Nicolas Alvarez wrote:
> Darren New wrote:
>> (Or install an X server on Windows.)
> As if that was too hard!
I didn't say it was hard. It's simply unnecessary. Running a program
remotely isn't the only problem this solves. It lets me also set up an
environment at home matching the one at work, including Apache, MySQL, etc
etc etc, none of which reliably work the same under Windows.
I can't believe I'm getting arguments against running Linux on this forum. ;-)
The NFL should go international. I'd pay to
see the Detroit Lions vs the Roman Catholics.
Darren New wrote:
> Orchid XP v8 wrote:
>> I use VNC for this very reason... ;-)
> Yeah. I did too, for a while, until I figured out how to make X run. You
> thought X was slow over a slow network? Try VNC.
I did. Tunnelled over SSH from my home PC to my desk at work. :-D
http://blog.orphi.me.uk/
>> You thought X was slow over a slow network? Try VNC.
You know you've been raytracing too long when you set up a VPN to your
house so you can check your POV-Ray renderings from work! o_O
> etc etc etc, none of which reliably work the same under Windows.
Ah, that answers to my question also.
> forum. ;-)
Well, layering Win+X or Win+Lin+X there should be a slight difference in
eg. memory usage, preferring the first one.
-Aero
I did that. It sucked. Until I switched to RDP, so at least the splash
screen only got sent once a day. :)
Sure. But I have 6G here. I'm not running low any time soon. :-)
Having a lot of something doesn't automatically mean it's wise to use it
as quickly as possible ;). But yes, while you practically need to run
Linux somehow anyway, the solution sounds more than reasonable.
-Aero
I already have Linux installed. That doesn't mean I always want to boot out
of Windows, interrupting what I'm doing, in order to load Linux when I need
it. :-)
> out of Windows, interrupting what I'm doing, in order to load Linux when
> I need it. :-)
Booting between two systems is annoying, especially for cheking some
little thing. It cancels all you're doing in that very moment and takes
time. Hibernating can ease up a bit, while it's not necessary to shut
down all applications etc, but such booting is still a PITA.
-Aero
Or, as one boss said, "The transistors don't get tired. That's why they're
there."
