Stephen wrote:
> Use a small screwdriver as a stethoscope. Press the handle against the cartilage
> in front of auditory canal, closing the ear and place the blade against the tape
> drive at various places to see if you can identify where the noise is coming
> from.
*Clearly* you've done this a great many times before. ;-)
>> from.
Just one of the tricks of the trade ;)
Another one is, we have heat receptors just below the lower lip that can
distinguish temperature differences better than our fingertips. Putting
components (close to) there can sometimes tell you if one is overheating.
In a similar vein, if you are in a building that is on fire (maybe you are
trying to rescue your mother's electric drill or you favourite Haskell book) and
your earlobes start to tingle. Then it is really time to get out.
Regards
Any which trade would that be then?
Heh. I've got a laptop which I *think* might have overheated. But can I
find a reading for the core temperature?? What do *you* think? :-P
Yeah. Because the building on fire would merely be a mild suggestion. :-D
Electronic Engineering. I was a maintenance engineer for 26 years.
Have you tried speedfan?
http://www.almico.com/speedfan.php
My laptop is running at 85 deg C
Sometimes there are situations where you put yourself in danger. Real fires are
not like Hollywood fires. :)
Regards
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:tetmk49e2gmdse9c1uk1bm1mglkak6utbe@4ax.com...
> The chattering is probably the tensioning system and the tape drive
> starting and
> stopping as the data is read.
If the tape has got alot of mileage on it perhaps it's what I used to call
tape fatigue. Take a look at the edges of the tape. Small ripples?
On Fri, 19 Dec 2008 08:20:59 -0400, "Jim Holsenback" <jho### [at] hotmailcom>
>> starting and
Yes, when faultfinding (UK usage) it is a good idea to use all of your senses.
Regards
I'm curious... what does tingling earlobes signify?
~Mike
On Fri, 19 Dec 2008 07:10:07 -0600, Mike Raiford <"m[raiford]!at"@gmail.com>
It is too hot :)
Also the tip of your nose tingles as well.
Tips I picked up on fire fighting courses, when I worked off-shore.
Regards
> It is too hot :)
Huh. And here I was thinking it was because a wind might be blowing by
you as a backdraft forms.
~Mike
Weee....
http://stilbild.nu/backdraft.jpg
