POV-Ray : Newsgroups : povray.off-topic : Emacs Server Time
6 May 2026 07:18:21 EDT (-0400)
  Emacs (Message 210 to 219 of 349)
Subject: Re: Emacs
Date: 18 Apr 2009 13:18:20
Message: <49ea0b5c$1@news.povray.org>
On Sat, 18 Apr 2009 05:10:30 -0400, Warp wrote:
> Jim Henderson <nos### [at] nospamcom> wrote:
>> On Sat, 18 Apr 2009 04:39:37 -0400, Warp wrote:
>> > Jim are *deliberately*
>> Don't you *dare* tell me that I'm deliberately misunderstanding you.
>> You have no idea what my *deliberate* processes are.
>   Fine, you are not doing it deliberately. You are misunderstanding what
> I wrote because you are stupid?
>   Is that better?
Hardly.
It's because I have a different perspective.  Quite frankly if you're
going to continue to insult and presume to tell me what I mean when I
write, then I shall just plonk you into my twit filter and be done with
you.
Jim
Subject: Re: Emacs
Date: 18 Apr 2009 13:18:53
Message: <49ea0b7d@news.povray.org>
On Sat, 18 Apr 2009 06:18:09 -0400, Warp wrote:
> He (as well as Darren) deliberately chose to ignore what I was saying
*plonk*
Have fun.
Jim
Subject: Re: Emacs
Date: 18 Apr 2009 13:22:22
Message: <49ea0c4e$1@news.povray.org>
On Sat, 18 Apr 2009 13:19:35 -0300, nemesis wrote:
> Jim Henderson wrote:
>> On Sat, 18 Apr 2009 03:23:46 -0300, nemesis wrote:
>>> You know what is not intuitive either?  A Boeing user interface.  Yet,
>>> it'll get you farther and faster than your intuitive bicycle. :)
>> True, but sometimes a bicycle is all you need, you don't need a 747 to
>> take you to the corner market. ;-)
> Yeah, it was a poor analogy because it's not two ways:  once learned the
> basics, vi is excellent as a bike as well!  Just ask any *nix sysadmin.
Yes indeed. :-)
Jim
Subject: Re: Emacs
Date: 18 Apr 2009 13:31:24
Message: <49ea0e6c$1@news.povray.org>
nemesis wrote:
> 20-years vi hacker comes in touch with notepad for the first time:
> iWhat the crap is this thing?
Heh. I can't tell you the number of .signature files and mail messages I've
gotten over the years that end with :wq
   There's no CD like OCD, there's no CD I knoooow!
Subject: Re: Emacs
Date: 18 Apr 2009 13:42:28
Message: <49ea1104@news.povray.org>
> you.
  You are not going to see this (unless someone quotes me), but I'm going
to write it anyways:
  I wrote that vi is harder to approach than other more "regular" text
editors because it doesn't work like those other editors. With other text
editors you start the program and just start editing. In other words, you
eg. press the 'a' key, and the letter 'a' appears at the cursor position.
You press the down cursor key, and the caret goes to the next line, and
so on.
  I think I expressed that, but you still chose to deliberately nitpick
about what "start editing the file right away" means. I think it was pretty
clear from what I wrote and from the context that I meant that you don't
have to press any "commands" or anything to start editing the file. You
just edit it right away. I was contrasting vi with basically any other
text editor. I was expressing why I find vi so hard to approach.
  This is not a question of persective. This a question of whether you
understood what I wrote or not.
  Then you acted all so mighty and deeply insulted when I dared to hint
that you had deliberately started nitpicking on terminology, rather than
understanding what I wrote.
  So if you did not deliberately nitpick, then what is the other possible
alternative? The only other alternative was that you did not understand
what I wrote. I can't believe you would be so stupid as to not to understand
such a simple thing, which is why I chose to believe that you were just
deliberately nitpicking.
  But since you insist in that you were not doing it deliberately, then
fine by me. It means you are stupid. And arrogant as well.
