POV-Ray : Newsgroups : povray.off-topic : Another Vista stupidity Server Time
15 May 2026 23:25:04 EDT (-0400)
  Another Vista stupidity (Message 21 to 30 of 42)
Subject: Re: Another Vista stupidity
Date: 15 May 2009 12:25:08
Message: <4a0d9764$1@news.povray.org>
Warp wrote:
>   "How do I do that?" Right, he was in Windows, and there's no diff in
> Windows. We pondered for a moment what would be the easiest solution.
Download diff for Windows? :-)
http://www.google.com/#hl=en&q=diff+win32
> He was using notepad++ as his text editor and we wondered if there would
> be some way of comparing two files in it. With the million of menus in the
> program, it was probably not worth the trouble.
It works with vim, tho. :-)
>   Sometimes things just *are* way easier in unix. Sure, there are tools
> for Windows to do the same thing, but the problem is that Windows never
> has *any* tools by default, and it would always require quite a lot of
> work to get the tools. In unix the tools just are there, period. No need
> to think nor hassle around.
No more hassle than starting up yast to download them, methinks.
Occasionally you'll have to figure out if it's a "real" port or a cygwin
port, but i've found the "win32" modifier almost always points you at a
native port without a bunch of dependencies.
But sure, unix has more command-line tools for Windows by default. :-)
Windows isn't primarily targeted at developers, so developers have to
install some tools they need.
   There's no CD like OCD, there's no CD I knoooow!
Date: 15 May 2009 12:32:14
Message: <4a0d990e@news.povray.org>
  That's precisely the problem I was talking about. *Nothing* comes with
Windows by default, and for everything you would have to search and download
some third-party, non-standard utility which might or might not do what you
want.
  (Additionally, Windows' command prompt just isn't as easy to use as
unix's. It's just a PitA to try to do anything in it.)
  Yeah, rather than take 2 seconds to diff the files in the mac computer,
he would have to spend at least 2 hours to find out how to do the same
thing in vim (and this after he had found and installed the program).
  I'm talking about a real, actual, concrete experience here, not some
theoretical "methinks" thing. Diffing the files on the mac was just way,
way less hassle than *anything* else.
Date: 15 May 2009 13:05:53
Message: <4a0da0f0@news.povray.org>
And even more, vim can't diff. It can only run 'diff' to do the comparison,
then do stuff with its output.
Date: 15 May 2009 13:16:16
Message: <4a0da360$1@news.povray.org>
I was just answering the question. I understood your point, but the easiest
solution would have been to download the stand-alone diff executable. :-)
No argument there.
Well, diff works from the command line just like in UNIX. Maybe 3 minutes to
find and download diff (once you know the best search terms) and then you
run it from the command line.
If you want side-by-side diffs, you can invoke it from vim, is all I was
saying. The same tools work. They're just not distributed there by default.
OK. I'm talking *my* real actual concrete experience. I *have* diff on my
windows machine, along with netpbm and tar and gzip and a couple other
packages I'm used to using or that I need to talk to unix machines. It's
less of a hassle than you think, and you only need to do it once.
It was more a FYI post ("btw, it's easy to solve this problem on Windows so
he doesn't have to bother you next time") than it was "you're wrong."
I still copy RAR files over to a UNIX VM to take apart because I haven't
found an easy free unrar program for Windows, so I know just what you mean.
"diff" doesn't fall into that category, is all.
Date: 15 May 2009 13:40:18
Message: <op.utzfddc47bxctx@e6600>
> mean.
Define "easy". 7-Zip can extract RAR, if you want GUI-based. If
command-line is your thing, UnRAR is freeware.
FE
Date: 15 May 2009 14:15:47
Message: <4a0db152@news.povray.org>
  Besides being the best (free) compression program in existence, as a
bonus. :)
Date: 15 May 2009 14:23:19
Message: <4a0db317@news.povray.org>
I'm not sure what part of "it works with vim" is confusing you here. :-)
Date: 15 May 2009 14:23:57
Message: <4a0db33d$1@news.povray.org>
>> haven't found an easy free unrar program for Windows, so I know just
>> what you mean.
Thanks. I'll look around for unrar. I hadn't found that, last time, oddly
enough.
Date: 15 May 2009 14:26:59
Message: <op.utzhi9pu7bxctx@e6600>
On Fri, 15 May 2009 20:23:53 +0200, Darren New <dne### [at] sanrrcom> wrote:
> I'll look around for unrar. I hadn't found that, last time, oddly enough.
http://www.rarlab.com/rar_add.htm
FE
Date: 15 May 2009 14:28:22
Message: <4a0db446$1@news.povray.org>
> Warp wrote:
>>  Not even big rich companies are safe
>> from this kind of tampering (just ask Sun Microsystems).
> Sun isn't a big rich company anymore, though :)
Yeah - I heard an unsubstantiated rumour that Oracle bought them...
http://blog.orphi.me.uk/
