POV-Ray : Newsgroups : povray.off-topic : Interesting take on C++ vs others... Server Time
23 Jul 2026 03:21:32 EDT (-0400)
  Interesting take on C++ vs others... (Message 13 to 22 of 22)
Subject: Re: Interesting take on C++ vs others...
Date: 3 Jun 2009 21:15:51
Message: <4a272047$1@news.povray.org>
Warp wrote:
> John VanSickle <evi### [at] hotmailcom> wrote:
>> Does it do something simple, like anticipate future needs based on the
>> current vector size?
>   My allocator can only be used to allocate elements of the same size.
> It allocates larger buffers of memory and then manages a simple list of
> free blocks.
Pretty much what I'd thought; allocate space for more than one when
called, and return a piece of the extra space for later calls.
John
Date: 4 Jun 2009 00:35:20
Message: <4a274f08$1@news.povray.org>
That's kind of how every allocator works. :-) The difference is Warp's has a
different pool for each specific size of item, so you don't get
fragmentation. The first empty you find is always the right size.
   There's no CD like OCD, there's no CD I knoooow!
Date: 4 Jun 2009 02:56:19
Message: <4a277013@news.povray.org>
  There's also one advantage: If a block of memory becomes completely
freed, the allocator frees this block of memory from the underlying
(compiler-provided) system allocator. If then new objects are allocated
and the current list of free objects is empty, it will allocate a new
memory block and start returning the space in consecutive order. In other
words, it effectively resets the ordering of freed objects in certain
situations.
  I have noticed enormous speedups because of this, compared to the system
allocator. If I *don't* free the blocks of memory (thus effectively resetting
the ordering of the list of free objects in that block) the allocator becomes
much slower. My conclusion is that the allocator is cache-friendlier than
the system allocator: Returning space for allocated objects consecutively in
memory is much faster than returning them in random order (which is what
tends to happen when you just keep a list of freed objects without ever
resetting their ordering).
  According to my tests this can have such a big impact that even spending
time sorting freed objects can speed up memory allocation overall. Cache
misses simply are really expensive.
Date: 4 Jun 2009 12:37:22
Message: <4a27f842$1@news.povray.org>
Have you ever tried building one that uses a bitmap of free entries? Since
they're all the same size, it would seem easy to do all the math needed quickly.
That's probably another reason the performance of compacting GCs are often
better than "manual" malloc and free.
Date: 4 Jun 2009 12:47:46
Message: <4a27fab2@news.povray.org>
nemesis escreveu:
> Perhaps I should bring on Jon Harrop to the rescue. :)
well, and truly I did:
to: namekuseijin <nam### [at] gmailcom>
date Tue, Jun 2, 2009 at 9:49 PM
subject Re: ocaml benchmark going bad
On Tuesday 02 June 2009 22:19:53 you wrote:
 > Hey, man.  Thought you'd like to know about this:
 > http://metamatix.org/~ocaml/price-of-abstraction.html
 > Don't know how old it is but seemingly OCaml is taking a beating by
 > both C++ and Scala on a mandelbrot implementation.  Perhaps the author
 > forgot some options to the ocamlopt compiler?
 > saw it in the povray newsgroups:
http://news.povray.org/povray.off-topic/thread/%3C4a256d90%241%40news.povra
 >y.org%3E/
The author claims that the programs are equivalent when they are not and
makes many completely false statements as a consequence. Objectively, he
should have asked for peer review but, actually, he could have written
decent OCaml code just by copying any of the many efficient Mandelbrot
benchmarks written in OCaml that are freely available on the web.