Subject: Re: Emacs
Date: 18 Apr 2009 13:54:46
Message: <49ea13e6@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> I was responding to what you actually wrote, rather than what you might have
>> thought you intended to mean. You said you don't start up vi, edit a file,
>> then save and quit. That's just how vi works.
>   Then you must be using a different version of vi than I do.
No. You start vi with a file, edit it and insert text, and then save it.
It's just that "typing letters" isn't how you insert them, any more than
using H J K and L are how you move around inside an emacs session.
>   I start vi with eg. a text file, try to start editing it and... weird
> things happen. Nothing happens, it beeps or does weird things.
Right. You need to go into "insert text" mode. You can configure your vi to
start that way, but most people don't, since most people don't start editing
by having the first thing they do to be inserting text.  (I.e., most times
you start vi, you already have the file you're changing.)
Maybe it's because I use vi a lot, so when someone says "you can't start
with a file, move the cursor, edit text, and then save the file", I'm not
assuming they meant to add "without having to learn what keystrokes do
that."  It's not like you can move the cursor, edit text, and save the file
in emacs without either using a version with menus or learning that C-n is
down and C-p is up and so on.
Given that there *are* editors where you can't open a file when you start
the editor, or that you can't move around arbitrarily in the file (because
it's syntax-directed editing or something), I thought maybe you meant
something like that.
>   I think I explained that in parentheses in my post.
vi does everything you described. It just doesn't use the "usual" keys to do
it. Later versions do indeed let you use the arrow keys, and prompt you to
save the file when you close the window, and even have standard menus on top
and such.  The original VT100 version doesn't, of course.
Subject: Re: Emacs
Date: 18 Apr 2009 13:59:34
Message: <49ea1506@news.povray.org>
> understand such a simple thing, which is why I chose to believe that you
> were just deliberately nitpicking.
You miss a third possibility:  That I genuinely believed what I said.
The reason I got pissed off is because in your world, either people agree
with you, they deliberately misinterpret what you say in order to
'nitpick', or they're stupid.
There are other alternatives to those three options.  And it's time you
learned that.
Jim
Subject: Re: Emacs
Date: 18 Apr 2009 14:00:06
Message: <49ea1526$1@news.povray.org>
People who use vi call that "inserting text", not "just start editing".
That's the confusion.
> so on.
vi does this.
You say "vi is not like other editors", then you use terms that mean
something different in emacs and vi (such as what "just start editing"
means, or "opening and saving the file"), and then you get upset when people
who you *just said* think those things mean something different
misunderstand you.
> alternative?
That you're talking to people with a different perspective of what "just
editing" means, complaining that they have a different perspective, then
getting mad because they don't understand what your complaint is when you
use the same words they do to mean something different?
Subject: Re: Emacs
Date: 18 Apr 2009 14:03:40
Message: <49ea15fb@news.povray.org>
> *plonk*
  I wonder what really is the point in killfiling a regular visitor here.
  The only effect which that will achieve is that you will end up seeing
most of my posts anyways (because people tend to quote), and the threading
of discussions will become broken because your news reader will drop posts
inside the thread.
  Of course it's not really a question of not seeing anymore what I write
(assuming you killfiled me for real in the first place, rather than simply
pretending). It's just a way of you being pompous and arrogant, to show
how deeply "offended" you are.
  It's also an easy way of trolling, which is quite successful, I must admit.
Killfiling someone usually means that most if not all of what he writes is
insulting or inflammatory. Nobody kills someone just because he makes one
or two inflammatory posts among thousands. The only reason to do it (or
pretend doing it) is to taunt.
> Have fun.
  Well, you have fun with your broken threads and having to read my posts
quoted by other people anyways, if you really killfiled me. (If you are
just pretending, then you are more arrogant than I assumed.)
Subject: Re: Emacs
Date: 18 Apr 2009 14:06:18
Message: <49ea169a@news.povray.org>
  I repeat: I think I made it pretty clear what I meant when I wrote
"you edit it". No need to nitpick about this anymore.
  If you honestly did not understand it because I expressed it improperly,
then I'll try to express myself more clearly next time.
