POV-Ray : Newsgroups : povray.off-topic : Physics, relativity, quantum, etc. Server Time
6 Sep 2024 11:16:48 EDT (-0400)
  Physics, relativity, quantum, etc. (Message 1 to 10 of 219)
Subject: Physics, relativity, quantum, etc.
Date: 19 Jan 2009 13:07:51
Message: <4974c177$1@news.povray.org>
I thought Warp might like seeing this, since he has talked about relativity
and warped space time and (I think) dark matter here before.
http://www.newscientist.com/article/mg18925423.600-three-cosmic-enigmas-one-audacious-answer.html
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Subject: Re: Physics, relativity, quantum, etc.
Date: 19 Jan 2009 14:10:36
Message: <4974d02c@news.povray.org>
"One such problem arises from the idea that once matter crosses a
black hole's event horizon - the point beyond which not even light can
escape - it will be destroyed by the space-time "singularity" at the
centre of the black hole. Because information about the matter is lost
forever, this conflicts with the laws of quantum mechanics, which
state that information can never disappear from the universe."
  General relativity predicts one thing, quantum mechanics another. Why
must GR be wrong and QM right? Why couldn't it be the other way around?
"Another problem is that light from an object falling into a black
hole is stretched so dramatically by the immense gravity there that
observers outside will see time freeze: the object will appear to sit
at the event horizon for ever."
  I'm not sure that's exactly correct. From the point of view of an external
observer, when an object approaches the event horizon of a black hole the
frequency of the light coming from that object decreases. If the frequency
of the light decreases to zero, it's basically not emitting any light at
all and thus cannot be observed.
  While from the outside point of view the object never actually reaches
the event horizon, and consequently the frequency of the emitted light
never reaches true zero, there's probably a limit to how low the frequency
can be for it to be observed (as there are such limits in almost everything
related to quantum particles).
  After all, the object cannot (and does not) emit photons forever. It stops
at some point (ie. when it crosses the event horizon), so no infinite amount
of photons can reach the external observer. The external observer sees the
photons coming less and less frequently, until the frequency becomes so low
that it's practically nonexistent.
"The team's calculations show that the vacuum energy inside the shell
has a powerful anti-gravity effect, just like the dark energy that
appears to be causing the expansion of the universe to accelerate. [...]
All observations used as evidence for black holes - their
gravitational pull on objects and the formation of accretion discs of
matter around them - could also work as evidence for dark energy
stars."
  I don't really understand how the same object can both repel (with
antigravity) and attract (with gravity) at the same time. Isn't that
a bit contradictory? Which is it?
"Dark energy stars and black holes would have identical external
geometries, so it will be very difficult to tell them apart,"
  If that is so, then wouldn't it behave in the same "problematic" way
with regard to an external observer watching an object fall towards this
star? What would be the difference?
  The article doesn't claim that time dilation near massive objects doesn't
happen. It just says that time dilation near the event horizon of a black
hole causes problems with respect to quantum mechanics. If these dark stars
behave externally so much like black holes that they would be very hard to
distinguish from them, how does it solve any such "problem"? The time
dilation would still be there due to the mass of the former star being
accumulated close to the Schwarzschild radius.
Date: 19 Jan 2009 14:18:25
Message: <4974d201@news.povray.org>
Warp escreveu:
Besides, I thought Hawking's radiation coming from blackholes explained
that no information is lost or am I lost here? :/
Well, I'm still munching the possibility of being nothing more than a
hologram in a credit card... :P
Date: 19 Jan 2009 14:51:56
Message: <4974d9dc$1@news.povray.org>
Did it say GR is wrong? That quote just says it conflicts.
(FWIW, I'm seeing more articles that imply GR is going to loose to QM than
vice versa, but that might just be because it's easier to experiment on QM
than on GR.)
It's definitely a weird situation. I think the progress of time for someone
falling in seems to be asymptotically zero, but I don't know that means
anything for anyone outside or inside the doomed spacecraft.
> the event horizon,
Why not?  It doesn't slow down - it just moves slower *inside* the space
ship, yes?
I think that's quite the problem there. That's where GR and QM disagree: QM
says there are lower limits on size, frequency, etc, while GR says space is
smooth and continuous.
