POV-Ray : Newsgroups : povray.off-topic : Innovative open source? Server Time
21 Jul 2026 16:07:41 EDT (-0400)
  Innovative open source? (Message 51 to 60 of 62)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Innovative open source?
Date: 5 Apr 2009 00:19:54
Message: <49d8316a@news.povray.org>
Darren New wrote:
> It looks like it just keeps the order even for integer indecies:
> $pdq[10] = "Ten";
> $pdq[20] = "Twenty";
> $pdq[15] = "Fifteen";
> $pdq[12] = "Twelve";
> print_r($pdq);
> Array
>      [10] => Ten
>      [20] => Twenty
>      [15] => Fifteen
>      [12] => Twelve
> Weird, but understandable. It looks like a list of pairs. :-)
A list of pairs; exactly.
Date: 5 Apr 2009 00:31:46
Message: <49d83432$1@news.povray.org>
Nicolas Alvarez wrote:
> Darren New wrote:
>> clipka wrote:
>>> I think there's nothing wrong about it
>> That's why I was confused. You were characterizing it as "incorrect" and
> No he (clipka) wasn't. nemesis was :)
My bad.
   There's no CD like OCD, there's no CD I knoooow!
Date: 5 Apr 2009 03:15:50
Message: <49d85aa6$1@news.povray.org>
Darren New wrote:
> nemesis wrote:
>> Darren New <dne### [at] sanrrcom> wrote:
>>> You're saying "a hastable is for lookups. It doesn't have an order.
>>> Therefore, Python is right to base its data structures on hash tables."
>> It's supposed to be a hashtable.
> What is "supposed" to be a hashtable?
Remember we're talking about Python's dict here?  A Python dict is
supposed to be Python's builtin hashtable feature.  They also employ it
behind the scenes to hold objects' attributes.
> If you need a hashtable, PHP's arrays give that to you. If you need a
> list, PHP's arrays give that to you. If you need order-preserving
> keyed-access data structures, PHP's arrays gives that to you, and Python
> doesn't.
If you need a hashtable, Python's dicts give that to you. If you need a
   list, Python's lists give that to you. If you need order-preserving
keyed-access data structures, you may derive a new class from Python's
dict and implement that custom behavior.
I thought specialization was a good thing, specially performance-wise.
If you want just an order-preserving list for your items, PHP most
likely will still incur in a performance loss by calling a hash function
over the item, a Python list won't.
Well, why speculate when we have the sources available?
Here's how to get the PHP ones:
http://br2.php.net/get/php-5.2.9.tar.bz2/from/a/mirror
And here's how to get the Python one:
http://python.org/ftp/python/2.6.1/Python-2.6.1.tgz
Doing so reveals a lot.  For instance, now it's not simply in the
correct specialized behavior, consistent semantics and crystal clear
syntax that Python gets my vote as a top-notch language:  comparing it's
source with PHP's is also an incredible testament to all the bad things
that go into open-source projects you mentioned, except when done right.
PHP's source is a hell of a mess and tracking down the exact location of
array definition was not easy at all and I had to look up quite a few .h
and greap a bit to find out the one directory it was in:
php5/ext/standard/array.c
Looking inside is like looking into the Devil's guts.  Few comments,
lots of macros defined elsewhere, no clue on how to decypher it.
Python's one is a breeze to find:
Objects/dictobject.c
very logical and just as beautiful to look at as Python code.
Both are in C.
And yes, PHP does incur into the hash cost at all times, even if you
just intend to use arrays as a simple list.  See
"php5/ext/standard/array.c", array_push, zend_hash_next_index_insert.
Python's lists don't have such problem, as any specialized data structure.
It's amazing you can nitpick and even pick a fight for tools you most
likely don't even care, Darren...
Date: 5 Apr 2009 12:22:59
Message: <49d8dae3@news.povray.org>
No. We're comparing PHP's "array" to Python's "dict" and "list."
I said "PHP arrays maintain order." You followed up with "Order shouldn't
matter in a dictionary." Hence the confusion, because you're talking about
Python, while I'm comparing Python to PHP.  I'm not sure why you're saying
anything about "should" if you're talking about "is".
>> Python doesn't.
And if several people need order-preserving keyed-access data structures,
you have a problem knowing which one you want.
Not when you have the choice of implementing something in C or implementing
it in Python. Python will almost always lose in that case.
Now you're talking about performance comparisons, when 3 sentences up you
said you're talking about Python dicts. See my confusion?
Why do I need the sources?
I'm not arguing that PHP is better than Python. I said that Python dicts
aren't as powerful as PHP arrays. Also, Python lists aren't as powerful as
PHP arrays. I have no idea how you go from there to "Python's source code is
better commented than PHP's source code."
I'm just trying to understand your point, having a conversation. If at the
start you'd said "A dict or a list is going to be more efficient than a
combination of the two", I wouldn't have argued in the least. But that isn't
what you said, implying that there was something about the topic you could
teach me. Like there was some deeper, more subtle thing wrong with combining
the two than "it's less efficient if you don't use all the features."
