POV-Ray : Newsgroups : povray.off-topic : Weekly calibration Server Time
2 Jul 2026 18:36:46 EDT (-0400)
  Weekly calibration (Message 27 to 36 of 106)
Subject: Re: Weekly calibration
Date: 20 Apr 2009 16:25:22
Message: <49ecda32@news.povray.org>
Mueen Nawaz <m.n### [at] ieeeorg> wrote:
>         2) The monkey problem is isomorphic to this one: If I have an unbiased
> coin (and assume the outcome _is_ random, and not related to chaos -
> such as the force I hit it with, etc), and I keep flipping it, is it
> possible that I can get a continuous string of heads indefinitely?
>         Intuition tells me yes. I just can't see any physical reason why I
> _have_ to get a tails at some point.
>         Yet _every_ single person - mathematician, probabilist, or otherwise
> says the answer is no because the probability of such an event happening
> is 0 in the limit to infinity. If you do 1 minus that, you get  that the
> probability of a tails appearing at _some_ point is 1. In fact, you're
> the _first_ person I've seen who has the same dilemma with this problem
> as I do.
  I'd say that the probability being 1 with infinite throws is exactly as
meaningful as the probability of getting a certain value of a continuous
range being 0. Yes, it's mathematically zero, but that doesn't mean that
the value will never be chosen (if it meant that, it would mean that no
value would *ever* be chosen because all the individual values have a
probability of zero).
  Likewise the probability of getting tails being 1 with infinite throws
doesn't really tell us that tails must appear at some point. After all,
you *can't* throw a coin an infinite amount of times, and even the idea
has no correspondence to any physical event. It's a purely mathematical
construct. What the 1 tells as is that it's the upper limit for the
probability.
  I'd think about it this way: No matter how many times you throw, there's
*always* a non-zero probability that it will be all heads. At no point is
tails *forced* to appear by any law of nature or mathematics. (This is
because past tosses do not affect future ones.)
Date: 20 Apr 2009 16:40:25
Message: <49ecddb9$1@news.povray.org>
Darren New wrote:
> Mueen Nawaz wrote:
>>     What's a "truly random" sequence?
> This is a well-defined concept.  It means that (basically) the
> probability of you being able to predict the next item in the sequence
> is unchanged by any knowledge you might have.
	OK. Not how I was interpreting it...
>>     (And be careful when you say Normal. The distribution called "normal"
>> in probability is the Gaussian distribution, which I think is not what
>> you meant).
> I meant what are called "normal numbers" in math, not normal statistical
> distributions. Check wikipedia.
	I know - just thought I'd point out it could be confusing.
	Anyway, your original assertion was that a truly random sequence is
necessarily a normal sequence. That doesn't match up with your
definition of normal.
	If I have a sequence derived from a Gaussian distribution, then it is
truly random by the way you defined it. Given the whole sequence, up to
a point, it doesn't tell me anything about what the next element could
be (other than what is obvious - that it follows a Gaussian
distribution). However, for this sequence "every block of a particular
length occurs with equal probability" does not hold.
"Now we all know map companies hire guys who specialize in making map
folding a physical impossibility" - Adult Kevin Arnold in "Wonder Years"
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 20 Apr 2009 16:41:03
Message: <49ecdddf$1@news.povray.org>
	Which was my whole long winded point. The monkey problem is identical
to this one.
	In classical probability, that's kind of the case. Perhaps it's better
to say that the model is only valid if you're talking of an interval or
collection of intervals (my interpretation - not necessarily shared by
probabilists). I was pointing out that if it's flawed to use this model
to calculate the probability of getting a single point, it's equally
flawed in trying to calculate the probability of getting all heads, or
of monkeys producing the works of Shakespeare.
                                   anl
Date: 20 Apr 2009 16:52:57
Message: <49ece0a9$1@news.povray.org>
That's the difference between "unbounded" and "infinite". You're thinking
"no matter how big it gets..." but "infinite" doesn't mean that. Unbounded
means that.
Can you write a turing machine that uses up an infinite amount of space on
the tape? No, only an unbounded amount. Can you have a countably infinite
set? Yes. Hence, infinity is not computable by a turing machine.
As long as you keep trying to do the math in terms of "you compute
successive values", you'll not get the answer.
   There's no CD like OCD, there's no CD I knoooow!
Date: 20 Apr 2009 17:08:50
Message: <49ece462$1@news.povray.org>
That's how the people in cryptography define it. :-) Basically, you can't
have a random sequence. You can only have a random process. It's impossible
to look at a sequence that has already been generated and decide if it's
random or not.
Fair enough.
I didn't define the term "normal sequence", except by reference to "normal
numbers", via Wikipedia.