Firstly, he uses a simple and efficient imperative loop in the C++:
int iters1(int max_iter,double xc,double yc) {
   double x = xc;
   double y = yc;
   for(int count = 0;count<max_iter;count++) {
      if( x*x + y*y >= 4.0) { return count; }
      double tmp = x*x-y*y+xc;
      y = 2.0 * x * y + yc;
      x = tmp;
   return max_iter;
Great. I'd expect to see a simple imperative and efficient loop in OCaml
but the OCaml code he describes as "equivalent" is actually completely
different:
let iters1 max_iter xc yc =
  let rec aux count x y =
    if count = max_iter then max_iter else begin
      if x *. x  +. y *. y >= 4.0 then count else
      aux (count+1) (x *. x -. y *. y +. xc) (2.0 *. x *. y +. yc)
    end in
  aux 0 xc yc
Eh? He's used a nested recursive function for no reason and that has
introduced two radical differences compared to the C++:
1. OCaml does not unbox floats across function boundaries like this so
the floats are needlessly allocated and deallocated at every iteration
in the OCaml. In comparison, the C++ does no heap allocation.
2. His nested function is not self-contained: it captures xc and yc from
its environment. So this is compiled into a closure (a concept that does
not exist in C++, of course) incurring allocation and making every
single function invocation in the inner loop several times more
expensive. In comparison, the C++ does direct function calls to
statically-known locations.
No problem, I thought. This was obviously written by a C++ guy who
doesn't know OCaml. But then I saw his OOP example in C++:
class Complex {
public:
   Complex(double xc,double yc) : x(xc), y(yc) { }
   double norm_square() {
      return x*x+y*y;
   Complex operator*(const Complex &other) {
      return Complex(x*other.x-y*other.y,
                     x*other.y+y*other.x);
   Complex operator+(const Complex &other) {
      return Complex(x + other.x, y + other.y);
private:
   double x;
   double y;
int iters2(int max_iter,double xc,double yc) {
   Complex c(xc,yc);
   Complex z(xc,yc);
      if( z.norm_square() >= 4.0 ) { return count; }
      z = z * z + c;
   return max_iter;
His overloaded * does not implement multiplication correctly but, more
importantly, he forgot that objects in C++ are represented by pointers.
By removing all of the pointers he has removed all of the allocation but
also any chance of using subtypes and/or inheritance. In other words,
this is not OOP at all. He has just used a struct.
Let's try an honest C++ equivalent that does support OOP, i.e. you can
derive a new kind of complex number from the Complex class and use it
interchangeably because they will have the same uniform run-time
representation of a *pointer* to an object:
#include <cstdio>
const int RESOLUTION = 5000;
class Complex {
public:
      return x*x+y*y;
   Complex *sqr() {
     return new Complex(x*x - y*y, 2 * x*y);
   Complex *add(const Complex *other) {
     return new Complex(x + other->x, y + other->y);
private:
   double x;
   double y;
   Complex *c = new Complex(xc,yc);
   Complex *z = new Complex(xc,yc);
      if( z->norm_square() >= 4.0 ) {
        delete c;
        delete z;
        return count;
      Complex *z2 = z->sqr(), *oz = z;
      z = z2->add(c);
      delete z2;
      delete oz;
   delete c;
   delete z;
   return max_iter;
int main() {
   int    max_val = RESOLUTION/2;
   int    min_val = -max_val;
   double mul = 2.0 / max_val;
   int    count = 0;
   for(int i=min_val;i<=max_val;i++) {
      for(int j=min_val;j<=max_val;j++) {
         count += iters2(100,mul*i,mul*j);
   printf("result: %d\n",count);
That is 15x slower than his C++ code because allocation is so
inefficient in C++.
