POV-Ray : Newsgroups : povray.off-topic : Tell me it isn't so! Server Time
1 Jun 2026 15:52:03 EDT (-0400)
  Tell me it isn't so! (Message 331 to 340 of 473)
Subject: Re: Tell me it isn't so!
Date: 28 Jul 2009 11:40:50
Message: <4a6f1c02$1@news.povray.org>
Warp wrote:
>   The reason why languages like C++ don't come up with libraries which would
> be handy (such as graphics and sound) is complicated.
Actually, for graphics and sound and other ubiquitous stuff like that, it's
not all that hard to come up with a decent library. Win32, X, etc all fit
the bill.
My rant was more along the lines of higher-level stuff. Take, for example,
an HTTP client library. You would think it's straightforward, but how do you
allocate memory such that it's easy to free? (C++ solved this problem,
obviously, which is one of the big wins for C++ libraries over C libraries.)
How do you open a socket? How do you hash passwords for DIGEST
authentication? How do you keep from blocking on DNS lookups? Each of these
libraries has layers and layers under it, and nobody wants to redo all those
layers using only the standard libraries.
So the solution is to make the standard libraries bigger, and you start
getting things like Java and C#, which nobody wants to use because the
standard libraries are too big. :-)
I did read and understand the rest of your post, but I guess I wasn't really
clear in my late-night rant as to what I thought the problem was.
>   Also such library would be highly non-portable. For example, if the C++
> standard dictated some kind of GUI library, how would you implement it eg.
> for the iPhone? You just can't. This would mean that for such systems you
> would have to use a crippled version of the language which may or may not
> compile some existing code.
Exactly! That's what I'm getting at. If it's not in the standard library,
then two chunks of code both wanting to do graphics are going to have
trouble working together. I want to play a video in a web page, but the web
client uses Qt and the video uses X, or something like that.
If it *is* in the standard library, then you either get something like "it
won't run on an iPhone" (say, .NET) or you get one "the standard library is
too big to fit on your hardware."
The most recent solution seems to be to put a layer of interpreter on top of
everything, using DOM and javascript as a graphics layer for your application.
>   A standard library to play sounds would run into similar problems,
Here I think a framework would probably be sufficient. Unlike graphics,
programs don't seem to generate from scratch too many types of sounds. It's
mostly format-independent stuff, like "read a file and play it", or "here's
a gunshot that should sound like it's 20 feet away and off to the left a
bit" or some such. When they do generate from scratch (synthesizers, sound
editors, etc) they can use a decent open sound format and convert it when
they're done.
The problem here is layering it on top of other libraries. How do you
prebuffer the sound? What version of select/poll/threads/etc are you using
if you're pulling sound off a network connection? What standard are you
using to timestamp sounds so you can lip-sync to the video of the person
talking?  If you want to build software to (say) play video (my current
bugaboo), you need all those things underneath first, and since they're not
standard, you can't mix-and-match the sound system with the video
decompression system with the content negotiation system with the DMA system
with the networking system.
These aren't hard problems to solve. The problem is they've been solved over
and over, and if you're trying to put multiple pieces of code together,
you're going to run into incompatibilities in the lower layers. Exactly like
with the graphics: the problem isn't that windowing systems are hard, but
that there are so many to choose from, and programs for one won't run on
others, even tho a simple adaption layer could make it work. But then
everyone writes their own adaption layer, and then you get adaptors between
the adaptors, and you get layers and layers of abstraction, all of which are
unnecessary for simple tasks but none of which you can throw away once it's
in the mix.
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 28 Jul 2009 12:00:00
Message: <web.4a6f2031ac52dfd4b533f5a90@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Darren New wrote:
> > That's one solution, but not really because of the memory. The Amiga had
> > only 128K or 256K, and it handled clipping windows and saving the
> > clipped parts elsewhere just fine.
> Which model? I don't recall seeing one with less than 1MB RAM.
The original Amiga 1000 came with either 256K or 512K memory.  I had one of the
256K models.  A pretty amazing machine for it time.
Isaac.
Date: 28 Jul 2009 12:13:12
Message: <4a6f2398$1@news.povray.org>
Amiga 1000. From wikipedia
"Machines began shipping in September with a base configuration of 256 KB of
RAM at the retail price of 1295 USD."
Which fits my memory. I think the 500 had 128K? It wasn't a whole lot, but
the Amiga made efficient use of it.
