Darren New escreveu:
> Warp wrote:
>> In my little experience, trying to use a programming paradigm (eg. OOP)
>> with a language which has no specific support for that paradigm (eg.
>> traditional lisp or scheme, or C) only creates a ton of kludges.
> Actually, LISP has excellent support for OO. It has closures (which are
> objects without the types, not unlike javascript objects) and it has
> macros that let you Do The Right Thing with the syntax and integrate it
> cleanly into the language. It's not going to look like Java/C++/C#/etc
> classes, but I'd disagree it's a kludge.
More than that, Common Lisp has CLOS:
http://en.wikipedia.org/wiki/Common_Lisp_Object_System
> I don't remember scheme enough to know how clean it is, and I'll agree
> with you on the C part. :-) And that's not to say there aren't things
> that would be very difficult to do in LISP without native support built
> into the language (like some forms of control flow, for example).
Are you kidding? One of the main strenghts of Lisp is its macro system.
Not dumb C preprocessing, a metaprogramming features which allows you
to create nice new syntax for any control flow you want.
See:
http://www.paulgraham.com/onlisp.html
Scheme itself lives up to its original goal as a minimalist and
incredibly flexible and powerful language. See for instance an
implementation of a full-fledged, purely functional object-system:
http://okmij.org/ftp/Scheme/index.html#pure-oo
This is done purely with functions and will look awkward for Warp in the
way they are called, but thing is: one layer of macros later and it
looks just as integrated into the language as if OO was always there.
Yes. I was trying to describe that it doesn't have to be built in, tho. :-)
I like CLOS.
(I don't know if CLOS counts as "built in" or not.)
>> built into the language (like some forms of control flow, for example).
Didn't I say that? :-)
Cool. Thanks for that.
My fortune cookie said, "You will soon be
unable to read this, even at arm's length."
It is.
That guy has all sorts of cool stuff, either in Scheme, Haskell or C++.
The "On Lisp" book by Paul Graham is very good too. It's available in PDF and
explores Lisp macros as no other.
Yep. Got it, read it. :-) I wish I had a use for it. :-)
Subject: Re: This is the sort of brokenness...
Date: 16 Mar 2009 21:15:02
Message: <49bef995@news.povray.org>
Heh, did you see the GObject framework?
Date: 16 Mar 2009 21:18:30
Message: <49befa66@news.povray.org>
Darren New wrote:
> ... that I hate seeing in a popular language. Backwards compatibility for
> a language already rushed out the door is really a killer, IMO.
> http://vijaymathew.wordpress.com/2009/03/13/dangerous-designs/
OMG, *that* is how they implemented it?!
Dude, slow down on that coffee! X^D
Heh. Got it, read it many moons ago.
Yeah. Generics are kludged in approximately the same way, with the extra
excuse that it allows generic code to interoperate with previously compiled
non-generic code.
They've locked themselves into a specific JVM, and nothing can change that now.
Warp <war### [at] tag povray org> wrote:
> sounds like you could argue in favor of languages like brainfuck which
> have a minimal set of instructions, yet are still Turing-complete.
Scheme:
Minimalist. check
Power. check
Flexibility. check
Brainfuck:
Minimalist. check
> Eg. just because tail recursion is enough to perform any kind of
> looping construct doesn't necessarily mean that special looping constructs
> wouldn't be a useful tool.
That's why you got for-each in the standard and a few more. (which, obviously,
are macros wrapping tail-recursive calls)
"Like the OO systems in most dynamic languages, CLOS does not enforce
encapsulation. Any data member (or slot) can be accessed using the
slot-value function or via (optionally auto-generated) accessor
methods."
Your definition of object-oriented programming may vary, but in my view
data hiding, ie. modularity, is an integral part of OO programming. If the
internal structure of the object is exposed to the outside, you lose most
of the benefits of modularity.
I think that the typical impossibility or difficulty in data hiding in
languages which do not have specific support for modularity is a sign that
the "OOP" is, after all, just a kludge.
It's pretty easy to fix in LISP if you really care - just make all your
local names gensyms. (If we're still talking about minimal support for lots
of paradigms, you could do this with some pretty simple macros, methinks.)
CLOS doesn't do this, because people who use LISP are usually pretty good
programmers.
