POV-Ray : Newsgroups : povray.off-topic : stupid XP SP3...needs to piss off a little Server Time
13 Sep 2025 03:33:29 EDT (-0400)
  stupid XP SP3...needs to piss off a little (Message 16 to 25 of 25)
Subject: Re: stupid XP SP3...needs to piss off a little
Date: 2 Apr 2009 11:30:06
Message: <49d4d9fe$1@news.povray.org>
scott wrote:
> Of course some people have different experiences, but I've been running
> Vista for a while now as my main work machine (and at home) and have
> never had any stability issues.
Same here. There's a couple of annoyances. I like the Vista media center
less. If I do a chkdsk during boot (which I do before making a ghost
backup), sometimes some programs won't start, as if there's some system
library or service they're depending on that didn't get initialized until I
reboot again.  Other than that, no problems here.  Hard to judge the speed
since I upgraded the processor and drives as well.
> Actually the new GUI uses your 3D card to draw the graphics, under XP
> your 3D card sat idle while the CPU did all the graphics...  BTW you can
> always turn it off if you don't like it.
I like the new GUI. It has benefits besides just the glass borders. The
drawing all happens in the background and gets composited, so it's real easy
for the system to give live thumbnails of a program's window and stuff like
that.
It does thrash a bit more than XP did with the same amount of RAM, but not
so much as I find it a PITA. Just lots of disk activity when you switch
between big programs. I think it manages to keep a much better track of what
parts of the working set need to be swapped in first.
   There's no CD like OCD, there's no CD I knoooow!
Date: 2 Apr 2009 11:34:51
Message: <49d4db1b$1@news.povray.org>
scott wrote:
>>  Have you ever heard of the concept of disk caches? You can even
>> configure
>> how much is cached.
> Isn't Vista's SuperFetch just a very clever disk cache that uses more
> RAM than its predecessors?
Sort of. It's more like a cache prefetch/readahead, based on the paging
behavior of previous runs of the same program. Plus, if a program gets
swapped out by something, when that new something exits, the old program
gets swapped back in preemptively rather than on demand, making the system
more responsive.
> Really, what is the disadvantage with keeping as much stuff from disk in
> RAM as possible?  It just seems silly to me to erase stuff from RAM for
> the sole reason of making the "free RAM" counter higher, why not just
> erase it later when that RAM is actually needed by something else?
I think you're talking past each other. Scott is saying the kernel uses up
all free RAM as disk buffers. Warp is saying "why would you want the kernel
to use up all memory?" Clearly using it as a resizable cache is a good idea,
while using all memory for something the kernel cannot discard when needed
is a bad idea.
Date: 4 Apr 2009 06:26:40
Message: <49d735e0$1@news.povray.org>
On 4/2/2009 12:44 AM, scott wrote:
> That's 2D acceleration, not 3D. In the graphics card it's quite
> separate,
For the past several years, they've been the same thing.  You just
access them using different API calls.
...Chambers
www.pacificwebguy.com
Date: 4 Apr 2009 06:31:35
Message: <49d73707@news.povray.org>
On 4/1/2009 11:31 AM, Warp wrote:
> [GDS|Entropy]<gds-entropy    AT    hotmail   DOT  com>  wrote:
>> I'd be happy to stay with xp pro...but MS seems hellbent on forcing the
>> issue with pissta, and that I do not like..
>    That's one of the problems with Windows: You are more or less forced to
> submit to whatever whims Microsoft may have today. (The only other
> alternative is not never upgrade your system, leaving you wide open to
> any discovered security holes.)
That's one of the problems with providing commercial software: you have
to actually pay your support staff!
MS can't (or won't) afford the staff to support 3 versions of Windows
simultaneously, so they're trying to cut down.
Makes perfect sense to me.
...Chambers
Date: 4 Apr 2009 09:08:49
Message: <49d75be1$1@news.povray.org>
MS might actually stand a chance to afford that. They won't, because
it's not profitable.
-Aero
Date: 4 Apr 2009 12:05:40
Message: <49d78553@news.povray.org>
  That doesn't change in any way what I said.
Date: 5 Apr 2009 22:17:25
Message: <49d96635$1@news.povray.org>
No, but you seem to be criticizing them for not supporting older
operating systems.  I merely pointed out that their refusal to support
older OSs makes perfect business sense.
...Chambers
Date: 6 Apr 2009 11:15:32
Message: <49da1c94@news.povray.org>
  I didn't criticize them for not supporting older versions. I said that
if you use Windows, you will at some point be in the situation that you
will not be getting any security updates anylonger and you will be forced
to buy a new version. Not only will the new version cost quite a lot of
money (I bet usually more than your current version), but the differences
between Windows versions are rather big. If you don't like the new version,
then you are stuck.
  (The main problem with Microsoft is that they have this mentality that
every new version of Windows has to look different just for the sake of
looking different. Whether the change actually improves anything, or on
the contrary, degrades usability, is completely irrelevant.)
Date: 7 Apr 2009 00:07:30
Message: <49dad182$1@news.povray.org>
It sells, if something :(. Most people won't understand a bit if you
tell them you've rewrote memory management and tweaked the scheduler,
but they do understand if you tell them you have a new shining desktop
environment available.
-Aero
Date: 7 Apr 2009 23:21:38
Message: <49dc1842$1@news.povray.org>
Fair enough, it sounded like criticism but it seems you didn't intend it
that way.
> but the differences between Windows versions are rather big.
If the differences were small, why would anyone upgrade?
 From what I understand, it's the users that are the problem, and MS
doesn't like it any more than you do.  But, they have to eat, which
means they have to sell the new OS, which means they have to convince
people to buy it... which means, if they put a lot of work into the
system, and make it really great, and give it the same look and feel,
people will just go "Huh?" and move on.
The problem is one of noticing things... ideally, an OS shouldn't even
be noticed.  Of course, if you don't notice your OS, then you probably
don't think about buying a replacement either.
MS is in the sticky situation of needing people to notice their OS to
sell it, but needing people to NOT notice it for them to like it.
...Chambers
