![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Isn't it legal to put a class declaration in the same .cpp file where you
define its member functions and the main() that's the only routine that uses it?
When I did that, I got errors about not being able to find the vtable for
the class.
Is #include supposed to work just like a textual include? Is this something
funky with the Qt preprocessing stuff?
Insanity is a small city on the western
border of the State of Mind.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 12 Jun 2009 20:22:16 +0200, Darren New <dne### [at] san rr com> wrote:
> you define its member functions and the main() that's the only routine
> that uses it?
You can put the entire program in a single file if you want.
> for the class.
Possibly some internal compiler problem (which might be triggered by a
syntactical problem in your code).
Yes.
FE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Yes.
OK. I think the problem is that Qt runs the code through a preprocessor for
various reasons, and it was probably not running the .cpp stuff thru, just
the .h stuff.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Yes.
With two minor exceptions:
1) Certain compiler-dependent #pragmas may change the behavior of #include
slightly. The most common one is "#pragma once".
2) __FILE__ will expand to the name of the header file if it appears in
it, rather than the source file where it's #included. Likewise for __LINE__.
Thus if either identifier is used in a header file, its behavior will be
different than if you copy-pasted the contents of the header file to the
source file.
(The exception is if either identifier is used in a preprocessor macro, in
which case they are interpreted only after expanding the macro instantiation.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> the class.
A minimal example code would help a lot answering the question.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Yes.
Good point, thanks! Neither of which was the problem, which seems to be
specific to Qt, which runs its own preprocessors. But thanks for the
clairifications.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> the class.
Yeah. I solved it before I asked the question. I was just trying to figure
out if it was normal C++ stuff or QT stuff. Once I got confirmed that
#include in C++ was essentially the same as in C (modulo leaving off .h), I
went grubbing around QT and figured out there's a macro it only expands in
.H files with the "moc" processor.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> that uses it?
> for the class.
> something funky with the Qt preprocessing stuff?
Perfectly legal.
As far as Qt is concerned... are you running moc by yourself?
You known, qmake uses the HEADERS variable to look for Q_OBJECT classes.
If your private class contains that macro, just try and include the
generated .moc directly.
Something like:
source.cpp:
class my_private_implementation
Q_OBJECT
/* neat stuff */
#include "source.moc"
Jonathan.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I see. No, I'm a Qt newbie. I just worked out this weekend how to compile
something outside of the Qt subdirectories. :-) {To be fair, it's
cross-compiled from a VM to a piece of hardware that doesn't have any
keyboard or mouse, so it's not like it's trivial.}
Cool. It's easy enough to put it in a separate .h file. It just surprised
me. Looking at it, I thought Q_OBJECT was a #define, not some tag for a
separate preprocessor.
You know something else that surprises me? That I can screw up the
compilation enough to get G++ outputting assembler that the assembler
doesn't understand. I can't imagine why I can invoke G++ with arguments
that, in one execution, would compile C++ to assembly, then pass that
assembly to the assembler for the wrong architecture. Weird.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I believe it's both.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
