nemesis wrote:
> Hmm, this sounds weird. You mean dynamic linking an app against a GPL
> lib doesn't require one to GPL the app code as well? If so, what's the
> point of the LGPL?
> And I didn't know OpenGL was GPL'd. In fact, it's a specification only.
> Are you talking about the mesa lib?
OpenAL is also LGPL, as far as I can tell. (They don't actually put the
license on the web site anywhere.) You'd think fsf.org would have a FAQ
section too, or at least have links to the actual licenses off the home page
somewhere.
"Ouch ouch ouch!"
"What's wrong? Noodles too hot?"
"No, I have Chopstick Tunnel Syndrome."
Darren New escreveu:
> nemesis wrote:
>> extension for gcc, so without gcc, there would be no plugin of yours.
> This is not true. Someone else may write a gcc-compatible compiler.
Down to the devious plugin architecture?! I think Duke Nukem Forever
and HURD are released first, or Wine 2.0 is Vista compatible.
> it may be a large codebase that works for any compiler, and I want it to
> work for gcc also.
Why? You don't like the damned GPL stuff, remember? Why help spread
it? Why not tell your users that if they want said functionality
they'll need to use other, possibly better and unrestricted compiler?
>> So, why would you even write a plugin for gcc in the first place?
> And my Linux application wouldn't exist if I didn't have Linux to run it
> under. Does that mean my application is GPLed? My apache module wouldn't
> exist if apache wasn't around. Does that mean my module is GPLed? My
> PSQL stored procedures wouldn't exist if PSQL wasn't around. That
> doesn't make my stored procedures GPLed.
Of course, none of those projects require your code to be GPLed. GCC
will, and not by the GPL.
BTW, all your examples do not constitute a single program running in the
same process space, they are very different from app and lib or plugin.
> If every Linux application you wrote was required to use the GPL, would
> you find software companies like Adobe porting their software to it?
You talk like as if the plugin is an external app running in a "gcc
kernel space".
> You can certainly license code with a license that says "if you use this
> compiler, everything you compile with it belongs to us." As you say,
> people don't do that, because people wouldn't use the compiler if they did.
GCC doesn't say that, so I don't know how the example is any pertinent.
> I find it interesting that in the areas where FSF *is* the leader, they
> wind up acting like monopolists.
Like in areas where they are actually the original developers of GNU
software? Yeah, sound as bad as Apache...
Someone may write a word processor compatible down to the undocumented
binary file format?!?
Maybe someone likes your gcc plug-in so much they want you to port it to
*their* compiler. Whoops, sorry! You can't!
>> to work for gcc also.
I didn't say that. I said I don't always like what it does to my employment,
and I said I don't like how the FSF is trying to force unrelated software to
be GPLed. But most of the developer tools are pretty nice.
I'm not sure what "single address space" has to do with it. Certainly my
program runs in the same address space as the Linux kernel, or the Linux
kernel wouldn't be able to fill my buffers with data when I call read().
>> would you find software companies like Adobe porting their software to
>> it?
> kernel space".
It is, as much as FLASH is. It's an "external app" in that it doesn't
incorporate any of the code from GCC into itself.
>> this compiler, everything you compile with it belongs to us." As you
>> say, people don't do that, because people wouldn't use the compiler if
>> they did.
Right. I was trying to explain *why* it doesn't say that, even tho it could
say that with at least as much authority as the plug-in architecture could.
>> they wind up acting like monopolists.
> software?
No, like in areas where the product is so good it has pushed most
competitors out. Like, Sun shipping the gcc compiler instead of continuing
to improve their own.
"Ouch ouch ouch!"
> You can
> prevent me from distributing your code in ways you don't like, but
> that's true of every license.
What isn't true of every license is that it lets you use software for
any purposes *or* modify or make it as basis for other software as long
as you release it all under the same license too.