> If the
Like, in unsafe languages, where a stray pointer can change private
variables without going thru the class methods? :-)
By this factor, I know of almost no actual OO languages besides Smalltalk
and Ada. (And Ada has OO features without being what I'd call an OO
language.) And I'm not sure you can't cast pointers inappropriately in Ada,
either. I'll look it up some day when I'm bored. :-)
C# and Java both have reflection that let you get to private members from
outside. C++ not only lets you return pointers to private members (which
isn't particularly bad in *my* opinion, see below, but you might disagree)
but also allows unsafe (in the technical sense[2]) access to private members
via undefined operations. It's pretty trivial to bypass all the modularity
in C++ since you need to be able to see the class declarations of the
private parts in order to access the class[1]. Python has the __dict__
element (et al) even if you had private variables. Pretty much anything
designed so you can serialize it has external access to private members.
Now, ya see, I see the point of modularity is to let me reason about the
code. If I have a private integer X, and the only things I set it to are 0,
1, or 2, then I should be able to have a switch with those three cases and
never miss one. Or, for a better example, if I have a buffer, and my class
is the only thing that writes to the buffer, I can ensure I never have a
buffer overflow. This isn't the case in C++ any more than it is in LISP or
Python. The only difference is, in LISP it's much harder to break by
accident. I don't see the advantage of making variables private if the
privacy isn't enforced well enough to give me more guarantees about the
program's execution. It's like having type declarations that aren't checked
at compile time or runtime - what's the point?
It would seem to be no harder to track down a bug caused by someone
accessing a private variable in a LISP object inappropriately than it would
be to track down someone overflowing a public array and clobbering a private
member in C++, especially since in LISP you'd actually have the name of the
private member somewhere in the source code module causing the trouble.
What do *you* think modularity is good for, that simply saying "stuff that
starts with an underline is private to the class" isn't adequate? I'm
seriously asking, because I'm wondering if I'm missing something.
[1] For example, you could declare an identical class with a different name,
except with all the privates public, then cast a pointer to the private
class into a pointer to the public class. Don't even need to depend on
compiler-specific knowledge about element layout and such. Or just declare a
child class that is happy to change any of its private variables.
[2] "Unsafe" means there are features with undefined behavior which may
affect the future state of the program, such that you can put values of the
wrong type into variables. That is, you can put values that don't belong to
the type into a variable of that type, or access values inappropriately
(such as accessing private variables from outside the scope you're supposed
to access them from).
> lots of paradigms, you could do this with some pretty simple macros,
> methinks.)
> good programmers.
Yes. Straight-jackets are generally viewed as a limiting "feature" by
people who actually know how to program rather than being a low-paid
drone. What really amazes me is when very smart programmers actually
enjoy being in the jacket and ask for more. :P
The best I've ever read on the subject comes from Larry Wall:
"The trend over the last 25 years or so has been to design computer
languages that enforce a state of paranoia. You're expected to program
every module as if it were in a state of siege. Certainly there are
some feudal cultures where this is appropriate, but not all cultures are
like this. In Perl culture, for instance, you're expected to stay out
of someone's home because you weren't invited in, not because there are
bars on the windows."
http://books.google.com.br/books?id=oh8lz4A3sUsC&pg=PA289&lpg=PA289&dq=larry+wall+house+invited&source=bl&ots=NcO4joArZd&sig=SaR-z_PriPfBbQaxNRAHpBfD_gc&hl=pt-BR&ei=dynBSYutLNuvtwfE0MXSCg&sa=X&oi=book_result&resnum=3&ct=result
Of course, such attitude would not stand the barbarism going on in
enterprise by thousands of code monkeys typing a bad rerun of
Shakespeare, but for one guy or 2 in the know alone working on a private
project, giving up all bureacratic measures for you not to shoot your
own foot may lead to an increased productivity with no sensible bug issues.
I think by the time you get people so disconnected from each other that you
have to literally defend your code against them, you also have a
sufficiently big management structure that you can afford code reviews and
things like that. And if someone *does* need to bypass your API and access
the private variables, chances are you can either (1) get them to change the
implementation of the public API, or (2) if the author is (say) in another
company, it's a good thing you can bypass the lack of ability to do what you
need. :-)
> methods."
BTW, this is only true in CLOS. If you actually implement OO using closures,
this isn't the case.
As a sort of C++ equivalent, consider C++'s upcoming lambda expressions. If
you write something like
{ int x, y;
x = 3; y = 4;
std::function pdq = [x,y](z) {return x+y+z;}
x = 8; y = 9;
// What here could you write to get the "4" that's in y inside pdq?