That does indeed sound strange. Perhaps if either one of us were deeply
schooled in this... :-)
I think it's saying the singularity causes the problem with QM, not the
event horizon. Specifically, when the black hole evaporates due to Hawking
radiation, you've lost the information (namely, the spin and charge and
such) of the particles that fell in.
With a big enough black hole, you'll never know when you cross the event
horizon. If your event horizon is galaxy-sized, the gravitational gradient
is very mild.
> If these dark stars
There wouldn't need to be a singularity in the middle of the black hole.
If/when it evaporates, all the stuff that fell in can come back out the same
way.
I think. I am not a cutting-edge theoretical physicist.
Date: 19 Jan 2009 14:52:58
Message: <4974da1a$1@news.povray.org>
AIUI, that's exactly where the information is lost. The Hawking radiation is
from quantum uncertainty *outside* the black hole, unrelated to what's
inside. That's *why* the information has to be on the *surface* (so to
speak) of the black hole.
Date: 19 Jan 2009 14:54:35
Message: <4974da7b@news.povray.org>
  OTOH Hawking radiation is also an attempt to unify a bit quantum
mechanics with GR. There's practically no concrete proof that it's
actually happening. The physics involved are also rather exotic
(although perhaps not for a quantum mechanic).
Date: 19 Jan 2009 15:27:34
Message: <4974e236@news.povray.org>
> than on GR.)
  OTOH GR has resisted the test of time rather well. Time and again new
tests go just like GR predicts, and no way else. For example some time ago
they published data about the exact measurement of the distance between
the Earth and the Moon for the past 40 years (which can be done with
millimeters of accuracy using lasers and those corner-box mirros there),
and this distance has changed exactly as GR predicts, to umpteeth decimals
of accuracy.
  In fact, the entire theory of dark matter and dark energy exists
*because* of GR, not regardless of it. Galaxies don't behave like they
should, according to GR, if the visible matter would be everything there
is in the galaxy. Neither does the Universe, expanding against GR, unless
there's some umeasured force making it do so.
  It's not like there wouldn't be alternative theories. For example,
similarly to how Newtonian mechanics are a good approximation at small
scales and velocities but start failing at larger ones, it has been
proposed that GR also works well for stellar sizes but not for galactic
ones. That, in a similar way, it starts deviating as we go larger and
larger, and this can be seen from the behavior of entire galaxies and
galaxy groups. This would explain the galaxy rotation abnormality without
having to resort to dark matter which cannot be measured.
  OTOH such theories are not considered viable because they contradict
other measurements, which in turn confirm GR even at galactic scales.
(I think measuring eg. galactic lensing has been used for this purpose.)
That's why the dark matter and dark energy theories are currently considered
the most believable.
  You mean besides being ripped apart by infinite tidal forces? ;)
  From a timescale point of view, an observer falling to a black hole
would not see any change in timescales for himself. How he sees the
rest of the universe, however, is another story.
> > the event horizon,
> ship, yes?
  To the external observer it looks like the falling object slows down in
every aspect. For example if the falling object had a clock (and let's
forget those tidal forces ripping it apart) and the external observer
would look at this clock with a telescope, the clock would slow down
indefinitely. Well, until no photons arrive anymore from the object and
it could not be observed anymore.
  Does QM say that space is not continuous?
> event horizon.
  I think the article is talking about the event horizon in this case
because it talks about the time dilation which happens as an object falls
towards it. This is a direct prediction of GR.
  What happens to the object *after* it has crossed the event horizon
is a rather different issue.
  Assuming Hawking radiation indeed exists...
> horizon.
  I have heard this, I have a very hard time understanding how it would be
possible.
  Space is *really* warped near the event horizon. The closer you get to
it, the more warped it is. If you were to look out of your spacecraft as
it's falling, the universe would look really weird. The closer you are
to the event horizon, the weirder.
  And after you cross the event horizon... Who knows. But you certainly
would *not* see the universe in any normal way, if at all. You probably
wouldn't be able to measure anything of the universe at all (because,
if the GR equations are right, *all* geodesics inside the event horizon
point directly towards the center).
  Some people seem to think that there could be objects "floating" around
inside the event horizon, and that someone could be there and see nothing
unusual. However, if all geodesics are pointing directly towards the
center, I have hard time believing that you could perceive the space
around you as anything "normal". No matter what you do, you go inevitably
towards the singularity. Even trying to stay still is impossible because
time geodesics also point towards the singularity, and advancing in time
moves you towards it.