Subject: Re: This GPL stuff is getting ridiculous
Date: 30 Jan 2009 15:20:12
Message: <498360fc@news.povray.org>
On Fri, 30 Jan 2009 11:32:19 -0800, Darren New wrote:
> Jim Henderson wrote:
>> You can link to GPL libraries. There are plenty of examples of this.
> Then what's the LGPL for?
Provides some additional options.
> Note that OpenAL is apparently LGPL, so it specifically says you can
> link to it without invoking the GPL.
Yes, but again, linking to something that's GPL'ed doesn't mean your
program has to be GPL'ed. I used OpenAL as an example, probably not the
best example given that it is LGPL.
>> What you cannot do is incorporate GPL-licensed code into non-GPL
>> licensed code.
> Define "incorporate"? Look at the first paragraph of
> http://www.fsf.org/licensing/licenses/why-not-lgpl.html
I write this:
void main(void)
puts("do something here");
/* Call a bunch of other functions */
You write code and you use some/all of my code in your code. My code is
released under the GPL, now yours must be as well because you're using
the source code I wrote in your code/product.
> It doesn't sound like the FSF agrees with you.
>> There is, AFAIK, one single exception - if you own the code, you can
>> dual- license it.
> Unless it's a plug-in for GCC.
Well, argue that with the GNU foundation, I would agree that the root of
this debate is suspicious. It seems, though, they're trying to do
something similar to the Linux kernel's "tainted" flag with the compiler,
but pushing it to a new level.
>> But if you're building something large and you want to leverage code
>> others have written, you have to respect their license terms (whatever
>> that license is, not just if it's GPL).
> Agreed. I'm not arguing the GPL is a bad thing, even. I'm simply
> pointing out that a lot of the slogans promoted by FSF supporters are
> wrong.
> The gcc changes aren't aimed at making sure the plug-ins are "free
> software". They're aimed at making sure the plug-ins are "copyleft".
Well, as the authors of gcc, surely they have the right to extend the
license terms in whatever way they see fit.
Jim
"Darren New" <dne### [at] san rr com> wrote in message
news:49834830$1@news.povray.org...
> The thing that's "getting ridiculous" is when people go out of their way
to
> apply the GPL to *your* code when it *isn't* a derivative of any GPLed
code.
> See how that works?
No, I don't. How is it even possible for *others* to GPL *your* code? It's
only you who can do that.
On Fri, 30 Jan 2009 17:19:54 -0200, nemesis wrote:
> Jim Henderson escreveu:
>> On Wed, 28 Jan 2009 18:46:27 -0800, Darren New wrote:
>>> So you said "The GPL only affects those who modify the code." This is
>>> factually wrong, as evidenced by my example.
>> No, it's not factually wrong.
>> I just purchased X-Plane 9. It uses openAL, openGL and a slew of other
>> libraries.
>> X-Plane is a proprietary software package that links to these libraries
>> which IIRC are licensed under the GPL.
>> If Austin (the author of X-Plane) had incorporated the libraries into
>> his binary by compiling the code as part, then yes, he would've had to
>> license his whole software package under the GPL. He didn't and he's
>> within the requirements of using GPL libraries.
>> The argument about "linking means you have to release your code under
>> the GPL" has been disproven time and time again.
> point of the LGPL?
I don't believe it does. But I've not done an in-depth look at the
differences between GPL and LGPL. I have read a lot of discussions about
it, though.
D'oh! Yes, Mesa is what I'm talking about, it provides libGL. However,
Mesa is X11/MIT licensed.
Jim
>> point of the LGPL?
>> only.
> page somewhere.
LGPL 2.1 or later according to my RPM package.
Jim
OK, I'll assume you didn't read the link that started the thread, then. Thanks.
"Ouch ouch ouch!"
And GPL != LGPL. LGPL is GPL plus ability to use the library unmodified in
commercial applications. The GPL doesn't allow you to link to unmodified GPL
code and use it in your own program.
"Ouch ouch ouch!"