(Assuming I'm close on the syntax, and I think I'm saying pass x and y by
value to the pdq lambda thingie.)
Building OO via closures is like that, except the x and y serve the purpose
of instance variables. (C++ doesn't have actual closures, so the analogy is
flawed here, of course, but if you don't see how closures can make objects,
that should clarify it.)
If you could pass x and y by reference, declared several std::functions that
used them by reference, and then return collection of those functions
without actually losing the stack frame those referneces referred to, you'd
have objects-on-closures, with no access to internal instance variables.
Date: 18 Mar 2009 13:43:54
Message: <op.uqz0vkjo7bxctx@e6600>
On Wed, 18 Mar 2009 17:44:23 +0100, Darren New <dne### [at] san rr com> wrote:
> name, except with all the privates public, then cast a pointer to the
> private class into a pointer to the public class. Don't even need to
> depend on compiler-specific knowledge about element layout and such. Or
> just declare a child class that is happy to change any of its private
> variables.
Except that the compiler is not required to generate the same layout in
those two cases, so you would still depend on compiler-specific knowledge.
FE
> programmers.
No. Crappy programmers (self-taught "hackers") want everything exposed and
can't understand the reasoning behind data hiding. Good programmers understand
this reasoning and for that reason use data hiding and abstraction.
> > If the
No. The reasoning behind data hiding in modular thinking is completely
independent of the language used. It has to do with program design.
If you expose the internal structure of a module to the outside, then
there's a big chance that outside will start making *assumptions* about
this internal structure. As an example, a module describing the concept
of a "color" might have four integral variables as members, one for each
color component. If this fact is exposed to the outside, then there's a
big chance that some code somewhere will assume that the "color" module
has four integral member variables with certain names.
If this happens, then you can't change the internal implementation of
this module without breaking existing code. For example, if you wanted
to change the color components to floats, or you would want to pack the
color components into one single integral value, you will most probably
break existing code (especially probable in the latter case, as the
amount and names of the member variables will change drastically).
If you can design the absolutely perfect module which will never change
its contents and will suffice for years to come, then by all means make
all members public. Us mortals will try smarter techniques.
> outside.
Thus it's one reason why the design of these languages is badly broken.
Only if the class itself explicitly does so. You can't get to the private
members *from the outside*. (Well, at least not without some serious
hacking.)
It's usually considered bad design in C++ to return pointers to members.
I don't understand what you are saying. If a class in C++ does not expose
a member array, then you can't get to that member array from the outside,
and if the class' own functions are properly designed, no buffer overflow
is possible (precisely because you *can't* access the array from the
outside).
You might be able to control your *own* code from not misusing public
variables (and you might never make mistakes), but it's more difficult to
control someone else.
If you need to tell someone else "don't access member variables whose
name start with an underscore", that's just plain stupid. You should be
able to tell that by making the *compiler* enforce it.
I'm sorry, but that simply doesn't follow. If the guy is stupid enough
to use things not in the interface I give him, it's his problem if he's
f*cked down the road. But I agree with you: dumb programmers like that
should wear a straight jacket, no doubt.
> drone.
No, data hiding is seen as "limited" by self-taught hackers who don't
know jack s**t about programming. Those people just can't understand what's
the idea, and want everything to be accessible.
I enjoy being able to create modules which I can safely improve later
without the fear of breaking existing code. And I'm talking from actual
experience, rather than theorethical handwaving.
What a load of BS.
Increased productivity... until the day that you actually need to heavily
change some module because of new requirements or improvements, and you end
up breaking thousands of lines of code which are carelessly using public
members as they please.
Of course rather than admit their design mistake, they will just use some
fancy term for this, such as "refactoring".
Why not? Having the compiler check for breaking of agreements (eg. "don't
access these variables") is much better than oral agreements. The compiler
is much better at catching mistakes than you are.
Warp escreveu:
It's not because it's accessible that it is going to be used. It is
only accessible because the implementation didn't care to bother putting
loads of chains and belts and bureaucratic measures that are there only
for the sake of bad programmers who can't understand the concept of
interfaces and have to have their knees broken so they can't jump the fence.
For people who know it better, the lack of such measure does not mean
irrestrict access to things, it simply means less stupid typing to make
the compiler happy. Modularity is conserved.
