Darren New escreveu:
> nemesis wrote:
>>> Firstly, you understand that by giving the FSF the copyright, you've
>>> given them permission to prevent you from releasing your own code
>>> with a different license, right?
>> Yes, and I'm pretty sure all GPL contributors willing to do so,
>> including commercial entities, are well aware of it.
>>> Copyright is the right to restrict others from copying your work.
>>> It's not the right to copy it, but to prevent others from doing so.
>> [...] The copyright holder
>> of the original GPL'd code is still the same,
> Not if you've given the copyright to the FSF.
It was exactly about the FSF I was talking about, following from the gcc
case.
>> but what does this mean when he explicitely grants others the right to
>> use, copy and modify it?
> That he can prevent you from copying it.
No, he can't because he explicitely stated otherwise by abiding by the
GPL terms.
He can, as copyright owner, license it all under another license and
begin anew, even closed source, from there on with worthy improvements
to the code, just as some commercial entity can take away a MIT project
and do the same. The original GPLed code can't be closed by anyone,
like MIT code.
>> The only power left to FSF is if they suddenly change from a
>> foundation to a corporation and license the body of GNU software under
>> a restrictive commercial license
> Yep. Not that I'm saying they will. I'm just pointing out that the
> assertion that the original author can always dual-license the code is
> incorrect if you've turned the copyright over to the FSF.
The majority of GPL'd code out there is not GNU and copyrights are
retained by the original authors, which is what really fuels GPL
projects, since everyone benefits from collaborative development and
still retain their copyrights in face of leechers.
If you're willing to donate code patches to the FSF though, you are well
aware of the consequences and are willing to take the risk perhaps
because you think it'll be of benefit for everyone, including yourself
(like, others can take the burden of maintaining the software, even your
changes). Even though Stallman may end up being nothing more than a
evil leecher and a hypocrite. I believe it's more likely though that
he'll be assaulted by ninjas...
nemesis wrote:
>> The brainwashing in this case is to make people think that if I
>> improve your code, then it's still your code to control.
> I don't think I get it what you mean.
You conflate "my code, with your code added" to be the same as "my code".
The GPL isn't "more free" than the MIT license. It's just letting you
exercise different control over the code you wrote yourself. You can prevent
me from distributing your code in ways you don't like, but that's true of
every license.
The thing that's "getting ridiculous" is when people go out of their way to
apply the GPL to *your* code when it *isn't* a derivative of any GPLed code.
See how that works?
"Ouch ouch ouch!"
"What's wrong? Noodles too hot?"
"No, I have Chopstick Tunnel Syndrome."
>> The FSF is looking for technological mechanisms
>> to force you to GPL the code that you wrote entirely from scratch
>> yourself without modifying or incorporating any other GPL code.
>> They're not respecting my wishes about how I want to distribute *my*
>> original code
> Your gcc plugin code would only exist in the first place as an extension
> for gcc, so without gcc, there would be no plugin of yours.
This is not true. Someone else may write a gcc-compatible compiler. Or it
may be a large codebase that works for any compiler, and I want it to work
for gcc also.
In any case, that's irrelevant. If gcc plug-ins fell under the GPL, they
wouldn't need technological mechanisms to prevent them from working when
they aren't GPLed, would they? The fact that it interoperates with gcc
doesn't mean they're respecting my wishes for how I want to license my code,
does it?
> So, why
> would you even write a plugin for gcc in the first place?
And my Linux application wouldn't exist if I didn't have Linux to run it
under. Does that mean my application is GPLed? My apache module wouldn't
exist if apache wasn't around. Does that mean my module is GPLed? My PSQL
stored procedures wouldn't exist if PSQL wasn't around. That doesn't make my
stored procedures GPLed.
If every Linux application you wrote was required to use the GPL, would you
find software companies like Adobe porting their software to it?
> If the GPL alone would be able to restrict it in this way, you wouldn't
> enjoy it either, so what motivations would you have to submit any code
> at all to help promote and spread a project purpoting the evil GPL license?
I'm not sure what you're trying to say.
You can certainly license code with a license that says "if you use this
compiler, everything you compile with it belongs to us." As you say, people
don't do that, because people wouldn't use the compiler if they did.
I find it interesting that in the areas where FSF *is* the leader, they wind
up acting like monopolists.
"Ouch ouch ouch!"
> case.
I was referring to the concept that "the original author can always
dual-license it." That isn't true if the copyright has been given to FSF.
> The original GPLed code can't be closed by anyone, like MIT code.
Original MIT code can't be closed by anyone either.
