On Wed, 07 Jan 2009 11:28:57 -0800, Darren New <dne### [at] sanrrcom> wrote:
>Stephen wrote:
>> OOI I switched off Vista's UAC to install the new Beta and speedfan reported the
>> HDD temp. When I switched UAC on again only the core temperature showed.
>Are you running speedfan as administrator? I do believe Vista has some weird
>ideas about what's privileged and what isn't. :-)
You're telling me :)
I'm running it in an administrator account but not as administrator. When I ran
it as administrator I got both temps. But only the HDD temp shows in the task
bar, the core temp does not.
Regards
The administrator account by default has UAC turned off. Maybe that's what
you mean, or maybe that's info new to you, but I suspect it's the explanation.
> But only the HDD temp shows in the task bar, the core temp does not.
I think the task bar only shows one temperature, and it's set with a
checkmark somewhere in the UI that says which it shows. As long as you see
it on the full window, it's being monitored. (Same with the fan speed, if
you display that instead.)
Why is there a chainsaw in DOOM?
There aren't any trees on Mars.
I have the UAC turned on, on this administrator account I meant that by
selecting the program from the start menu, right clicking and selecting "Run as
administrator"
I could not find that checkmark.
>As long as you see
I cannot see the fan speed at all, at all.
No big deal.
Regards
> administrator"
I see. As I understand it, that doesn't actually log you on as
administrator. Instead, when you log into an account in the Administrators
group, you get two logins: one with admin privs, one without. The "run as
administrator" means "run with admin privs", not "run under the account
named Administrator". The account with the name "Administrator" is by
default configured to launch every process with administrative privs.
I fear I have retired all the machines with that installed, or I'd fire one
up and see if I can find it. Sorry.
Probably not monitored, then.
>> administrator"
Thanks for clearing that up.
No problems :)
Probably not ;)
Regards
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:au9am4l1vav81ne6uv3vqr7hp806r6udga@4ax.com...
> No big deal.
It's not on the left like in the attached?
~Steve~
> Regards
> Stephen
Download 'SF_SS.jpg' (85 KB)
Preview of image 'SF_SS.jpg'
Craziest colour scheme *ever*! >_<
"Invisible" <voi### [at] devnull> wrote in message
news:49661070$1@news.povray.org...
No, it's what suits me and what i'm used to, it hasn't changed for
nearly 10 years now.
Show us yours.
OK, well each to their own. It's a free country. ;-)
(I am a little puzzled as to how you can read black on a dark blue
background, but still...)
> Show us yours.
Why bother? It's just the standard grey and black.
news:496613b0@news.povray.org...
Dark blue?? O.O
>> Show us yours.
Just as bad then.