Why would you fear breaking your own modular code with clear interface?
Are you yourself using things you shouldn't? Why are you blaming the
implementation then?
It's all about scope. If it's public, it should be used. If it's not,
you shouldn't.
Scheme/Lisp has no problem with any of that though. First because of
lexical scoping: if you need to use an accessory function, you can
simply declare a local lambda in the outer function and no outside
functions will reach it. Second, because modules are truly modules and
though you may declare many functions, you only explicitely export some
of them. And functions not exported are truly not exported, you can't
reach them, using whatever dirty hacks you wish.
In languages other than LISP (say, Python or PHP or whatever), this is
handled by having a naming convention saying what variables are to be
treated as private.
I'm not sure I see the benefit of "I use private: in my C++ classes" to "I
put an underscore before private names in my classes." Other than a touch
of readability (which many C++/Java/etc programs violate by tacking things
like "m_" to the front of every member variable) I don't see a whole lot of
difference.
Certainly if should-be-private members are exposed as public but don't
document to the user which are private, that's a problem.
You still get subclasses. And of course there's always the hack of declaring
a subclass. Or just using compiler-specific hackage to access the variables.
or the infamous "#define private public". But correction noted. It's just
irrelevant to the point I was making. :-)
> Warp escreveu:
Yeah, sure. If you are the *only* person making the entire program, then
perhaps that might be the case.
> It is
So in your opinion the concept of "interface" is a verbal agreement about
what should and shouldn't be used from a module? *That* is what sounds like
bureaucracy to me.
And why is a verbal agreement better than telling the compiler about the
interface?
In Utopia, maybe. In the read world, not so.
And I don't consider having to write "private:" once to be significantly
more typing. If I had to document what you should and should not access
in the module, *that* would be significantly more typing. And the kind of
text which most people will not read anyways.
Maybe you, Mr. Perfect, never make mistakes. I like the compiler telling
me possible mistakes, especially since telling the compiler what the interface
of my module is, is rather simple.
Also, if I make a module for others to use, how can I guarantee that
I can change the implementation later without breaking code others have
written? There are two options:
1) I write "private:" once in my class definition.
2) I write extensive documentation about the subject and hope people will
read it and obey it. Many people won't.
Which one of these two options is easier and less trouble?
> you shouldn't.
And what's wrong with the compiler telling you if you try to use it
regardless? I really can't understand that.
The compiler is not limiting anything that you aren't *already* limiting
by your verbal agreement. The only thing the compiler is doing is checking
that the agreement is not broken. Why that is a bad thing is beyond my
comprehension.
I thought you were old enough to know some basic facts of life:
Rule #1: People *don't* read documentation.
Rule #2: Read rule #1.
Rule #3: Even if people read documentation, they do not have photographic
memory and they forget.
Rule #4: Humans are imperfect and make mistakes.
Why is it a bad thing to make the compiler check interface breaches is
beyond my comprehension. It's enormously easier to do than writing some
documentation and *hoping* that people will read and obey it, and never
make mistakes.
Warp escreveu:
Now I (think I) understand the root of our disagreement. I'm thinking
about functional programming here with only functions accessible per
interface, you're thinking about what variable can be accessed and
whatnot in a severely mutable setting. It all becomes really hard when
you allow state to dominate. So hard that even very experienced
programmers can face dificulty handling it all, thus having to invent
all sorts of levels of accessibility rather than just rely on lexical scope.
> a subclass.
A subclass can't access the private members of the base class.
That has been made rather difficult in practice. If you are *intentionally*
trying to break your program, then that's your choice, of course. However,
in normal usage it's useful if the compiler checks that you don't make
mistakes.
Whether your program will link after that can depend on the compiler.
It's certainly not standard-conforming. And again, you are hacking on
purpose, trying to bypass the compiler checks, rather than using those
checks to catch your mistakes.
> Warp escreveu:
Not all member functions have to be public either. It's extremely common
for a class to have private member functions which are part of its internal
implementation and not even intended to be part of the public interface.
I would say that being able to define private member functions is equally
important as being able to define private member variables.
Warp escreveu:
Like I said, if the dumbass wants to use things not in the interface,
it's his risk.
> bureaucracy to me.
Not bureaucracy at all. Just a list of names of functions a module
provides.