> distribution).
Correct.
I think there's confusion conflating "random" and "normal" in our
conversation about distributions here. Not every random sequence is normal,
and not all normal sequences are random. Sorry if I confused "the kind of
random you assume idealized monkeys will generate on keyboards" with "any
sort of random distribution".
To have a "normal number", you need linear distribution, basically. I.e.,
all substrings of a given length appear with equal asymptotic probability as
the number of symbols you look at gets large. *Given* that, every sequence
of any given length will appear if you let N be infinity.
In other words, in order to avoid Shakespeare appearing, you would have to
have a non-random distribution *because* the sequence is infinite and not
just unbounded. In exactly the same way that 0*X is zero no matter how big X
gets, until X is actually infinite.
(lim(x->inf) 0*X) =/= (0*inf)
You can't reason about it based on "no matter how big it gets, ..."
Date: 20 Apr 2009 17:54:01
Message: <49eceef9$1@news.povray.org>
>> distribution).
> Correct.
> normal, and not all normal sequences are random. Sorry if I confused
> "the kind of random you assume idealized monkeys will generate on
> keyboards" with "any sort of random distribution".
	Not sure I'm getting it. Just to clarify, I'm using the word normal in
the way you originally meant it (normal numbers). I'm using normal
sequence in the same sense.
	I was merely pointing out that you originally said:
"Given that truly random sequences are normal, and in a normal sequence
every block of a particular length occurs with equal probability"
	I was giving you an example of a truly random sequence that was _not_
normal.
> I.e., all substrings of a given length appear with equal asymptotic
> probability as the number of symbols you look at gets large. *Given*
> that, every sequence of any given length will appear if you let N be
> infinity.
	Agree - other than with the use of the word "will".<G> What I mean is
that what you say is how I understand what probability theory says.
> to have a non-random distribution *because* the sequence is infinite and
	I think I get the general idea, but to nitpick, you can avoid it even
with a random distribution. If I have a distribution where the
probability of typing the letter 'e' is forbidden, it's still random
(not "truly" random).
	I suppose you may object to my referring to it as random, but it is
consistent with probability theory: A uniform distribution from 0 to 1
is a valid random distribution - even though you've excluded all numbers
greater than 1.
> not just unbounded. In exactly the same way that 0*X is zero no matter
> how big X gets, until X is actually infinite.
	That's really not helpful. I get quite fussy when people use infinity,
and insist on a lot of rigor (which I may not understand<G>) before I
accept anything said by it. The LHS is _always_ equal to 0 (assuming x
is a real number). It's not equal to the RHS because the RHS is
meaningless. It's undefined.
                                   anl
Date: 20 Apr 2009 19:03:36
Message: <49ecff48$1@news.povray.org>
> normal.
Yes. I was phrasing it sloppily there, since we hadn't talked about other
distributions at that point in the conversation. To clarify, a "normal
sequence" in the way I'm using it means all possible subsequences have the
same probability distribution in the asymptote. Hence, you can't take a
gausian distribution of symbols and expect to get a normal sequence from them.
>> infinity.
OK. I don't think I know enough math to convince someone else of it. I'm
just taking it on authority. It would seem to be the sort of thing amenable
to proof, so when a math text says it's so, I'll take their word for it. :-)
Especially when they point out a bunch of other hypotheses where they say
"We think so but haven't proven it."
No, it's not random. If you go an infinite number of symbols and "e" doesn't
appear, then "e" doesn't have the same frequency in the asymptote as
something that *does* appear an infinite number of times.
What you do in that case is remap the output to encode fewer letters of
english per bit, and interpret it that way. That's the equivalent of reading
the number in some other base (binary/hex/etc).  I'm dealing with English as
base-26 or base-127 or whatever character set you want to use.
> greater than 1.
Sure. But we're starting with the assumption that all the letters of the
alphabet can be typed. If you give the monkeys a typewriter with no "e" key,
of course they're not going to type out shakespeare.
And you can't say "they might never type the word 'the'", because if they
typed "th" and you knew they never typed "the", then you again wouldn't have
a random sequence, because you could predict with 1/25 assurance what the
next letter would be instead of 1/26.
It's not meaningless. It's merely not a number. That doesn't mean you can't
work with it. Just like you can work with math where you have functions that
are uncalculable, corresponding to functions that get stuck in infinite
loops in a programming language.
In any case, therefore, the statement still holds, because 0 is defined and
0*inf is not.
But I think I've exhausted my ability to convince you that Shakespeare
necessarily appears in the output, if the output is infinite and making the
other normal assumption that each possible character is typed with equal
probability. :-)
Date: 20 Apr 2009 19:15:48
Message: <49ed0224$1@news.povray.org>
> other distributions at that point in the conversation. To clarify, a
> "normal sequence" in the way I'm using it means all possible
> subsequences have the same probability distribution in the asymptote.