I agree with all of this. My disapproval is of the attempts to take code
from people that doesn't fall under the GPL and doesn't contain any code of
a GPLed project, and force them to release it under the GPL.
"Ouch ouch ouch!"
Subject: Re: This GPL stuff is getting ridiculous
Date: 30 Jan 2009 13:50:34
Message: <49834bfa@news.povray.org>
On Wed, 28 Jan 2009 12:46:12 -0800, Darren New wrote:
> Jim Henderson wrote:
>>>>> This makes GPL incompatible with all other licenses. This is
>>>>> rather
>>>>> restricting.
>>>> But protective of the rights of the original author, which is the
>>>> underlying goal.
>>> Which original author? The one giving away the code with more
>>> restrictions, or the one giving away the code with fewer restrictions?
>> The one who wrote the code that you are modifying and then
>> distributing.
> What makes you think I'm modifying the GPL code?
> If I include libjpg without modifying it at all, I can no longer use the
> MIT license on my code, even if my code is orders of magnitude larger
> and more valuable. This forces me, while building something large that I
> need to get paid for, to rewrite code that's already tested and works
> well and is bug-free and safe. Hence, GPL code leads to bugs in non-GPL
> code.
You can link to GPL libraries. There are plenty of examples of this.
What you cannot do is incorporate GPL-licensed code into non-GPL licensed
code.
There is, AFAIK, one single exception - if you own the code, you can dual-
license it. There are also plenty of examples of this.
There's nothing that says you can't get paid for writing GPL code. There
are also also plenty of examples of this.
But if you're building something large and you want to leverage code
others have written, you have to respect their license terms (whatever
that license is, not just if it's GPL).
Jim
On Wed, 28 Jan 2009 18:46:27 -0800, Darren New wrote:
> So you said "The GPL only affects those who modify the code." This is
> factually wrong, as evidenced by my example.
No, it's not factually wrong.
I just purchased X-Plane 9. It uses openAL, openGL and a slew of other
libraries.
X-Plane is a proprietary software package that links to these libraries
which IIRC are licensed under the GPL.
If Austin (the author of X-Plane) had incorporated the libraries into his
binary by compiling the code as part, then yes, he would've had to
license his whole software package under the GPL. He didn't and he's
within the requirements of using GPL libraries.
The argument about "linking means you have to release your code under the
GPL" has been disproven time and time again.
Jim
True. Perhaps I should've written "the copyright owner can always
dual-license it", but that would lead to further ambiguity, like in the
case of someone submitting code to a large project only to find out it
really wouldn't matter to dual code his lone little patch. What sense
does it make to release it in, say, a closed-source license, something
that is but a little part of a far larger GPL'd whole and which wouldn't
exist independently of it?
I thought I said that in that very sentence, but now reading it looks
ambiguous, yes. Sorry.
> of a GPLed project, and force them to release it under the GPL.
It doesn't force anyone any more than the GPL forces everyone to use Linux.
Jim Henderson escreveu:
> libraries.
Hmm, this sounds weird. You mean dynamic linking an app against a GPL
lib doesn't require one to GPL the app code as well? If so, what's the
point of the LGPL?
And I didn't know OpenGL was GPL'd. In fact, it's a specification only.
Are you talking about the mesa lib?
Then what's the LGPL for?
Note that OpenAL is apparently LGPL, so it specifically says you can link to
it without invoking the GPL.
> code.
Define "incorporate"? Look at the first paragraph of
http://www.fsf.org/licensing/licenses/why-not-lgpl.html
It doesn't sound like the FSF agrees with you.
> license it.
Unless it's a plug-in for GCC.
Agreed. I'm not arguing the GPL is a bad thing, even. I'm simply pointing
out that a lot of the slogans promoted by FSF supporters are wrong.
The gcc changes aren't aimed at making sure the plug-ins are "free
software". They're aimed at making sure the plug-ins are "copyleft".
"Ouch ouch ouch!"
It doesn't. I don't think anyone would complain that a patch to the
internals of the Linux kernel won't get incorporated unless they too are GPLed.
It's major functionalities, like, say, plug-ins, that people might want to
dual-license.
I see.
>> code from people that doesn't fall under the GPL and doesn't contain
>> any code of a GPLed project, and force them to release it under the GPL.
No, the GPL doesn't. But that's exactly what the FSF is trying to do for gcc
plug-ins. Remember where the thread started? Did you read the article that
was linked? The article was specifically "how can the FSF force gcc plug-ins
to be released as GPL even if they don't incorporate any GPLed code?"
"Ouch ouch ouch!"