Date: 28 Jul 2009 12:25:00
Message: <web.4a6f2566ac52dfd4dcf616650@news.povray.org>
> >> I am 75% sure that the C64 would *automatically* indent your code. As
> >> in, if you wrote a FOR-NEXT loop, the loop body would automatically
> >> appear indented, and there was nothing you could do about it.
> > I'm 99% sure it did *un-indent* the code no matter how hard you tried... (just
> > googled for a few C64 BASIC code snippets, and found them all not indented)
> Hmm. Perhaps it was the Sinclare Spectrum then...
Code snippets on the internet indicate otherwise. Next try... :)
(Hint: It wasn't the Amstrad CPC either; I don't know of any home computer that
had an auto-indent feature.)
Date: 28 Jul 2009 12:40:00
Message: <web.4a6f2988ac52dfd4dcf616650@news.povray.org>
> only 128K or 256K, and it handled clipping windows and saving the clipped
> parts elsewhere just fine. I suspect it was more a question of (a) amount of
> effort put into the graphics layer and (b) the fact that there was no
> hardware accel for Windows boxes so redrawing from scratch was probably
> close to as fast as blitting the saved window anyway.
Typically, yes. After all, in those days of Windows 3.1 (and earlier), windows
were just solid-filled rectangles with a border around, and buttons likewise.
Having a dedicated blitter chip made the approach much more worthwile. And I
guess the Amiga only had it because it was designed for GUI operation right
from the start.
Date: 28 Jul 2009 12:45:00
Message: <web.4a6f2a04ac52dfd4dcf616650@news.povray.org>
Neeum Zawan <m.n### [at] ieeeorg> wrote:
>  Ever used Fractint on DOS? _That_ program probably supported more video
> cards than any other. The amount of collaboration for that piece of
> software was truly impressive.
Why, yes, of course!
That was a freakin' awesome piece of software in any respect.
Date: 28 Jul 2009 13:00:01
Message: <web.4a6f2e6bac52dfd4dcf616650@news.povray.org>
http://en.wikipedia.org/wiki/Amiga_models_and_variants
allegedly 256K on the A1000.
Date: 28 Jul 2009 13:10:00
Message: <web.4a6f2feeac52dfd4dcf616650@news.povray.org>
Um... what's wrong with malloc() and free()??
Date: 28 Jul 2009 13:45:00
Message: <web.4a6f382eac52dfd4dcf616650@news.povray.org>
It actually had more than the original A1000 (512K), and was released later; but
by that time, memory prices must have dropped enough that they could offer it
for a significantly lower price - hence the lower type designation as it seems.
Date: 28 Jul 2009 13:45:01
Message: <4a6f391d$2@news.povray.org>
It exposes the internals of the memory allocations to the caller. And it's
difficult to manage if you don't have at least destructors. And it can be
inefficient if you do it a lot. And sometimes you need certain kinds of
memory (like DMA-accessible memory) so you wind up with multiple kinds of
malloc and free.
But mostly because it exposes the internals of the memory allocations to the
caller, which is usually less of a problem until you combine it with the
other problems, like threading.
Say you're generating some audio by reading hardware-compressed samples off
a microphone, then shipping it out over a connection that's packetized and
interleaved with other data (RTP, for example).  You don't know how big the
data you're reading is, and you don't know how big the data you're writing
is. One thread is reading from the microphone and filling buffers. One is
coordinating. One is writing the buffers to the socket. Who is responsible
for allocating buffers? Who is responsible for freeing them? Especially
given that the buffers you're writing might not be the right size for the
buffers you're reading.
Sure, you can use malloc and free. But I've seen maybe 5% of the programs
I've worked with *not* layer other memory management stuff on top, and each
"on top" is incompatible with the other "on top"s. You can't read a buffer
from John's DVD reader, feed it into a Python data structure, then take that
and stuff it out to a MPEG decoder hardware interface without copying it
three times. Heck, Qt is written in C++ and it doesn't make use of any of
the STL *or* C strings. You know how you print out the URL stored in a
"QURL" object?  myQurl.toAscii().constData() gives you an actual char* (or
something like that). Because Qt didn't like STL for some reason.
Everyone builds up big abstractions to help. If you have to do it yourself,
you're going to build abstractions suited to the program you're writing. If
you don't have to do it yourself, you have to haul around the whole library
from someone else and keep up with *their* changes.  I think this is a big
part of what the .NET stuff is trying to solve with all the "component" part
of the framework.