Indeed. In real enterprise world we got people who don't enjoy nor know
how to program, programming. Or, should I say?, fill up a few forms and
allow an IDE to generate the code. It will spill shit all over, true.
> more typing.
Indeed, Delphi and C++ are yet more zippy at that, not so much for those
poor Java souls... you also forgot the data type declarations.
This coming from a guy whose favorite language needs for one to provide
the source and the header file.
> And the kind of
It's usually the first thing one sees when opening a module. (export
foo bar boz frob etc)
> written?
Don't change the interface. Of course, if the implementation is changed
in such a buggy way as to totally alter the behaviour, same interface
doesn't mean jack.
>> you shouldn't.
Nothing wrong except quite a few more tiresome and bureaucratic measures
before actually writing anything.
> comprehension.
I was not saying that is bad. I was just reacting to this: "Your
data hiding, ie. modularity, is an integral part of OO programming."
Modularity is still there regardless of dumb programmers ripping their
contracts and no middleman to prevent them doing so. But I'm thinking
here on a typical Scheme module of old, before true modules, and where
all you had was a list of functions and lexical scoping, not a C plain
text file with lots of variables and variable-dependent functions lying
all around.
OK. I guess you look it as "if you bypass the documentation and access
members not documented, I have to support your brokenness forever." I look
at it as "if you're coding from the implementation instead of the
documentation, you get what you deserve" combined with "don't make me debug
my code when the bug is in your code."
Sure. Most of these languages (a) document what's public and what isn't, and
(b) have a language-wide naming convention for it. That is, after all, what
C++'s 'private' tag is - a naming convention.
>> outside.
I think it's more a trade-off than you make it out to be.
That's why I said it wasn't much of a breakage in my view.
> (Well, at least not without some serious hacking.)
Running off the end of an array is "serious hacking"? I wouldn't think so.
int * p = (int *) 0x123456;
*p = 27;
Find the bug in your code that's setting that member variable to 27.
How about
// Your code...
class xyz {
public: int[10] x;
private int y = 0;
// My code
xyz pdq;
pdq.x[10] = 27;
Sure. See above examples.
I agree, except for the fact that you're using C++ as an example. :) C++ has
it's own different lack-of-modularity problems. If the compiler actually
*enforces* that the member variables you declare private can only be changed
by your own methods, that's great.
"don't access member variables whose name starts with an underscore" is the
kind of rule that's enforced all through a codebase or a programming
language. The little extra warning the compiler is going to give you is
generally not of much benefit if someone's going to violate that rule
anyway, IME. In other words, if they really need to violate the privacy of
your class, they're going to do it in C++ almost as easily as they do it in
something like Python or LISP. The compiler doesn't enforce the
encapsulation in C++ - it just gives warnings when you use a variable name
that's private. There's no enforcement at runtime, and plenty of back doors
at compile time. Contrast with, say, C#, where you don't even know what the
private variables are named, and you couldn't access them if you did,
because the runtime enforces that - there, the only backdoor is the
reflection libraries that specifically are bypassing the privacy checking
system. Using reflection (or explicitly assigning to _private members) isn't
any more common or more prone to abuse than ((int*)0x12345)=27; is,
particularly because the user has to explicitly know they're violating
encapsulation when they write the code.
Granted, if you don't *document* in a universal kind of way what's public
and what isn't, you're leaving yourself open to abuse.
But there are a lot of people who don't want to write a ton of boilerplate
code for a function that could be automated, so they're willing to say "if
you use introspection to read and write my structure over the wire, be
aware it may change in other versions." It's better to say "this will break
with future versions" than to say "I'm going to write 5000 lines of
boilerplate code to allow clients to send my values over the internet or
into databases."
There are also a whole bunch of assumptions in your classes that someone is
going to rely on that you're not going to be able to prevent. SimCity
assumed memory you called free() on would still be valid until the next
malloc(), which is obviously a bad assumption yet still has to be supported
by the infrastructure if you expect to run simcity on later versions of the
OS. If you store your object outside of memory or interact with any other
objects, you're also going to have random dependencies created - someone is
going to have to change database schemas to store your objects in a
database, or change buffer sizes if you switch from JSON serializiation to
XML serialization without otherwise changing your interface. There will be
people who assume your class only invokes their getter method once, if
that's how you first code it, and if you change to invoking it twice, they
may very well fail out (because they're pulling the next row from a database
for each invocation, say). Or, in short, you can't protect against bad
programmers, and anyone half-decent isn't going to be frobbing private
variables to start with, IME.