  Thus also light is moving directly towards the singularity. This would
make it impossible to make any observations about anything else inside
the event horizon because any light hitting you is coming from "above"
and going "down".
  Of course this assuming tidal forces haven't obliterated you into
subatomic particles.
> is very mild.
  Maybe, but trying to make any observation about your surroundings
would be completely impossible, if I have understood correctly. Inside
the event horizon everything goes towards the singularity and there are
no other possible paths.
  I bet this would make eg. a human body keeping its shape a bit difficult.
Date: 19 Jan 2009 15:57:46
Message: <4974e94a$1@news.povray.org>
On the big scale it has. But then, so has QED at the small scale. :-)
Yes. I was pretty impressed when they found colliding galaxies where the
visible matter stopped (due to interactions) but the dark matter could be
seen "splashing" without stopping if you look at lensing effects.
Yes.
I think that's what I was saying. I don't understand why anyone inside *or*
outside would think it takes infinite time to fall in.
> every aspect.
So it stop, hovering against gravity, milimeters above the event horizon? I
find that difficult to understand.
But inside, he'd still be falling. And outside, he'd still be falling, yes?
He'd just look stopped yet still falling to those outside.
I believe that's correct. Or that gravity at least is not continuous
(because nothing is continuous).  I don't really understand it, but my
layman understanding is that GR's math only works if "forces" are
continuous, and QM says that "forces" are not.
>> event horizon.
Yeah.  Really, I didn't think QM had even started on predicting what gravity
would do and how it would work, so I'm quite over my head here. I don't know
where they're getting "quantum effects cause time to slow down" or whatever.
I was saying that the GR singularity in the black hole is what is in
conflict with the information-is-retained part of QM.
If it doesn't, you've still lost the information. :-)
>> horizon.
> possible.
Not necessarily. It's almost really warped just outside, and it's just a
little bit more warped inside. So while the slope is steep, the second
derivative isn't.  At least, that's how I understand it. :-)
> center,
I'm not sure how you can have a geodesic outside in an "orbit", and a
geodesic a milimeter away a "straight line" into the middle. They all point
directly towards the center in their own frame of reference, perhaps? I
think it's over my head.
I would think if you look inwards, you'd see nothing. If you look outwards,
everything would be very (infinitely?) blue-shifted. I've heard it, but I
can't think how it could be true.
I think the bits we've heard is that the tidal forces aren't necessarily
that high. The tidal force is the difference between your head and your
feet, not the absolute "slope" of the spacetime.
It sounds right to me.
That's a good point. Hrm.  It would certainly seem to interfere with
circulation, for example.
Actually, I've read a short fiction story about just such a situation.
Something was randomly bobbling cities, nobody knew what it was, but you
could only move inwards, could only see what's behind you, except the
quantum uncertainty let you see a few feet ahead, move back enough that your
circulation still works, etc.  There were people trained to go in at the
border when it showed up, helping people get to the center, staying safe
until it unbobbled itself.
And then there's "Redshift Rendezvous", which I read decades ago and which
has apparently just now resurfaces.  A novel about bad guys taking over a
hyperdrive spaceship.  "Hyperdrive" as in "the speed of light is different
here", as in "a dozen meters a second", and how the captain takes advantage
of the odd physics to rescue the situation.  A very fun story.
Date: 19 Jan 2009 16:01:57
Message: <4974ea45$1@news.povray.org>
Darren New escreveu:
Now you tell me the universe is discrete!  That's unreal! :P
Date: 19 Jan 2009 16:10:45
Message: <4974ec55$1@news.povray.org>
BTW, the article I read recently that talked about this was discussing a
gravity-wave detector where the amount of random noise they were getting was
pretty close to the amount of noise predicted by this whole
holographic-universe kind of thing.
It was a popular-science article, but google turns up
http://arxiv.org/abs/gr-qc/9906003
that pretty much sums it up, given what we're talking about. :-)
Basically, since the "hologram" of the universe is at 37 billion lightyears,
or whatever it is, but space is much bigger than that surface area, you get
some "blurring" at the quantum level that makes the "pixels" big enough to
actually measure, closer to 10^-15 than 10^-35 or some such.  Way over my
head, but interesting.
