> By downshifting, what happens is the wheels aren't stopped, but the
> torque applied through the drivetrain slows them down as the engine revs
> come down.
The brakes do the same. And in both cases, as soon as the negative torque
(either from engine or brakes) is higher than the friction between the tyre
and road, the wheels lock. As I said in my other post, maybe it's easier to
control small amounts of negative torque with the gears, but still you're
only applying it to 1 or 2 wheels, not 4, so you're never going to be able
to slow down as quickly.
> In that case, pumping the breaks was an effective
> way to slow the car down. Similar effect to a car with ABS (which I
> really miss in my current car, my last one had ABS but the new one
> doesn't), but the pulsing isn't rapid.
They make cars without ABS?
>> revs come down.
> torque (either from engine or brakes) is higher than the friction
> between the tyre and road, the wheels lock. As I said in my other post,
> maybe it's easier to control small amounts of negative torque with the
> gears, but still you're only applying it to 1 or 2 wheels, not 4, so
> you're never going to be able to slow down as quickly.
Um, no, the brakes don't do the same - if you have disc brakes, the
brakes stop the wheels when fully engaged (I don't have drum brakes so I
can't comment on those). Conversely, by downshifting, you increase the
engine revs and the wheels are not locked - they still turn.
Now, when you're on dry pavement, the wheels normally don't lock because
the car's momentum overcomes the friction on the brakes, bringing you to
a gentle (or sometimes less-than-gentle) stop. On ice, though, it takes
less friction of the brake pads against the wheel to stop the wheels
because it takes less to overcome the friction of the wheel against the
ground.
So it's easier to lock the wheels up and skid.
However, you're right that you won't slow down as quickly by using the
engine to slow the vehicle down. The point isn't to slow down quickly,
it's to slow down safely.
You have to combine this with driving more defensively as well - not
following the car ahead of you too closely, for example. If you don't
give yourself more space to stop, you'll run into someone else.
But that gets into another whole area of "stupid driver tricks".
>> In that case, pumping the breaks was an effective way to slow the car
>> down. Similar effect to a car with ABS (which I really miss in my
>> current car, my last one had ABS but the new one doesn't), but the
Yes. My 1999 Saturn SC1 has no ABS. :-)
Jim
I once gave myself a nosebleed by borrowing my mother's car. I was used to
driving a dinky manual without power breaks. I borrowed the behemoth car my
parents drove, and as I coasted up to the stop sign, I stomped the clutch
all the way to the floor, of course. Except their car had very strong power
breaks and was an automatic with no clutch pedal. Ouch.
"Ouch ouch ouch!"
"What's wrong? Noodles too hot?"
"No, I have Chopstick Tunnel Syndrome."
> to driving a dinky manual without power breaks. I borrowed the behemoth
> car my parents drove, and as I coasted up to the stop sign, I stomped
> the clutch all the way to the floor, of course. Except their car had
> very strong power breaks and was an automatic with no clutch pedal.
> Ouch.
Ouch indeed. Kinda the reverse of what nearly everyone I know who
learned to drive a stick went through when not timing the clutch properly
when shifting. Of course, you lurch forward (usually) rather than
backwards, so a nosebleed isn't so much of a problem as whiplash. ;-)
Jim
> when shifting.
Oh, I did that too. This was years after I learned to drive a stick. I just
wasn't really paying attention to the controls as such. Just, you know, drivin'.
"Ouch ouch ouch!"
>> properly when shifting.
> just wasn't really paying attention to the controls as such. Just, you
> know, drivin'.
Yep, I managed it when I tried driving a stick for the first time in
years myself. Takes a few tries to get the hang of it again.
At least when I drove in England, I was driving an automatic. I don't
know that I'd get used to shifting with the lever on the wrong side (Yes,
Stephen, the left side is the WRONG side <g>).
Jim
Of course it is, it isn't the American Way ;)
Regards
>>(Yes, Stephen, the left side is the WRONG side <g>).
<Grumble> I shoulda expected THAT. ;-)
(Haven't you noticed my spelling?)
Jim
Of course, because through the brakes you are applying more torque than the
tyre/road surface can provide, so the wheel locks.
Only because *usually* the negative torque applied from the engine is not
enough to overcome the grip between the tyre/road. Try downshifting on ice
or even on wet tarmac violently (eg 4th to 2nd at 40mph) and you will lock
the wheels (certainly audible on wet/dry tarmac).
BTW the two effects add up, so if you are already braking hard with the
pedal, downshifting hard at the same time will likely lock the wheels
easily, this is why racing drivers always "blip" the throttle while braking
and changing down, to avoid the engine braking that could lock the wheels.
> ground.
Yes, and the same applies to engine braking. Next time it's wet or snowy
try changing down (a couple of) gear(s) and letting the clutch out quickly,
you'll hear/feel the driven wheels lock until the car slows enough for the
wheels to grip again. Obviously on snow and ice this happens easier.
No, you are asking a dyslectic about spelling? :)
Anyway I am used to reading American spelling now and translate into proper
English, automatically. It is BTW one way. :)
Regards