Rule #5: Best documentation is the code. ;)
Warp escreveu:
Exactly. Lexical scoping takes care of that. For languages which allow
conveniently-definable lambdas, that is.
Warp escreveu:
How this is any different from someone breaking a contract on purpose is
beyond me.
You missed this one:
3) You name your private variables with the naming convention used by
every other package ever implemented in that language, including
the ones that define the runtime, and which every programmer knows
bypassing means future incompatibility.
You already know you're using a private variable, if you're bypassing either
global naming conventions or using reflection or something.
If the compiler actually *prevents* it, then you're locking yourself out of
a whole bunch of metaprogramming techniques that templates aren't adequate
to handle.
Sure. "Don't read documentation" or "forget documentation" is as bad as
"don't document it". But if it's a naming convention used throughout the
language, people don't do it.
How many people name their own function to add a list of numbers as
__builtin_addlist()
in C or C++? Why not? Because everyone who is even a little knowlegable
knows that two underscore names are reserved for the compiler.
First, the whole "dynamic languages" bit at the start should indicate not
everyone has a compiler for these languages. Secondly, it eliminates a whole
raft of useful mechanisms. Where's the C++ library to which I pass a class
and it generates a SOAP interface parser for that class?
>> a subclass.
Yeah, "protected" slipped my mind. It's still not hard to do if you're trying.
Err, has it? I can't say something like
int * p = (int*) ((void*)(&yourInstance) + 32);
if I want access to whatever integer is 32 past the start of your class?
> mistakes.
While I agree, I fail to see why using reflection as intended isn't "normal
usage" and not "a mistake". It's not something you accidentally do. You know
very well you're bypassing encapsulation. Not the least of which is that you
need to give the name of the variable you want to access as a string.
Right. Since you said reflection violates encapsulation hard enough to make
a program not "OO", I'm trying to figure out allowing type casts and
assignment of arbitrary memory addresses to pointers doesn't.
Now, if the statement is "the compiler should be able to warn of external
access to private variables, with the ability of the caller to easily
indicate they know what they're doing," I'm 100% with you.
If the statement is "the compiler should error on external access to private
variables, with no way to get around it," I'm 95% with you, with the caveat
that "that's a pain in the ass way to write generic code that isn't type
specific, because you have to write code generators instead of using the
compiler you already have."
If the statement is "the compiler should error out on external access to
private variables, but there should be a non-portable hacky and error-prone
way to bypass it anyway, so you can't rely in your debugging efforts on what
your code actually says," I'll just have to disagree with you there. :-)
> > bureaucracy to me.
> provides.
I really fail to see how that is different from using a *real* interface
specification, rather than just a verbal one. Except for the fact that with
a real interface the compiler can make sanity checks, of course.
Yes, and these people put everything in the public part of their classes
because they don't have any idea what they are doing. In the same way as
those self-taught hackers who detest all programming paradigms.
> > more typing.
In fact, in C++ you don't even have to necessarily write "private:" at
all because members are by default private (when not inside any access
specifier block).
What source?
> > written?
> doesn't mean jack.
Don't write such BS. I am talking about experience. For example I have
totally changed the internal implementation of this class of mine several
times, and the public interface has always remained the same regardless,
and thus the changes have never broken any existing code:
http://warp.povusers.org/FunctionParser/
And by "totally" I mean literally write everything from scratch. And
no external code breaks. That's the nice thing about modularity. It allows
me to do that safely.
> >> you shouldn't.
Thinking that brevity in programming is a good thing is a really common
beginner mistake. Those are the beginners who, for example, in C++ always
write "using namespace std;" to dump *everything* in the standard libraries
to global namespace because it saves them from typing 5 extra characters
later. Then you get code like this:
i = search(first1, last1, first2, last2);
"Woohoo! I saved typing 5 characters!" And now it's completely unclear
what this "search()" is. Is it a local function somewhere? Is it an external
function defined in some header? Perhaps it's a class which is being
instantiated? Is it a standard library function?
Compare to:
i = std::search(first1, last1, first2, last2);
Now it's completely unambiguous that this is a standard library function
being called.
Brevity is *not* always the answer. Even if I had to write "private" in
front of every single function and variable declaration (as you have to do
in some languages), I would still do it. (Fortunately I don't have to.)
> > comprehension.
