POV-Ray : Newsgroups : povray.off-topic : Obsolete technology Server Time
16 May 2026 00:36:24 EDT (-0400)
  Obsolete technology (Message 21 to 30 of 48)
Subject: Re: Obsolete technology
Date: 27 Apr 2009 16:29:53
Message: <49f615c1$1@news.povray.org>
>>>>>>   dd if=/dev/sda of=/mnt/sdb1/WinNT_backup.img
>>>>> ...or I could use Norton Ghost (which we have a commercial license
>>>>> for).
>>>> Hmmm... Why do companies want to use money on such programs ?
>>>   If the program breaks, they have someone to call to. No such luck with
>>> free software.
>> So you are saying that their chances of having the problem fixed in
>> time is better if they have paid money for the program ?
> Sure.  If Norton Ghost dies they can spend hours on the phone or in
> email exchanges to both act all bossy customer and demand a new copy or
> a fix, rather than spending a few minutes getting Knoppix to boot and
> then typing those 4 lines.
In fairness, Ghost does much, much more than dd does. In particular,
Ghost comprehends NTFS, so you can do things like restore to a partition
of a different size, backup only the "used" sectors, etc. It also has
the ability to backup and restore over the network using compression and
so forth. And you can browse and modify the backup image on the server
without having to restore it first. And...
http://blog.orphi.me.uk/
Date: 27 Apr 2009 16:33:57
Message: <49f616b5$1@news.povray.org>
>>> ...or I could use Norton Ghost (which we have a commercial license for).
Because it has useful functionallity that saves us money?
>> But what if the HD breaks ?
> - or if the PC is rooted ?
> - or if the installation is messed up by a virus or an employee ?
Well, let us hope that doesn't happen in the next 3 weeks then, eh?
After that, the machine I just spent all this time setting up is going
to be decommissioned anyway. (GAH! >_< That was *so* worth it...)
The new machines are going to be set up from a Ghost image, so if one
breaks it'll be much faster to fix.
Date: 27 Apr 2009 21:24:03
Message: <49f65ab3$1@news.povray.org>
> so forth.
knoppix@Knoppix:~$ konqueror man:dd man:ssh man:gzip &
knoppix@Knoppix:~$ sudo su -
root@Knoppix:~# dd if=/dev/sda bs=1k conv=sync,noerror | gzip -c | ssh
-c blowfish andrew@linuxbox "dd of=sda.img.gz bs=1k"
Also see:
http://wiki.egee-see.org/index.php/SEE-GRID_Guide_on_WN_replication
andrew@linuxbox ~ $ gunzip sda.img.gz
andrew@linuxbox ~ $ /sbin/sfdisk -l -uS sda.img
andrew@linuxbox ~ $ konqueror man:mount
(Look for loop and offset)
Also see:
http://www.andremiller.net/content/mounting-hard-disk-image-including-partitions-using-linux
> And...
knoppix@Knoppix:~$ konqueror man:man man:info &
Tor Olav
http://subcube.com
Date: 27 Apr 2009 22:26:07
Message: <49f6693f$1@news.povray.org>
>> partition of a different size, backup only the "used" sectors, etc. It
>> also has the ability to backup and restore over the network using
>> compression and so forth.
None of this lets you restore to a partition of a different size or backup
only the used sectors, or browse the files in the backup over the network
without decompressing them.
It also doesn't let you clone a new Windows machine from an old one.
   There's no CD like OCD, there's no CD I knoooow!
Date: 28 Apr 2009 00:07:57
Message: <49f6811c@news.povray.org>
Like the many ntfstools? I'm sure there's one that can skip free blocks.
> It also has
> so forth.
According to Unix philosophy, no backup tool should have compression
built-in. If you need it, you use a pipe and an external compression tool.
Mount it with a loop device.
Date: 28 Apr 2009 01:18:14
Message: <49f69196$1@news.povray.org>
Yes, but what's the point in adding a UNIX dependency when there are free
ghosting tools that work just fine entirely under Windows and without you
even having to quiesce the file system before you ghost it?
If you really want to know why someone would pay money for the product, look
at the page on wikipedia to see the list of features it would be a PITA to
put together under Linux. For *some* people, time is money. :-)
Date: 28 Apr 2009 04:38:44
Message: <49f6c094@news.povray.org>
Are there any that aren't alpha? Every system I've seen for reading NTFS
from Linux is either read-only or has a big flashing red disclaimer on
it. Ghost was written by people who's signed the NDA and seen the spec
for the NTFS filesystem.
Random, but... why the hell do you need a loopback "device" in the first
place? Why can't you just mount (say) an ISO image directly? Requiring a
loopback device means that
1. there are only a finite number of them available,
2. before you can mount anything loopback, you have to determine which
device numbers (if any) are free.
It just seems unecessarily complicated...
Date: 28 Apr 2009 08:46:25
Message: <49f6faa1$1@news.povray.org>
>>> And you can browse and modify the backup image on the server without
Have a look at this document:
   http://www.slax.org/documentation_loop_mount.php
Here's how I understand the situation:
Linux kernels earlier than v. 2.6.23 had 8 loop devices, unless you specified more
Linux kernel v. 2.6.23 had 256 loop devices
Linux kernel v. 2.6.24 and later does not have these limitations
Just try this:
   mount -o loop,offset=somenumberofbytes ~/sda.img /mnt/sda1
 From the mount manual:
mount will try to find some unused loop device and use that."
Tor Olav
http://subcube.com
Date: 28 Apr 2009 09:05:22
Message: <49f6ff12@news.povray.org>
>> first place? Why can't you just mount (say) an ISO image directly?
>> Requiring a loopback device means that
> specified more
The device files still have to exist in the filesystem though. (That's a
fairly bizare concept in itself...)
> Just try this:
> is given), then mount will try to find some unused loop device and use
> that."
So somebody wrote the code to automatically select a free device. The
fact is, you still need there to be a free device. I still don't get why
you can't just mount the file itself...
Date: 28 Apr 2009 09:54:14
Message: <49f70a86$1@news.povray.org>
>> specified more
>>> which device numbers (if any) are free.
>> Just try this:
>> and use that."
If your kernel is of a newer version there will always be a free loop device,
I.e. you don't have to worry about that.
Because the file is not a block device.
   http://en.wikipedia.org/wiki/Loop_device
Tor Olav
http://subcube.com
