POV-Ray : Newsgroups : povray.off-topic : A small security problem Server Time
2 Jul 2026 00:47:17 EDT (-0400)
  A small security problem (Message 11 to 20 of 28)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: A small security problem
Date: 8 Dec 2008 17:31:10
Message: <493da02e$1@news.povray.org>
Nicolas Alvarez wrote:
> http://tinyurl.com/6xqhbr
Yeah, it's tucked away in there, but it's not "hard" to find if you
realise it exists and you go look for it.
> Registry key:
Very easy to overlook. But then, raw registry editing demands knowledge
and caution anyway! o_O
> Service:
> http://blog.binaryfactory.ca/wp-content/uploads/2008/05/gpodefault.jpg
Riiiight. And, as you obviously realise, the article this is from is
describing how to apply security to services using a *Group Policy*.
And, as you also know, Group Policies DO NOT WORK WITH NT. :-P
http://blog.binaryfactory.ca/2008/05/windows-service-permissions-concerns-when-hardening-servers/
Now, Mr Smarty, if you know how to actually do this *in Windows NT*,
_then_ I'll be impressed. Cos I've spent all ****ing day trying to find
it. :-(
> Share:
> http://www.get-digital-help.com/permissions-recorded-tv.png
Yeah, everybody knows about files and shares.
> Exchange mailbox:
> http://tinyurl.com/6m4ere
I don't even have access to *touch* our Exhange system...
You didn't show the UI for changing the ACLs on running processes. :-P
http://blog.orphi.me.uk/
Date: 8 Dec 2008 17:32:03
Message: <493da063$1@news.povray.org>
>> Service:
> Hmmm... Where did you get that page from? It's not in my interface
> anywhere obvious. Are you sure that's not specific to the print spooler?
It's a Group Policy setting. You won't find it in the Settings applet on
the Control Panel.
Date: 8 Dec 2008 17:33:13
Message: <493da0a9@news.povray.org>
Darren New wrote:
> And as long as we're pointing out the obvious... :-)
> This is from Vista. I think you need regedt32 to get the "permissions"
> tab under pre-XP systems.
Yes, I found that some time ago.
(Some KB article on fixing an obscure glitch in Office 97 due to a
registry key having the wrong permissions... Apparently it was designed
with Windows 95 in mind, which doesn't "have" security.)
Date: 8 Dec 2008 17:37:34
Message: <493da1ae@news.povray.org>
Darren New wrote:
> And yes, everything has ACLs attached, including all your devices,
> processes, connections, etc etc etc. Everything you can name in the
> kernel has ACLs on it.
I wonder... what do the ACLs on a process do? (Not to be confused with
the security tokens the process has. These presumably control what the
*process* is allowed to do, whereas the ACLs control what *you* can do
to that process.)
>> Anyway, apparently Process Explorer has the power to show _and edit_
>> the ACLs associated with a running service. (It's unclear whether it
>> changes the security token on the running process, or actually changes
>> the service configuration so that it will have the new security
>> *every* time it's run.)
> It changes it next time it runs, if you change it from the service
> configuration screens. (You know, the same set of tabs that shows you
> what other services and stuff it depends on, not the "task manager"-like
> stuff. I don't know which PE you're using there.)
I hunted around for ages in there. I found the controls to change the
account the service runs under, but nothing to change the ACLs on the
service.
>> And now I'm wondering... maybe it's a "right" you can set?
> That was my second suggestion. It'll likely be in the "user rights
> assignment" list if it is. Maybe domain controllers have more of this
> sort of thing than the individuals?
Even in NT, the User Manager thingy has a panel hidden away somewhere
for controlling password expiration times and such, and another next to
it for controlling... well, I forget exactly. But maybe I'll find
something useful in there? I'll take a look tomorrow.
>> Otherwise, yeah, I'm going to end up writing some horribly hackish
>> script to kill and restart this damned service. :-(
> It's that, or learning some deep Windows juju to invoke the LoginUser
> API to change your own ownership when the program runs. Maybe you could
> have a "run as" script?
Well, since I know how to program in C++ now, that should be easy! :-D
(I jest. Obviously.)
> Does this help?
> http://www.codeguru.com/cpp/w-p/system/article.php/c5755
> At least someone else wrote the hacky script for you. :-)
Well, that looks like my backup plan...
Date: 8 Dec 2008 17:38:26
Message: <493da1e2$1@news.povray.org>
Darren New wrote:
> http://support.microsoft.com/kb/256345/EN-US/
> That says Windows 2000, but it might be similar on NT?
Group Policy is not supported on NT.
Windows 2000 and higher.
Major PITA, actually...
Date: 8 Dec 2008 18:41:18
Message: <493db09e$1@news.povray.org>
> the Control Panel.
OK. Must be something in the "server" version of the OS that I never had to
administer. All I have is "local policy" tabs.
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
Date: 8 Dec 2008 18:46:50
Message: <493db1ea@news.povray.org>
Can you debug it? Can you send it a signal? Can a COM object talk to it? Can
you change its priority?
Try starting up the task manager and killing off csrss.exe or the login
process (winlogin.exe?) and see what you get.
That's what I was talking about. Sorry I couldn't help.
Here, it's in CP->Local Security Policy->Local Policies. You probably have
something for group policy management, which I certainly wasn't using back
in NT4 days. :-)
You're thinking of userpassword2.cpl or some such. (userpswd2?) It's not
there, I don't think. That lets you assign users to groups, not rights to
groups.
Date: 8 Dec 2008 20:10:14
Message: <493dc576@news.povray.org>
>> Service:
Google Image Search...
Date: 8 Dec 2008 20:11:06
Message: <493dc5a9@news.povray.org>
> it. :-(
I have only ever touched group policy in Windows XP.
Date: 9 Dec 2008 11:39:26
Message: <493e9f3e$1@news.povray.org>
Orchid XP v8 wrote:
> And now I'm wondering... maybe it's a "right" you can set? (As you may
> remember, permissions apply to resources, rights apply to users.) I
> wonder if I can either assign the "stop service" right to a user group,
> or else create a mini-admins group and somehow revoke the "kick people
> off" right?...
Apparently yes.
Apparently anybody who has the "load or unload a device driver" right
can also start and stop system services. (WTF?) So all I need to do is
create a suitable group and assign people to it and I'm done. Yay, me! :-D