Date: 5 Apr 2009 12:47:32
Message: <49d8e0a4$1@news.povray.org>
BTW, what tools do you think I'm fighting over?  You need to go back and
reread the thread.
I say "PHP arrays have a feature that Python dicts don't." (More precisely,
in spite of triple_r saying "And dictionaries? Outstanding.", that Python
dictionaries are no different from bog-standard hashtables, unlike in some
other languages.)
You are the one that turned it into "Python rulez! PHP Suxors! PHP is
*wrong* and Python is *right*, and if you can't see that then a thousand
years of mathematicians prove you're stupid!"
I wasn't turning it into a fight at all. I was just being polite and
pretending you actually had a reason for turning it into a discussion rather
than a cheerleading fest, including reading source code of each interpreter
and commenting on the genetic lineage of the authors thereof.
Had you just said "The rest of Python rocks", or "unnecessary features
universally applied can be inefficient", I would have agreed. But you said
"this data structure is incorrect", implying there was something outside the
API of the data structure that would be relevant to other data structures.
I like Python. It's my new favorite language, or will be once I get good at
it. PHP is the suckiest language I've ever been forced to use, with
essentially no redeeming qualities. (Worse even than C++ which *does* have
many redeeming qualities. :-)
So don't give me this "you started a fight" crap just because I was polite
and gave you the benefit of the doubt that you weren't trying to.
Date: 5 Apr 2009 15:05:02
Message: <49d900de$1@news.povray.org>
Darren New wrote:
>>>>> tables."
No, you said "A /dictionary/ in PHP is more like an array of key/value
pairs." if I may nitpick.  Then I replied a dictionary is a hash table
and order is not important in a hash table.
> shouldn't matter in a dictionary." Hence the confusion, because you're
> talking about Python, while I'm comparing Python to PHP.
I was not talking about Python when saying order shouldn't matter in a
dictionary.  You look things up in a dictionary, individually.
> implementing it in Python. Python will almost always lose in that case.
What is Python losing here with its specialized data structures,
implemented in C?
>> function over the item, a Python list won't.
> you said you're talking about Python dicts. See my confusion?
Why confusion when you understand perfectly well I'm now talking about
performance and its relation to specialized data structures, and thus,
dicts?
To see I'm not lying?
> as PHP arrays.
But they are, for their respective jobs.
> the start you'd said "A dict or a list is going to be more efficient
> than a combination of the two", I wouldn't have argued in the least.
Oh, you would, sir.
> that isn't what you said, implying that there was something about the
> topic you could teach me. Like there was some deeper, more subtle thing
> wrong with combining the two than "it's less efficient if you don't use
> all the features."
It's a question of principles:  specialization is good and a dict is a
hash table, an unordered set.
Date: 5 Apr 2009 15:08:14
Message: <49d9019e@news.povray.org>
> polite and gave you the benefit of the doubt that you weren't trying to.
Well, sorry.  You politeness always sounds like trolling over nitpicks.
Date: 5 Apr 2009 15:53:00
Message: <49d90c1c$1@news.povray.org>
A dictionary isn't a hashtable, tho. A hashtable is a hashtable.
I dare you to look up a word in Webster's dictionary if it's not in order.
"Hashtable" has a language-neutral definition. "Dictionary" does not, nor
does "map". You might want to look at (say)
http://en.wikipedia.org/wiki/Dictionary_(data_structure)
before you try arguing.
> implemented in C?
Then you're not implementing your specialized data structure in Python, are
you? If you want an ordered dictionary in Python, you can implement it in
Python, or in C. The implementation in Python will almost always be slower
than the implementation in C when you do that. It's losing efficiency, to
precisely answer your question.
However, ordered dictionaries in PHP (called "array" by the language) is
already in the language and implemented in C, do you don't need to try to
implement it in PHP, assuming the order you want is what PHP provides.
> dicts?
You keep bopping between "hashtable" and "dict" and "dictionary", which are
three different concepts.
About... PHP arrays being slower than Python dicts? Perhaps you haven't yet
gotten to my post where I gave the timings.
>> I said that Python dicts aren't as powerful as PHP arrays. Also,
>> Python lists aren't as powerful as PHP arrays.
This makes no sense to me. If you're comparing the capabilities of different
data structures, you don't exclude everything that one can do that the other
can't in your comparison. That's like saying a bicycle goes just as fast as
an automobile, as long as you don't leave the driveway.
> Oh, you would, sir.
You're dreaming.
I disagree that specialization is necessarily good. You're taking it as an
axiom without any support. I'm just trying to figure out if you had some
support, or whether you were arguing that everyone should accept your axiom
unquestioned.
I *thought* it was beginning to sound like a religious argument.
Date: 5 Apr 2009 15:54:18
Message: <49d90c6a@news.povray.org>
Somehow, asking people to support their assertions of facts always seems to
sound like trolling. I wonder why that is.
Date: 5 Apr 2009 18:00:13
Message: <49d929ed$1@news.povray.org>
> to sound like trolling.
Do you have a reference to back that up? ;)
