POV-Ray : Newsgroups : povray.off-topic : The trick Server Time
4 Jul 2026 01:59:45 EDT (-0400)
  The trick (Message 11 to 20 of 32)
Subject: Re: The trick
Date: 13 Mar 2009 06:41:48
Message: <49BA386E.2030004@hotmail.com>
On 13-3-2009 11:27, Invisible wrote:
>>>> Why not in (reverse) polish, no brackets at all
>>> If you think *you* can find a suitable encoding for lambda
>>> expressions in reverse polish notation, be my freakin' guest! :-P
>> I'd say that polish would be enormously more simple than standard infix.
> Not once you add case expressions, let expressions, type signatures and
> so forth.
The numerical expressions (which is what your question was about) would
still be more simple and there is no rule that other expressions can not
be implemented in another convenient way.
Date: 13 Mar 2009 06:48:39
Message: <49ba3a07@news.povray.org>
> Fun thing:
>   12+3*
>   123+*
> These two expressions look different, but are guaranteed to produce the
> same answer.
I thought that 12+3* means (1+2)*3 and 123+* means (2+3)*1 ???
Date: 13 Mar 2009 06:55:21
Message: <49BA3B9B.9000006@hotmail.com>
On 13-3-2009 11:35, Invisible wrote:
> Fun thing:
>   12+3*
>   123+*
> same answer.
Until now I had never realized that even reversed polish could be
interpreted in more than one way. Your interpretation might be
consistent,though that might require some checking. I would say that the
two expressions reduce to 9 and 5. Note that if you insist that
parameters are eaten from left to right subexpressions are not substrings.
Date: 13 Mar 2009 06:55:29
Message: <49ba3ba1@news.povray.org>
>> Fun thing:
>>   12+3*
>>   123+*
>> the same answer.
I stand corrected.
I was pretty certain I remember there being a way to modify the exact
order in which operations are performed yet always arrive at the same
answer. However, I am currently unable to construct a valid example.
Perhaps my memory is off...
Date: 13 Mar 2009 06:59:50
Message: <49ba3ca6$1@news.povray.org>
How about these?
ABC+*DE+*F*
ABC+DE+**F*
Date: 13 Mar 2009 07:07:51
Message: <49ba3e87$1@news.povray.org>
> How about these?
> ABC+*DE+*F*
> ABC+DE+**F*
Yes they seem the same to me...
Date: 13 Mar 2009 07:08:49
Message: <49ba3ec1$1@news.povray.org>
scott wrote:
>> How about these?
>> ABC+*DE+*F*
>> ABC+DE+**F*
I'M NOT CRAZY! 6_6
Oh, wait...
Date: 13 Mar 2009 07:13:06
Message: <49BA3FC3.4000309@hotmail.com>
> How about these?
> ABC+*DE+*F*
> ABC+DE+**F*
such rewriting indeed works for any operator $ that satisfies
(A$B)$C=A$(B$C) i.e. AB$C$=ABC$$ in RPN.
BTW Why did you choose this example with such a lot or irrelevant detail?
Date: 13 Mar 2009 07:18:59
Message: <49ba4123$1@news.povray.org>
>> So... maybe when printing out any given subtree, I make the print
>> function take the precedence of the parent node as an extra argument?
> I'd to print the parens (if needed) in the parent call before recursing.
It's easier to do it the other way around. The function only has to care
what the precedence of the current operator is before recursing. The
recursive call can decide what to do about it.
Using this technique, I was also able to "hack" in support for
associativity. For example, in Haskell function application has the
highest possible precedence, and left associativity (because of curried
functions). So, when recursing from a function application call, it
tells the left subtree that the parent's precedence was 8, but it tells
the right subtree that the parent's precedence was 9.
The result is that if you have
   A   B C   D
it prints out as "A B (C D)", which is correct.
(Although, needless to say, I spent a day confusing myself with what
"higher" precedence means, and mixing up left and right associativity.
It probably doesn't help that the function type constructor is
right-associative because the function application operator is
left-associative...)
What can I say? Apparently I'm not very smart.
Date: 13 Mar 2009 07:24:53
Message: <49ba4285$1@news.povray.org>
>> How about these?
>> ABC+*DE+*F*
>> ABC+DE+**F*
So... any associative operation then?
A quick check confirms that
   ABC*-DE*-F- ==> (A-(B*C))-(D*E)-F   ==> A - BC - DE - F
   ABC*DE*--F- ==> (A-((B*C)-(D*E)))-F ==> A - BC + DE - F
which aren't the same.
My brain is like mush this morning. This was the first correct example I
could find. It's about 10 years ago that I discovered this effect, so I
wasn't even sure if I was remembering right!
(Currently attempting to build a Haskell parser, printer and type
interence engine. This stuff is surprisingly non-trivial. Having an
argument about RPN in parallel with these activities is exceeding my
mental capacity!)
