POV-Ray : Newsgroups : povray.off-topic : Nice data structure Server Time
30 Jun 2026 16:02:34 EDT (-0400)
  Nice data structure (Message 16 to 25 of 25)
Subject: Re: Nice data structure
Date: 21 Jun 2009 09:57:55
Message: <4a3e3c63@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Warp wrote:
> >   I suppose that if you limit the size of the data container to 2^24 nodes,
> No, you could use "offsets to next element" or something, too, methinks. But
> yeah, that's kind of the thing I was thinking about. By the time you have
> more than 2^16 nodes, you're probably worrying more about speed, paging, etc
> than you are about raw size, perhaps. And you're going to start to see a lot
> of overlap in the earlier parts of the strings.
  I'd say it's the exact opposite: When you start having more than 2^16
nodes, that's when you need to star worrying about the amount of space the
data structure is taking. With less than 2^16 nodes the size of an individual
node is rather irrelevant.
Date: 21 Jun 2009 10:01:13
Message: <4a3e3d29@news.povray.org>
clipka <nomail@nomail> wrote:
> This would require your data to have a linear distribution.
  No, it doesn't. For an alphabet of eg. 26 characters you need to perform
at most 5 steps per character, period, completely regardless of what the
stored strings are.
  With an unbalanced tree the worst case scenario is that you end up having
to perform 25 steps per character.
Date: 21 Jun 2009 13:38:08
Message: <4a3e7000$1@news.povray.org>
My thought was that if you have that much data, you're probably running on a
machine where the memory limits aren't very tight (i.e., a desktop system,
say).  Of course, the killer is the ratio of the number of nodes to the
amount of memory, so sure, when you start getting up in the 2^25 number of
nodes range the size of the nodes is going to be prohibitive on a 32-bit
machine again.
The nice thing is the tree doesn't need rotations, so you can clip off a
large sub-tree of the tree and put it in its own address space. That's hard
to do if you have to balance nodes and stuff.
   Insanity is a small city on the western
   border of the State of Mind.
Date: 21 Jun 2009 14:27:55
Message: <4a3e7baa@news.povray.org>
> say).
  Well, I may be biased because of my programming history background, but
usually an app crunching tons of data requires space-efficient data containers
(so that it can crunch as much data as possible with a given amount of RAM).
You usually want your app to be able to handle as much data as possible.
  Also my recent programming history can also have some effect on how I view
these things, namely programming for handheld systems. For example, games
which require a full (eg. English) dictionary are an extremely typical case
where you need a very fast data container which should take as little space
as possible (because a handheld system won't have a multi-GHz CPU nor
gigabytes of RAM). A typical English dictionary is excruciatingly annoying
in this regard because they usually go just a bit over the magical limit
of 65536 words, especially if the game requires plurals and other inflected
forms. (And even if the dictionary did have under 65536 words, the total
amount of character data would still be well beyond that limit, and since
words are of differing lengths you really need byte-pointers/indices.)
> machine again.
  Hmm, I'm not so sure. 2^25 nodes, each node taking eg. 16 bytes, would
require "only" 512 MB of RAM, which is well below the capacity of any
modern desktop system.
Date: 21 Jun 2009 17:57:45
Message: <4a3eacd9$1@news.povray.org>
Yeah. My background tends towards needing to crunch arbitrary amounts of
data, and hence I look at data structures that cache to disk more
efficiently. The sorts of stuff I write can't rely on having enough memory
to hold it all, but also tend to assume you're not going to look at all of
it at once (like a database of customers, for example, rather than a game,
where you really want the whole level in memory at once).
Cool. Yeah, I'm kind of impressed, actually. I'm writing code for set top
boxes right now, and the boss has me porting webkit to the machine. He's all
worried about the performance, and I'm saying "maybe you shouldn't have two
layers of interpreted language on top of your 100MHz CPU just to draw your
top-level menus."
Coming from the credit card terminal world, where having 14K of ram was
pretty much top-of-the-line, it's a little boggling to have a whole 128M of
RAM. :-)
Handheld machines are definitely still the cutting edge of resource pain,
tho, yes.  Especially since people expect them to do flashy things
efficiently and cheaply and responsively.  CC terminals need to be quick,
but nobody really cares if you have a 16x4 text-only B&W screen on one.
>> machine again.
Fair enough. It's getting close to the limit of what you can put in one
address space conveniently, is all. (On a 32-bit machine, that is.) Of
course you still have the malloc()/free() space overhead for each blob, and
whatever the rest of the program is doing, and etc.
You can run into limits either way, with small memories or with google-sized
data. With my work, I tend to run into problems with google-sized data,
where the speed of even copying files from one place on the disk to another
is a significant overhead. I can see how if you're looking at it from a game
console or handheld device POV, you can see the space problem in a different
way.
Date: 22 Jun 2009 06:38:26
Message: <4a3f5f22$1@news.povray.org>
Warp wrote:
>   One problem which I see with the tree building algorithm presented there
> is that the tree is not balanced. The geometry of the tree will heavily
> depend on which order you insert the strings into it. A suboptimal insertion
> order will cause the tree to be heavily unbalanced.
As far as I can tell, it's only the letter selection part of the tree
which can be unbalanced. E.g., if you have a million strings, you won't
ever have to do a million comparisons to find a given string. You might
end up doing 25 comparisons per character or something, but you'll never
need to do a million.
(A common optimisation I've seen is to store the shared prefix in a tree
and then any unique suffix is stored all in one lump rather than as tree
nodes. As similar keys are added, the unique lump gets expanded out.
This way, the work is proportional to the size of the shared key prefix,
not the whole key.)
>   However, I can think of a much easier solution which doesn't need any
> rebalancing:
>   Always create every node so that it partitions the alphabet in two equal
> parts.
Assuming the range of permissible "characters" is small and known prior
to starting, sure.
(You might use this algorithm, e.g., with IP addresses as keys, and then
the key string elements aren't characters any more. But hey, if you're
going to use fixed-width binary data, there are better structures
available...)
Date: 22 Jun 2009 10:23:55
Message: <4a3f93fb$1@news.povray.org>
Darren New wrote:
> http://www.pcplus.co.uk/node/3074/
I just implemented it... partial matching and all. ;-)
Date: 22 Jun 2009 12:20:18
Message: <4a3faf42@news.povray.org>
  But if the strings themselves are very long, then it can make a
significant difference whether you have to make 25 comparisons per
character or 5.
Date: 22 Jun 2009 14:26:03
Message: <4a3fccbb$1@news.povray.org>
> character or 5.
Sure. I'm just saying, if the number of comparisons were dependent on
the number of keys, you'd be in a whole other *complexity class*. That
puts "really slow" into perspective.
http://blog.orphi.me.uk/
Date: 29 Jun 2009 14:08:45
Message: <4a49032d@news.povray.org>
...and then somebody on the Haskell mailing list announces that they're
releasing this on Hackage. Go figure!
