handler
to your code, calling the real OS handler, then passing control back to the
calling program. Of course in your code you could then check for certain
functions (like reading the contents of a folder) and modify the results :-)
I know in German you use a capital letter for every noun, but in English
it's usually just for names.
>> somehow?
> used to compile the file takes up more than one screen of text in the
> editor.
Yes. For some reason, this seems to be mandatory in all Linux
development. I'm not sure why...
>> where yet.
One assumes that if you don't need foo(), you wouldn't bother including
the header file. But sure, if the header declares a few dozen functions;
you might not call every single one of them.
>> actually runnable.
> you put it into memory and *again* adjust a bunch of addresses.
Right. So what you're saying is that there's actually a second linking
stage each time final executable is run?
>> function somewhere in the OS kernel.
> library (glibc or uclibc on Linux). The linker always searches that
> library as part of the linking process (unless you're doing something
> funky like compiling the kernel). The read() function in that library is
> written in assembler (because C is really not very useful for this sort
> of work) and that assembler code copies items off the stack into machine
> registers and then invokes an assembler instruction that causes the CPU
> to set certain flags in the CPU registers that control permissions,
> change memory maps, and eventually winds up branching to a particular
> address in memory which the kernel has previously set to be a branch
> instruction to the code to handle read(). So read() is normal, except
> it's in a library the compiler always searches and contains assembly
> language.
In summary... you can't call the OS from C. You can only write C wrapper
functions around the assembly code that calls the OS. (And the wrapper
then of course looks like a normal C function...)
>> Presumably in each version of the kernel, the base address of this
>> function is going to be different... so how the hell does the linker
>> know what it is?
I see. So that's the mechanism on the IA32 platform, is it? (I thought
only the BIOS uses this method...)
>> function.
> multiuser.
Interestingly enough, the Motorola 68000 does in fact have two modes of
operation: "user mode" and "supervisor mode". I have no idea what the
distinction is.
Additionally, the factory-standard Amigas had the "EC" version of the
Motorola 68000 CPUs which lack an MMU. You can, however, replace this
with a version of the CPU that possesses an MMU. Indeed, several
companies offered the add-on boards, together with the necessary
software to extend AmigaOS to support virtual memory. This suggests that
the MMU-enabled variant of the CPU could support memory protection if
you wanted.
And finally, it's perfectly possible to make a multiuser OS without
memory protection. It just won't have any memory protection. (Meaning
one rogue program can crash the whole system.) Arguably not very useful,
but completely doable.
> what??
That's what it sounds like, the Pov-Ray world anyway. You've greatly
increased my paranoia.
Any day now I expect the carpenter's union to redesign and rebuild my
house not for
convenience or comfort but to teach me the current accepted practice in
carpentry.
> here.
Despite my concerns, I do appreciate all the work that the official and
unofficial
of Pov-Ray have done over the year --excellent work for my part.
David :)
> think of problems.
??!! Though the second clause of this sentence seems true to me, nothing
that I have read or heard in a long time seems so obviously false! It
makes
me wonder if I'm communicating with an entity of a different a species
or even
a different genus! (Is there an exclamation or ??!! icon?)
David
>> the future, and everybody agrees with me...
That was actually sarcasm. ;-)
> think of problems.
Depends who you think you're aiming your programming language at.
> large, complex programs in general.
People who use Haskell casually build interpretters, compilers, logic
simulation systems, and other things usually thought of as "hard" in
normal programming languages. Whether this is to do with Haskell or the
sort of people who use Haskell remains to be seen of course... ;-)
One might ask when computers will start to be designed to operate in a
more functional way...
> house not for
> carpentry.
Even if POV4 does change to an OOP model that you don't like, a) that is not
going to be released for decades, and b) you are free to still use the
latest stable 3.x release. I wouldn't worry about it.
> > think of problems.
And exactly what is it that makes it false?
Object-oriented programming closely matches the thought process of people.
OOP can be deconstructed into to most basic elements: Concepts and algorithms.
People think about things conceptually. For example, you can have one pen,
one car, one dog, and so on.
Moreover, people use hierarchies of concepts. Some concepts are more
abstract while other concepts are more concrete. For example, the concept
of "animal" is more abstract than the concept of "dog" or "cat", which are
more concrete. Moreover, there's a hierarchical relationship between these
concepts: A dog is an animal, and a cat is an animal (but a dog is not a cat).
Concepts can have properties to them. For example a dog has color, weight,
gender, race, etc. These properties can be different for different dogs.
Likewise the concept of "book" can have many properties, including its title,
author, date of publication, cover picture, table of contents, and so on
(all of which in themselves are also concepts).
The other basic element of OOP is algorithms. These can be thought in the
same way as food recipes. Food recipes use some concepts (ingredients, cooking
utensils, etc) and a list of instructions on how to prepare the meal.
This is the way people think naturally, and object-oriented programming
simulates this kind of design: It defines concepts (which may be hierarchical)
and algorithms on what to do with those concepts.
Now please explain to me exactly what here is "so obviously false"?
I have hard time believing that large programs written in a functional
language like Haskell don't use one of the basic features of OOP: Modularity.
Modularity (and the abstraction related to it) is one of the most essential
properties of a large project, if you want it to be manageable.
Functional programming sounds to me more like just a way of expressing
what you want to do (ie. algorithms), not how you should distribute your
code among modules. Modularity transcends things like imperative or
functional programming paradigms. You could say it's a metaparadigm used
in many if not most large projects, regardless of the language used.
> that I have read or heard in a long time seems so obviously false! It makes
Perhaps it's because you tried learning OOP from C++/Java?
I'm sure you think in OOP all the time with POV-Ray. You create a
sphere. It's an object with certain properties (texture, location, etc).
Now let's say you want to rotate the sphere, does it hurt so much to do
something like:
mysphere.rotate(45)
Let's say you want to have lots of balls in your scene. You want some
to be red, some blue, and some green. And some of _those_ you want to be
translucent.
So you create your "basic" ball as a sphere with little texture. You
subclass it to create two kinds of balls: "solid" and "translucent". In
terms of actual code, you just create a new object that is the subclass
of your "basic", and you merely add to it the texture that makes it
translucent.
Then you can subclass each to get the red, blue and green balls.
No, Taco Bell is NOT the Mexican Phone Company!
> house not for
> carpentry.
Try lying in front of the house when the bulldozers come. And if you
see someone coming along hugging a towel, become friends with him.
Otherwise your life will be in danger.
And not because of the bulldozers.
*I* don't think, naturally or otherwise, like any OOP programming I have
seen!! You may be trying to
read your on programming philosophy onto the world, or we may be of
different genera. :)
David
> something like:
> mysphere.rotate(45)
No! I think in terms of objects, not of OOP. The concept of an "object"
as used
in Pov-Ray in a valuable tool for thinking and programming -and used
well there.
What I have seen of OOP programming is something else. :)
David
You clearly don't understand what "object-oriented programming" means.
Then you come here to tell us that you don't want it, whatever it might be.
Clearly you haven't. You don't even understand what "object-oriented
programming" means.
I think it's more like how people categorize real-world stuff. Since a lot
of programming is essentially simulating the real world, OO makes sense.
There's a bunch of things that go on in the real world that don't make sense
to do with OO: expert systems, board game AIs, financial analysis,
accounting, etc.
There's a bunch of things that make sense with OO: Windowing system,
interactions between businesses and customers, etc.
To say "people think in OO" is to miss that in many situations people don't
think in OO.
I would say this is *A* way people think naturally. Something as simple as
a decision table or decision tree is another way people think naturally.