To clarify more, this includes sequences of length 1. So the mathematical
proof I read a long time ago (and which I don't think I really followed at
the time) basically said "if you have an equal probability of picking each
symbol at random, and you string together an infinite number of those
symbols, then you have an equal probability of picking any particular
substring of any particular length." Hence, since there are an infinite
number of substrings of length (size of shakespeare) and *something* in
there must appear an infinite number of times, shakespeare too must appear
The heights of people aren't "truly random" even tho they might be
statistically distributed. It depends on what you ignore when you do the
measurements.
The difference between arbitrary math (unrelated to the universe) and
statistics and science (related to the universe) that you described can be
attributed to what you ignore when you take your measurements. It's actually
kind of fascinating to think on. Someone once convinced me that subatomic
particles like electrons aren't just fungible but actually identical, but I
don't recall what the proof was. It was just logic and relativity and stuff
like that when you got down to it.
Date: 20 Apr 2009 20:29:38
Message: <49ed1372@news.povray.org>
> Hence, you can't take a gausian distribution of symbols and expect to
	OK - Agreed.
	There's really nothing to convince. I'm agreeing with you that
probability theory states the same thing that you state. I have no
_mathematical_ argument against what you're saying (other than the
nitpicking - I agree with your math). I'm just uncomfortable with this
application of probability theory to the "real" world.
	See, in mathematics, everywhere I've seen infinity used with rigor (and
where I understood it), behind all the formalism is basically a
definition of what they mean. Sometimes it is intuitive, but there's no
guarantee that it will conform to reality. Indeed, it is often
impossible to compare it to reality, given the absence of infinities (or
at least our ability to measure them). We can say the cardinality of the
set of natural numbers is that of the rationals, but that's not a
universal truth in the "real" world - it's just a consequence of how we
define cardinality (and numbers).
	It's because of stuff like this that you get the Banach Tarski paradox
(among a bunch of paradoxes). It's due to the Axiom of Choice, which is
quite intuitive to most people. If the BT paradox seems impossible in
the real world, you'll have to give up on the A of C, which seems
counterintuitive.
	Now in probability theory, it's really just mathematics where we're
manipulating numbers and symbols. For cases where we deal with finite
and discrete quantities, probability theory seems to agree with reality.
If it states the probability of something is 0, we interpret that to
mean it will definitely _not_ happen (unless our modeling was off).
Likewise, if it states it is 1, we interpret that to mean it _will_ happen.
	When you now go to continuous distributions, picking a point is, in a
sense, meaningless to the theory. It can only give nonzero probabilities
to intervals, or collections of intervals, etc.** Likewise, probability
theory gives you a 0 for flipping a coin every second forever and never
getting a tails.
	The (usual) interpretation when applied to the real world is that
because it gave me a 0, such a thing can never happen.
	Can it? Can't it? I don't know. I can never know, because I can never
test it. Because of that, I'm wary of results probability theory gives
me for stuff like infinite sequences. I _can_ test it with the real
world for finite events. I'm not saying probability theory is
inconsistent or the math behind it is bad. I'm just saying I shouldn't
blindly accept it as being consistent with the real world just because
it works for finite cases.
	I won't accept that I can't get a forever continuous string of heads
from a coin unless someone can give me a _physical_ reason. There isn't
any - there's only a mathematical one.
<snipped a whole bunch of stuff because I'd just nitpick further>
	Well, I guess "meaningless" is vague. It _is_ undefined. About as
useful as dividing by 0.
	Well, perhaps we're just playing semantic games.
	As I said, I agree that probability theory agrees with you.
	I'm simply wary of using a _purely_ mathematical argument to make
statements about the real world. It invokes no aspect of the real world,
and no laws of physics that I'm aware of. It's just like saying that
yes, you _can_ execute the BT paradox in the real world...
	(As you can guess by now, I'm one of those who feel that the theorems
in mathematics are not necessarily tied to the physical laws of the
universe - other than in the manner that we can think them and
presumably our brains conform to the physical laws...).
** The reason, I suspect, is that theories of integration generally
don't have the integral changing if you happen to remove a point or any
set of measure 0 from the domain of integration.
                                   anl
Date: 20 Apr 2009 20:35:00
Message: <web.49ed13deb9c54b9363a1b7c30@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> http://news.bbc.co.uk/1/3013959.stm
> "...and mostly typing the letter "s"."
For a second, I thought maybe they had discovered radio communication, but I
guess it was the humans that set up the radio link.  Too bad.
 - Ricky
