It's not Italian. ;-)
I'm blogging all this... I'll post the thing when I'm done.
http://blog.orphi.me.uk/archives/350
Well, since your blog won't let me sign up to comment, and you don't post
your email address here, I guess I'll put the reply here. :-)
Some hints: I suggest before you set up anything serious on the laptop, you
test the recovery disks so you know what they do. :-) Best time to do it,
after all. (And yes, I'm guessing with two DVDs it does the same thing as
the gateway recovery disks do: Puts it back to factory fresh, then uses the
second CD to install drivers after you "restore" the Vista install.)
As for the start menu and the control panel: use the search bar. It's way
way faster than trying to find something in the menus. You want mah jong?
Type "mah jong" in the search on the start menu. It actually works right.
The "measuring performance" is indeed checking things including your
graphics, RAM speed, disk speed, etc. Go to you start menu and search for
"welcome", then go to "view computer details", then "Windows experience
index" if you care. That'll also tell you the OS bitwidth, RAM, etc.
And yes, you can turn off the transparency and put the start menu back.
Right click on the desktop and pick "personalize", or right-click on a blank
part of the task bar and pick "properties".
The machine will likely be slow until you leave it on overnight or so, while
it builds search indexes and recovery snapshots stuff like that the first time.
Sound-wise, you can get "true surround sound" by plugging it into a dolby
system, even if your speakers aren't good enough. I.e., they're describing
the audio card, not necessarily the speakers.
eSATA: external SATA. If you have an external drive case that supports USB
and eSATA, use eSATA and it'll be about 4 times as fast to transfer.
HTH. :-)
There's no CD like OCD, there's no CD I knoooow!
> post your email address here, I guess I'll put the reply here. :-)
Interesting. I have an email from WordPress notifying me that you just
signed up... ;-)
> you test the recovery disks so you know what they do. :-) Best time to
> do it, after all. (And yes, I'm guessing with two DVDs it does the same
> thing as the gateway recovery disks do: Puts it back to factory fresh,
> then uses the second CD to install drivers after you "restore" the Vista
> install.)
Perhaps. I was kind of expecting the second DVD to burn quicker than the
first one - but no. Exactly the same speed. Both took about 20 minutes
to burn (and another 10 minutes to verify).
1. What's that?
2. You need to search for stuff = you haven't organised your stuff
correctly.
Why does that take 20 minutes? memtest86 gives me most of those
measurements in 0.2 seconds.
> for "welcome", then go to "view computer details", then "Windows
> experience index" if you care. That'll also tell you the OS bitwidth,
> RAM, etc.
For some reason, the welcome page automatically opens every time I log
in and won't go away. Apparently the Windows experience index is 3.6. I
didn't see any more detailed stats - but those are probably under
"advanced" or something.
> blank part of the task bar and pick "properties".
Already found out how to turn off transparency - but I kinda like it. As
I say, if you give it a slight tint, it makes it visible.
> while it builds search indexes and recovery snapshots stuff like that
> the first time.
I was wondering why the HD runs *constantly* and never, ever stops, even
when the machine isn't doing anything. Nice to know that Vista has
built-in systems to waste my time and computer power on pointless tasks
that I don't want it to do. :-) Clearly M$ have put a lot of work into
keeping computers slow to encourage the purchase of new, faster ones.
> USB and eSATA, use eSATA and it'll be about 4 times as fast to transfer.
Mmm, OK. But... they have the same electrical interface?
Also amusing was the manual's description of the covers on the bottom.
One is labelled "harddrive" and the other is labelled "secondary
harddrive". What, you mean you can put two in it? I suspect not! ;-)
On Fri, 03 Apr 2009 22:36:42 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
> 1. What's that?
http://images.google.com/images?q=vista%20%22start%20menu%22%20%22search%20bar%22
> correctly.
You will also find that the start menu in Vista expands sub-menus in place
rather than to the right. Decide for yourself if this is a good idea or a
horrible disaster.
1. It does not take 20 minutes. A few minutes at the most.
2. How else would you perform a benchmark other than running tests and
timing them?
Uncheck the box marked "Show the Welcome screen every time I log in".
Not quite, but close enough to provide basic compatibility.
http://en.wikipedia.org/wiki/Serial_ATA#External_SATA
FE
> signed up... ;-)
That doesn't help much if wordpress doesn't mail me the password. :-)
Some DVD burners (software) insist on writing the entire DVD whether there's
useful content or not.
> 1. What's that?
Open the start menu. See the bottom left, where it says "start search"?
> correctly.
Perhaps. But since you're not especially in control of how the start menu is
organized a priori, it helps.
Dunno. It takes about 5 on mine, IIRC, but then I have a kick-ass graphics
card. Much of the time is spent evaluating the abiltiy to scale textures, do
shadows and lights, stuff like that.
The checkbox at the bottom that says "Show this every time windows starts"?
Uncheck that.
See the link next to the rating? Click on that.
Yes. It's cool. It confused my wife till we set it to black for her.
Well, turn it off, then. It stops after it finishes.
As what? USB? No, of course not. Different shape connectors. I'm not sure
whether it's the same as SATA, but I'm not going to crawl under my desk to
check. :)
Possibly. Why not?
>> signed up... ;-)
OK, that's pretty random.
> graphics card. Much of the time is spent evaluating the abiltiy to scale
> textures, do shadows and lights, stuff like that.
Mmm, OK. It just seemed to take an absurdly long time to do whatever it
was doing. (And nailing the HD while it was doing it.)
> starts"? Uncheck that.
Yeah, I already found that. ;-)
> Possibly. Why not?
You mean other than issues of space, battery consumption and heat
dissipation?
For some reason, every few seconds the WiFi light flashes. Anybody have
any idea how I can completely disable WiFi? (If it were up to me, I
would have purchased a laptop that doesn't *have* WiFi, but for some
reason that appears to be impossible...)
Specifically, I'd like to make absolutely sure it can't connect to any
networks of any kind, and that it isn't wasting battery power trying.
Since the test of the HD takes about 15 seconds here, I'm expecting your
laptop was doing other things during the test (like building search indexes)
or was swapping.
Disabling it in Network Connections doesn't do the trick?