I disagree. There's no modularity if you can't enforce access rights.
Data hiding is an integral part of modular design. Verbal agreements are
worth absolutely nothing.
I still prefer option #1. It's not like it would exclude option #3, so
you get the best of both worlds: Clarity in naming conventions, *and* the
compiler checking the integrity of the interface.
> to handle.
And if you don't prevent it, you are locking yourself out of ever trying
to improve your module (without breaking tons of existing code).
In fact, precisely. If the code supports telling "this is the public
interface", what better documentation.
> Warp escreveu:
> beyond me.
It's different because if you do it by mistake, nothing will tell you.
(Except when your code breaks when you update the library.)
It's not "verbal". It's expressed in the code. It just so happens that
there's a way to bypass it. You say "My module exports the functions alpha,
beta, and gamma." You then later define alpha, beta, gamma, and delta. The
caller can't get to delta without explicitly saying "hey, you know that
private function delta in that module? Import it into my module."
It's not something you do by mistake.
And then someone comes and says "Gee, parsing this function each time is
adding too much overhead. We need to store that structure in a database. And
then we need to calculate it at the server and then ship the bytecodes to
each client." And you're either screwed, or you bypass the private part to
make it work knowing you'll break on the next release of the library. Or you
pick the source up, and maintain it yourself in the future, which is just a
special case of #2 there.
You should try Ada! ;-)
In any case, that sort of import is exactly the sort of way you bypass the
access restrictions on exported functions in Python, for example. You have
to go read the source (to find the name), then explicitly copy the function
into your own namespace to invoke it.
And you can't enforce access rights in C++, because nothing prevents wild
pointers from clobbering anything in memory.
WarpsClass x(...);
memset(&x,0,23);
If you think that's somehow unfair, then how is reflection any less fair?
Now I'm completely puzzled. We are talking about public interfaces and
private members, and you start suddenly talking running off the end of an
array? I can't see *any* connection whatsoever between these two things.
I could just invent a completely wild answer to that argument of yours as
well: "But loops use loop variables without the need of any hacking." It
makes exactly as much sense to me.
> *p = 27;
What member variable?
> How about
> // Your code...
> class xyz {
> public: int[10] x;
> private int y = 0;
> // My code
> xyz pdq;
> pdq.x[10] = 27;
You are accessing a public variable, not a private one.
It enforces it as long as you don't deliberately try to bypass the
compiler checks.
Deliberately hacking yourself around the compiler checks requires more
malice than using a public member variable which simply "shouldn't" access.
It sounds like you are saying "since you can't enforce the privacy of
the members in all possible cases, then they might just as well be public".
That's BS.
Haha.
> that's private.
Warnings? Trying to access a private variable gives a compiler error.
That's the great thing about language support for private sections: You
don't *need* to document that they are private. The compiler will tell you.
> OS.
I don't see any connection between that and the current subject.
> Or, in short, you can't protect against bad programmers
So let's deliberately make bad code?
That's exactly as silly as saying that it's useless to lock your car
because someone could break its windows anyways.
> each client."
That's a hilariously bad example because in order to get the object from
the database you will have to make a database call, which will parse its
internal structures (perhaps even directly from disk), after which your
object will be constructed from this parsed data. I would be really surprised
if that's not an order of magnitude slower and resource-heavy than re-parsing
the function.
And exactly how would making the private members public help this?
You are nitpicking, and you know it.
If you write normal, standard-conforming C++, you can perfectly well
And if it's a language feature, people don't do it either, not even by
accident.
And then you modify your class, and your pre-existing SOAP interface parser
breaks.
You call that "easy"? To me it looks like garbage. You can't write code
like that by mistake. You are deliberately writing non-standard code which
triggers undefined behavior. You are not accessing a member variable, you
are trashing memory.
Let's talk about *standard-conforming* C++.
> > mistakes.
Well, if you want to intentionally break the modularity of your code with
something like reflection, at the risk of breaking tons of code in the future,
that's your choice.
(If you use reflection to, for example, save the state of an object to
a database to be retrieved later, haven't you kind of locked up the
structure of that object? You can't make *any* changes whatsoever to it
without breaking all the stored objects in the database. Doesn't sound
very enhanceable to me.)
If you trash memory, you are writing non-portable, non-standard-conforming
code. All bets are off. If you want to write code like that, you might as
well not use classes at all. What's the point?