He also failed to mention that abstraction is usually achieved with
functors and not objects in OCaml. Let's try using the higher-order
module system:
let resolution = 5000
module type COMPLEX = sig
  type t
  val mk : float -> float -> t
  val norm2 : t -> float
  val add : t -> t -> unit
  val sqr : t -> unit
end
module Complex : COMPLEX = struct
  type t = {mutable r: float; mutable i: float}
  let mk r i = {r=r; i=i}
  let norm2 z = z.r *. z.r +. z.i *. z.i
  let add z1 z2 =
    z1.r <- z1.r +. z2.r;
    z1.i <- z1.i +. z2.i
  let sqr z =
    let r' = z.r *. z.r -. z.i *. z.i and i' = 2.0 *. z.r *. z.i in
    z.r <- r';
    z.i <- i'
end
module Iters(C: COMPLEX) = struct
  let iters max_iter xc yc =
    let c = C.mk xc yc in
    let i = ref 0 and z = C.mk xc yc in
    while !i < max_iter && C.norm2 z < 4.0 do
      C.sqr z;
      C.add z c;
      incr i
    done;
    !i
end
let () =
  let module I = Iters(Complex) in
  let max_val = resolution/2 in
  let min_val = - max_val in
  let mul = 2.0 /. float max_val in
  let count = ref 0 in
  for i = min_val to max_val do
    for j = min_val to max_val do
      let x = float i *. mul in
      let y = float j *. mul in
      count := !count + I.iters 100 x y;
    done
  done;
  Printf.printf "result: %d\n" !count
So here are my timings:
C++:    3s   (raw)
C++:   35s   (genuine objects)
OCaml:  4.6s (record)
OCaml: 10s   (functor)
Dr Jon Harrop, Flying Frog Consultancy Ltd.
http://www.ffconsultancy.com/?e
Date: 4 Jun 2009 14:26:00
Message: <4a2811b8@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> more
  Everything was fine until this point. However, this is starting to
sound more like he is deliberately trying to come up with a contrived,
yet plausible-sounding way of artificially making the C++ version slower.
  I find it rather ironic (and hypocritical) to do that immediately after
he argued that the straightforward iterative version in C++ had an "unfair"
advantage over the proposed Ocaml version which used recursion. In other
words, he is arguing that the first Ocaml version was slower because the
wrong (and inefficient) methodology for the given task was used. Then he goes
right ahead and gives us the completely wrong (and inefficient) methodology
in the "abstracted version" of the C++ program, just to artificially make
it slower.
  The original article didn't say anything about "object-oriented programming".
It only talked about abstracting away the complex number type. Even if you
could argue that for an implementation to be "OOP" it *must* support dynamic
binding, he is (probably deliberately) missing the point: The point was not
to make the program object-oriented, but to abstract away the complex number
type. In other words, to make it more modular. And the suggested C++ class
does exactly that, and it does so in the way that the language was designed.
  Maybe he wanted to point out that in Ocaml you cannot do the same, ie.
create classes which are *not* dynamically bound, and thus the comparison
is "unfair". However, if Ocaml lacks such capabilities, that's hardly C++'s
problem. The goal was to abstract away the complex number type as efficiently
as possible, nothing else. His argument about "OOP" is completely flawed.
Date: 4 Jun 2009 15:54:14
Message: <4a282666$1@news.povray.org>
I have to say, after posting it and rethinking about, that I believe he
missed the point the poster wanted to say:  that higher abstractions
like recursion and getting away from lowlevel machinery do indeed incur
in a cost.
He correctly identifies unboxing and variable capture as extras not
present in the C++ code but that was precisely the point of the author
-- "The price of abstraction".  By making OCaml behave the same as C++,
you can indeed maxout performance, but that was not the point... yes,
Warp, I see what you mean about the dumbing down of the C++ code.
In any case, although he went after C++, I was more annoyed at seeing
another higher-level language with high level constructs, Scala on the
JVM, outpacing OCaml.  That's what really stroke me as odd.
a game sig: http://tinyurl.com/d3rxz9
Date: 4 Jun 2009 16:11:40
Message: <4a282a7b@news.povray.org>
> Scala on the
  If the JVM performs JIT-compiling, I don't see the problem...
Date: 4 Jun 2009 16:16:44
Message: <4a282bac$1@news.povray.org>
Warp wrote:
> However, if Ocaml lacks such capabilities, that's hardly C++'s problem.
Indeed, I think that was specifically the point of the article in the first
place. :-)
Date: 4 Jun 2009 16:34:48
Message: <4a282fe8$1@news.povray.org>
Warp escreveu:
>> Scala on the
JIT-compiling doesn't beat g++ compiling in that benchmark, nor do I
understand quite why it should beat OCaml either -- the author mentions
poor OCaml float performance.
I'm not an OCaml programmer, which is why I asked Mr. Harrop for some
insight.  I only knew, based on more than one source, that it's capable
of very C++-like performance.  caught off-guard...
