POV-Ray : Newsgroups : povray.off-topic : Unit testing - simple question with long explanation for discussion... Server Time
16 May 2026 06:38:10 EDT (-0400)
  Unit testing - simple question with long explanation for discussion... (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Unit testing - simple question with long explanation for discussion...
Date: 8 Jan 2009 12:39:03
Message: <49663a37@news.povray.org>
Invisible wrote:
>> Normally, a "unit test" covers what would normally be one class, and
>> not a whole operation.
> Again, depends what you test.
Well, I'm kind of taking the definition of "unit tests" as I understand it.
There are four or five other kinds of tests too.
>> I can imagine lots of tests for a postscript parser: The string "one
>> two three" parses into three words, the word "three" winds up on top
>> of the stack, that "1.0" parses as a number but "1X0" doesn't, etc.
> That's the kind of thing I'm trying to do. Except that figuring out
> every possible case is surprisingly hard.
Yes it is. That's why you need to do it. :-)  Run it thru a 3rd-party
postscript interpreter if you don't know what the function is supposed to
be. You don't have to test exhaustively. You just have to figure it out.
Look, you have to figure out every possible case to *write* the code, yes?
> I'm having difficulty figuring out a way to really thoroughly check that
> this works properly. Seemingly you'd need a really big stack of test
> cases, but how do you generate those?
While it's not what most people recommend, you can write the test cases as
you write the code. When you add a check that looks to see if the first
character is a digit and if so takes a different branch, you put in a test
where the first character is a digit and where the first character isn't.
For example.
Better would be to start with a dozen cases you know the answer to, then
parse them until they work, and every time you see something funny or think
of something new, add it to the list of test cases.
It's difficult to exhaustively figure out what you're going to match if you
don't have the right formal tools. (This is why people like regular
expressions and BNF, you see.)
 > (And how do you figure out what
> the "correct" answer is? This is sometimes non-obvious.)
If you can't tell from the spec, you have to run it against someone else's
implementation. If you're attempting to build a compatible implementation,
it has to match Adobe's(?) regardless of what the spec says.
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Date: 8 Jan 2009 13:51:12
Message: <49664b20@news.povray.org>
> to be. You don't have to test exhaustively. You just have to figure it out.
Yeah. But you sit down and write some code which you think should work,
and then you have to write lots of test cases for
- Does it fail on a zero-length literal name. [The spec explicitly
*allows* such names.]
- Does it correctly handle [what would otherwise be] comments inside a
literal string?
- Does it choke if the input contains a comment [and so is non-empty]
but no further actual tokens?
- Does it parse all possible reals, but not invalid ones such as "." and
"e1"?
- Does it handle balanced brackets and escaped brackets in strings?
It's easy to *think* you got all these working, only to suddenly
discover that in some sufficiently obscure case it falls over. :-/
> else's implementation. If you're attempting to build a compatible
> implementation, it has to match Adobe's(?) regardless of what the spec
> says.
I'm not aware of any Adobe implementation that's freely available.
(Except perhaps for the one inside the nearest laser printer. And I
already tried to get that to parse stuff; it didn't seem to want to do
it for some reason.)
http://blog.orphi.me.uk/
Date: 8 Jan 2009 18:58:11
Message: <49669313$1@news.povray.org>
>> yes?
> literal string?
> "e1"?
There's a good start. Why do you think it's hard?
Testing doesn't prove the absence of bugs, only the presence of bugs.
Ghostscript would probably do pretty close, then. :-)
That one was far from free. :-)
Sometimes you need to wrap it up in actual page description stuff, by which
I mean the magic comments that mark the start and end of pages and such.
Date: 9 Jan 2009 04:25:09
Message: <496717f5$1@news.povray.org>
Darren New wrote:
>>> yes?
>> work, and then you have to write lots of test cases for
>> literal string?
>> and "e1"?
Because the list is wildly incomplete. Figuring out how to make a
*complete* list is absurdly hard.
Sure. But I'd like to reveal as many bugs as possible, so...
Yeah, that's what I'm ending up using. (Ghostscript seems to correctly
process just about every *real* page description I've ever come across,
so I guess it's not too bad a comparison.)
Ah, but for me? ;-) I didn't pay...
> which I mean the magic comments that mark the start and end of pages and
> such.
Nope. If I send it a PostScript program that draws some coloured lines
and stuff, it spits out a piece of paper with lines drawn on it. If I
send it another PostScript program [which also works fine in
Ghostscript] that parses a string and writes the results onto the
page... the printer appears to not receive the data. Really weird.
(And if I send a PostScript program containing deliberate errors, the
printer prints out a page with an error message on it.)
Date: 9 Jan 2009 12:37:02
Message: <49678b3e$1@news.povray.org>
You invoked showpage and all that stuff, I assume?  (Along the "is it
plugged in, is it turned on" kind of debugging?)
Take a page that just prints one bit of text, and edit it with notepad or
whatever you prefer, and see if you can get a base for printing?
Date: 9 Jan 2009 13:13:22
Message: <496793c2@news.povray.org>
> or whatever you prefer, and see if you can get a base for printing?
As I say, when I run it in Ghostscript, it works just fine. But it
doesn't seem to want to work on the laser printer I tried it with. (I
guess I could try another...)
Date: 9 Jan 2009 13:24:02
Message: <49679642$1@news.povray.org>
I don't know how ghostscript works per se. You're sending it to the printer,
or the screen?
The point is the PS interpreter in the printer has no good way of knowing
you're done with the page, unlike ghostscript, so you have to add specific
code to the postscript on a printer to say "I've generated the bitmap, so
send it to a page now."  IIRC, that command is called "showpage".
Ghostscript on the screen renders as it interprets, so that's different.
Date: 9 Jan 2009 13:26:27
Message: <496796d3$1@news.povray.org>
> printer, or the screen?
> knowing you're done with the page, unlike ghostscript, so you have to
> add specific code to the postscript on a printer to say "I've generated
> the bitmap, so send it to a page now."  IIRC, that command is called
> "showpage".
Ghostscript also refuses to display anything until you perform a
showpage operation. (Or the deprecated copypage operation, for that matter.)
Date: 11 Jan 2009 21:54:17
Message: <496ab0d9$1@news.povray.org>
Actually, the right answer is to start with the incomplete list, and make
sure that nothing that used to work breaks when you add more.
But the real point of this post: A sample unit test for you:
http://groups.google.com.au/group/comp.lang.misc/msg/6167f34c7fff9570
Date: 12 Jan 2009 04:11:46
Message: <496b0952@news.povray.org>
> make sure that nothing that used to work breaks when you add more.
Well, that too.
Ooo... TMFT? ;-)