Where have I said "there should be a non-portable way to bypass it"?
There may be a non-portable way of bypassing it. That's different from
"there should be".
I disagree. Now you've got a naming convention that isn't enforced that
would mean something to people trying to read your code. Duplicate work,
with uglier source code, and insufficient reliability to depend on. I think
we've all learned that faux-Hungarian notation is a bad idea.
Unless the compiler also enforces that (say) privately scoped variables
start with an underline, at which point, why? What prefixes are you going to
have the compiler enforce, and what benefit does it bring, and why not just
have the prefix indicate the type information (like trailing $ means string
in basic)?
>> to handle.
Not really. The beauty of the reflection libraries are that they allow the
person using them to *adjust* what they do when you change your code, all
without having to change *their* code. Does using
write(handle, &thestructure, sizeof(thestructure))
prevent you from ever adding anything to thestructure? No. Why? Because
you're getting metadata from the compiler (via sizeof) rather than
hardcoding a 137 as the size or some such.
Of course, that's hardcoded at compile-time, and the results it writes out
can't be read into an instance of the new version of the structure, which is
exactly why people started building more complex reflection libraries,
hibernation libraries, and so on.
If you have something like your function parse library, and I want to take
an instance of that and send it to a process on a different machine, how do
I do that? I can't, without violating the encapsulation, because you didn't
provide for that. But if my income this week depends on me getting to your
private variables, C++ isn't going to be able to stop me.
(I may be wrong, but it doesn't look like you provide accessors for anything
in the instance, so I can't even look at it after the fact and see what
function it's representing? It looks like I can't have a function that takes
an instance of FunctionParser and pulls out enough information that I can
make a second FunctionParser that does the same thing, other than via
AddFunction (second overload)?)
But with reflection, I can write code that does this, *and* it will *still
work* even after you change your class, even if you rewrite it completely.
Hacking past "private" is a whole different ball of wax than reflection.
Hacking around "private" can be a mistake (bad pointer) or intentional
(#define private public), but reflection is always intentional *and* it's
easy to write it to self-adjust.
Both Python and LISP and Java and C# provide for that. They just don't fail
to provide defined mechanisms for bypassing that.
> breaks.
No, it doesn't. Because the reflection library will change what it sends,
and generate a new WSDL that the client will use to get the new interface.
That's why it's done that way.
The things we're talking about generally don't allow it to be done by
mistake. It's certainly not the case that reflection gets "done by mistake".
Yes. Of course, it could just look like
alpha[i] = 32;
and you're equally screwed. Or even
&myInstance.update()
if my instance happened to be on the stack before but isn't now, and your
instance is there instead.
Tell me why you think reflection can be done by mistake?
> that's your choice.
Well, yes, that's kind of the point.
Without reflection, you have no generalized way to handle this. With
reflection, you can write code that does the right thing. Of course this is
simplified.
But the same is true of a manually-implemented class.
And when you're serializing something to (for example) store as a hidden
field on a web page, chances are when you update the code whoever is in the
middle of a session is going to break anyway.
Or, when you change the shape, you fix the database appropriately.
You're making a mistake that is arguably easier to make than using a name
that starts with an underline.
That's exactly what I'm saying: If you make a mistake, all bets are off. So
you're counting on the perfection of every author and contributor to your
codebase to always do the write thing, because the compiler *doesn't* check
that it's right, and the runtime *doesn't* check that it's right.
So I'm not seeing why the compiler not checking for you intentionally using
a private variable is *less* encapsulated than the compiler not checking you
don't accidentally have a wild pointer. The "standards-compliant" Python
code says "don't dick with the private variables of an instance unless you
want code that's fragile when that class gets upgraded."
In my experience, I'd much rather use a language where the access rules are
enforced, even if those access rules allow well-defined methods of getting
at private variables, than to use a language where a mistake by one
programmer breaks code in a completely unrelated programmer's module. That's
just my experience, tho.
> "there should be".
So you're saying having non-portable ways of bypassing the typing is better
than having portable ways of bypassing the typing? C# is less encapsulated
than C++, because C# has documented ways of intentionally getting to private
variables, but C++ has only accidental compiler-specific ways of getting at
private variables?
How about a declaration on a class that says "It's OK for someone to bypass
the private declarations and use reflection on this class", while classes
without that declaration would not be accessible from the reflection
methods. What do you think of that idea?
