POV-Ray : Newsgroups : povray.off-topic : White is in the winter Server Time
6 Jun 2026 16:35:02 EDT (-0400)
  White is in the winter (Message 11 to 20 of 73)
Subject: Re: White is in the winter
Date: 2 Feb 2009 06:22:07
Message: <4986d75f$1@news.povray.org>
http://www.metoffice.gov.uk/weather/uk/advice/snow.html
"If braking is necessary, pump the brakes don't slam them on."
...unless you have friggin ABS! :-P
Date: 2 Feb 2009 07:03:55
Message: <4986e12b@news.povray.org>
BTW ABS doesn't work below about 5 or 10 mph...
Date: 2 Feb 2009 07:27:36
Message: <4986e6b8@news.povray.org>
Really?
Any specific reason?
Date: 2 Feb 2009 08:13:29
Message: <4986f179$1@news.povray.org>
> Really?
I imagine it's because if the ABS system sees all four wheels go from 5mph
to 0mph it can't tell whether you've actually come to a stop or you are
skidding on ice.  At 50mph it's obvious if the wheels all stop within a
fraction of a second you are skidding, at low speeds it's not so easy to
work out.
Date: 2 Feb 2009 08:18:41
Message: <4986f2b1$1@news.povray.org>
>> Really?
> 5mph to 0mph it can't tell whether you've actually come to a stop or you
> are skidding on ice.  At 50mph it's obvious if the wheels all stop
> within a fraction of a second you are skidding, at low speeds it's not
> so easy to work out.
Mmm, OK.
I must admit, I've always wondered how the hell ABS actually works.
But not as much as power steering. This, as far as I can tell, should be
logically impossible. And yet it apparently works. How baffling!
Date: 2 Feb 2009 08:27:05
Message: <4986f4a9$1@news.povray.org>
Invisible wrote:
> Uh... WTF? It's not exactly like the Arctic out there! :-P
There are large numbers of people who have difficulty driving in
anything more slippery than rain.  This is most likely in areas which
are known for the mildness of their winters.
Add to this the general temperament of the government to view itself as
some kind of mother to the people, and you get urgent warnings telling
people to regard as wild uncontrollable dangers things that in fact
present a small and manageable risk.
I grew up in Michigan, and can tell you that even as experienced with
the snow as they are there, the first significant snowfall of the winter
is a refresher course in winter driving for just about everybody.
John
Date: 2 Feb 2009 08:28:15
Message: <4986f4ef$1@news.povray.org>
A speed sensor on each wheel, if one drops too quickly compared to the
others, or they all drop too quickly than what is "usually possible" a
solenoid is opened that releases the brake pressure until the wheels speeds
are back to normal, then the solenoid is closed.  The process might then
repeat if the driver is still pressing the brake pedal hard - this is the
"pulsing" sensation you feel.
Note that modern cars are much more complex, with ABS being part of a much
larger control system, capable of regulating the braking force to each
individual wheel (to allow each wheel to be giving the maximum stopping
power, and to prevent skids, wheel-spin etc).
There's a part in the steering system that twists or bends by a specific
amount depending on how hard you tug at the wheel.  A set of valves then
controls some pressurised hydraulics based on how much force you are putting
into the wheel, which helps you steer.
Newer cars have a torque transducer and an electric motor with some clever
software.  This saves on fuel as there is no hydraulic compressor having to
be run the whole time (usually you only need power assist at low speeds).
Date: 2 Feb 2009 08:32:29
Message: <4986f5ed$1@news.povray.org>
> speeds are back to normal, then the solenoid is closed.  The process
> might then repeat if the driver is still pressing the brake pedal hard -
> this is the "pulsing" sensation you feel.
> much larger control system, capable of regulating the braking force to
> each individual wheel (to allow each wheel to be giving the maximum
> stopping power, and to prevent skids, wheel-spin etc).
...not to mention traction control... ;-)
>> be logically impossible. And yet it apparently works. How baffling!
> putting into the wheel, which helps you steer.
> clever software.  This saves on fuel as there is no hydraulic compressor
> having to be run the whole time (usually you only need power assist at
> low speeds).
The part I can't figure out is that, as far as I can tell, hooking up a
motor that turns the steering wheel in the same direction as you're
trying to turn it should generate a positive feedback loop. I can't
figure out how turning the wheel doesn't cause the powerful motors to
rip the wheel out of your hands and put the car into full lock before
snapping the steering column in half...
Date: 2 Feb 2009 08:35:19
Message: <4986f697@news.povray.org>
I did notice that in the videos of people pushing cars, all the cars
seemed to be attempting to drive uphill at no more than walking pace -
shorly not a sensible thing to do in snow?
Yeah, maybe. I guess the government doesn't want to hear the whole "why
didn't you warn people?" thing, or "why didn't you take action?". (OTOH,
it didn't seem to be a problem for New Orleans...)
I can remember 1995 or so, there was a lot of snow one day. About 20 cm
or so. Not huge, but a lot. Nobody seemed to really pay much attention.
A few people got slightly stuck or something, but nobody considered it a
big deal. Yet today, it's a catastrophy... hmm.
Date: 2 Feb 2009 08:46:03
Message: <4986f91b$1@news.povray.org>
Er yeh, that's what I meant by wheel-spin.  OOC I looked up the instructions
for how a dealer fits the "USB Audio" upgrade to my car (I was just
wondering if the cables were already there and I simply needed to fit a
suitable plug - sadly not).  Anyway, it appears my car has a network of
fibre optic cables o_O.  To fit the upgrade, apparently involves ripping out
half the car, making some connection to a box of opto-electronics in the
boot, then fitting a "USB hub" under the drivers seat and fitting the USB
socket in the centre console, and of course fitting cables between all of
them.  The 250 pound price tag doesn't sound so bad now!
> motor that turns the steering wheel in the same direction as you're trying
> to turn it should generate a positive feedback loop. I can't figure out
> how turning the wheel doesn't cause the powerful motors to rip the wheel
> out of your hands and put the car into full lock before snapping the
If you simply program the motor to apply the same torque you are applying
with your hands to the wheel, then there is no feedback, it will just feel
like it takes half the force to turn it.  Of course in reality it is more
complex, the multiplier is probably dependant on speed, and maybe other
factors like how sharp you are turning.  And maybe there is some limit the
torque you apply needs to go above before the motor kicks in?
Something like:
If AppliedTorque > 10 Then
 MotorTorque = (AppliedTorque - 10) * CalculateAssistFactor( VehicleSpeed ,
SteerAngle )
Else
 MotorTorque = 0
