![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The best thing about operating a virtual machine is...
...it makes my physical machine seem *fast*! o_O
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What I find interesting is that, even though the virtual machine is
about 200x slower than a physical machine, it still manages to
communicate over the Internet, apparently without issue. I guess the
emulator must be doing some pretty significant buffering to pull this
off, mind you... o_O
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I wish it would buffer my keystrokes... I had to type some stuff several
times, leaving a 2 second pause between each keypress, before it would
register *all* of the letters I typed. :-S
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What VM software are you using?
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
QEMU.
It's the only VM software I can find that doesn't require you to
"install" it before you can use it. If you have a better suggestion...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> QEMU.
Sun's Virtual Box worked rather well for me. It also has extensions
compatible with most of the major distros (You can integrate the Linux
windows with your desktop, share files with the host, pass through some
USB devices, etc...
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> QEMU.
> USB devices, etc...
Yes, I was looking at Virtual Box just yesterday. It looks a lot more
user-friendly. (E.g., you configure a VM using a GUI rather than miles
of cryptic command switches.)
OTOH, you definitely need to "install" it before you can run it. My
objective is to create a VM that I can put on a USB stick and plug into
some arbitrary PC to quickly pull up a Linux console or something.
I might try something like Virtual Box or Xen on my home PC tho...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> QEMU.
>> USB devices, etc...
VMware Server. It does also require installation, but it's free (as in
"no cost") and performance is much better than QEMU.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
