POV-Ray : Newsgroups : povray.off-topic : Really strange design choices Server Time
16 May 2026 09:05:29 EDT (-0400)
  Really strange design choices (Message 21 to 30 of 37)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Really strange design choices
Date: 18 Dec 2008 11:56:40
Message: <494a80c8@news.povray.org>
Orchid XP v8 wrote:
> Why...why...WHY...why would they do this? o_O
I wonder if anybody will figure out where this is quoted from...
Subject: Re: Trixy
Date: 18 Dec 2008 12:06:11
Message: <494a8303$1@news.povray.org>
Invisible wrote:
> - There can be *zero* or more characters before the decimal point. (But
> notice that there must be more than zero characters *in total* before
> and after the decimal point. It's just that there can be zero in either
> place, but not both.)
A quickie C# example ...
Code:
     class Program
         static string[] tokens = new string[] {"0.", ".0", ".", "1.1",
"1.1.1", "1e1", "1x1", "s1", "1s"};
         static void Main(string[] args)
             Regex rx = new
Regex(@"^[+-]?(([0-9]*(\.[0-9]+)?)|([0-9+]\.))(e[0-9]+)?$");
             foreach(string t in tokens)
                 if(rx.Match(t).Success)
                     Console.WriteLine("\"{0}\" --> Real", t);
                 else
                     Console.WriteLine("\"{0}\" --> Identifier", t);
             System.Console.ReadKey();
Output:
"0." --> Real
".0" --> Real
"." --> Identifier
"1.1" --> Real
"1.1.1" --> Identifier
"1e1" --> Real
"1x1" --> Identifier
"s1" --> Identifier
"1s" --> Identifier
The relavent portion is this regex:
Which does what Warp describes, but also takes care of the case with .0
and 0.
> - The "e" can also be "E".
you can easily replace the e for exponent with [eE], which allows either
lower or upper case. :)
> - The exponent is an integer, not a real.
> See? Not as easy as it looks, is it? Gotta pay careful attention to
> *exactly* what the manual says is and isn't permissible.
>>   In an actual BNF-style parser the rule probably becomes simpler because
>> the repetition can be removed.
> It would be *really nice* if the reference manual included a BNF syntax
> diagram... :-S
> Between the rules for splitting up tokens, the tricky rules for escaping
> things in strings, and characters that have multiple meanings depending
> on context, it's really quite hard!
> E.g., "<" is the start of a string, "<~" is the start of another string,
> and "<<" is an ordinary name object. Go figure. Similarly, "[" is
> classified as a "delimiter character", yet it's also the *name* of an
> operator (and a name is a sequence of "regular characters" - that is,
> can't contain delimiters).
> It all gets confusing very fast...
~Mike
Subject: Re: Trixy
Date: 18 Dec 2008 12:22:16
Message: <494a86c7@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> >     ^[+-]?([0-9]+\.?|[0-9]*\.[0-9]+)(e[+-]?([0-9]+\.?|[0-9]*\.[0-9]+))?$
> ...which would be incorrect then, for at least the following reasons:
  Which is exactly what "[0-9]*\." means: Zero or more digits, followed
by the dot character.
  That's easy to fix: Replace "e" in the regexp with "[eE]".
  Then it becomes simpler:
    ^[+-]?([0-9]+\.?|[0-9]*\.[0-9]+)([eE][+-]?[0-9]+)?$
  In fact, that pattern actually matches the floating point number
representation in C and C++ (except perhaps for possibility of a
preceding +).
  It was not a question of difficulty. It was a question of me not knowing
the exact format of floating point numbers in PostScript and making
assumptions.
Subject: Re: Trixy
Date: 18 Dec 2008 12:43:13
Message: <494a8bb1$1@news.povray.org>
Invisible wrote:
> There is also a whole bunch of "interesting" rules about how token
> parsing works.
Sounds like a state machine to me. AKA a regular expression.
Sounds like your parser is too complex.
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
Subject: Re: Trixy
Date: 18 Dec 2008 14:02:42
Message: <494a9e52@news.povray.org>
  Any regular expression can be converted into a state machine, but can
every state machine be converted into a regular expression? Is there a
one-to-one relation?
Subject: Re: Trixy
Date: 18 Dec 2008 14:41:36
Message: <494aa770$1@news.povray.org>
In the original definitions of those two terms, yes. Obviously, by the time
you get to Perl regular expressions, they're no longer "regular" in the same
sense. If you stick to regular expression algebra as invented by Kleene,
they're equivalent specifications of the same languages. (One can wind up
exponentially larger than the other, mind.)
Date: 18 Dec 2008 15:26:12
Message: <494ab1e4@news.povray.org>
Orchid XP v8 wrote:
> Eero Ahonen wrote:
>> I assume you are already aware of this, but I'll provide a link anyways:
>> http://circle.ch/blog/p558.html
Search in povray.general about that guy who wanted to make a webserver in
POV SDL.
(I don't think it's possible without adding for example other I/O
facilities)
Date: 18 Dec 2008 17:15:46
Message: <494acb92$1@news.povray.org>
It rings a bell from a Friends episode.
Subject: Re: Trixy
Date: 18 Dec 2008 20:45:00
Message: <web.494afc0bac85e77ef3c2d8260@news.povray.org>
Maybe the problem is not so much the PostScript language he tries to
*interpret*, but that Halks... Haks... that hassle of a language he tries to
*implement* it in ;)
BTW - I found PostScript to be one of the most-fun languages to program in...
the whole stack-based approach with reversed notation, the string-handling that
lets you get a substring and then manipulate the *original* string via it, and
so on...
Best thing about it: It usually comes with easy-to-use graphics output :)
Subject: Re: Trixy
Date: 18 Dec 2008 23:06:31
Message: <494b1dc7$1@news.povray.org>
You should look into FORTH.  PostScript is based on it.
