On Tue, 02 Dec 2008 12:58:51 -0500, Tom Austin <taustin> wrote:
>A internal resistance may build due to age, but I think that is
>different that what I am referring to.
Yes, I agree it is different. I'd not heard of a film on the electrode before.
Regards
On Tue, 2 Dec 2008 20:20:51 +0200, "Gail" <gail (at) sql in the wild (dot) co
[dot] za> wrote:
>No. I live in a city.
Sorry Gail, I'm not a very literal person. I surmised that you lived in the city
from what you've said before. That was my idea of a joke, sorry.
>The tallest trees around here come to about the top of my window. Pity
>they're too far away to give effective shade.
Shame! They are so far away but then the upside is that they don't block your
view and you have something to look at.
>The building is pretty high. The ground floor (which is a parking area) is
>about 4 m high (a guess, I haven't measured). The floors aren't as high, but
>my ceiling is 2.75 m above the floor (which really made curtains expensive,
>and doesn't help with the temp in winter)
Ouch! But at least your room must be airy.
Regards
I was using the term 'film' because I lacked a better term at the
moment. It's a buildup of 'something'
I got curious and looked up a few sources
I'm not crazy - I actually found something.
apparently it is called a 'passivation layer'
http://www.spectrumbatteries.com/id6.html
http://www.electrochemsolutions.com/pdf/Passivation.pdf
http://www.bealecorner.com/trv900/battery/lithium.html
I believe it has to do with low current draw.
Low current does not burn off the passivation layer that forms, yet you
do not see much affect because the current draw is low and the internal
resistance drops little voltage.
But as soon as you need a higher current from a battery with a big
passivation layer, the voltage drops due to the internal resistance.
Most electronics sense the low voltage and indicate low battery and shut
off.
If they would stay on for a couple of minutes the passivation layer
would be burned off and the voltage would return to normal.
I don't know what 'chemistries' of Li-ion batteries have this problem -
apparently someone thought the SONY Infolithium batters did.
Tom
Darren New wrote:
> Orchid XP v8 wrote:
>> Recipe...book...?
> Yeah. I think they had some ROM left over or something. Who would put a
> 50" TV in the kitchen, tho?
I just found a TV that also contains 6 famous paintings which you can
watch instead of watching TV... WTF?
http://blog.orphi.me.uk/
That was very interesting now I'm worried about the heat transfer from my CPU
core to the battery. :)
No big deal I suppose if you include a start up timer
Regards
Now *that* is a good idea. You hang up a huge TV on a flat wall, and when
you're not watching TV, it looks like a painting instead of a big flat chunk
of pointless glass.
Slow glass would be even better, but they haven't invented that yet.
The NFL should go international. I'd pay to
see the Detroit Lions vs the Roman Catholics.
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:gb1bj4992supdiml4f75dj02tqkkedfm7v@4ax.com...
> co
> the city
And that was a very tongue-in-cheek reply...
Need more smilies.
You do know your 1960's SF :)
Have a brownie point.
Regards
On Tue, 2 Dec 2008 22:49:50 +0200, "Gail" <gail (at) sql in the wild (dot) co
>> co
>> the city
Phew! Thank goodness, here's me thinking that you thought that I thought you
were a dryad.
>Need more smilies.
Now I thik that you're Warp :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-)
Regards
On Tue, 02 Dec 2008 22:07:14 +0000, Stephen <mcavoysAT@aolDOTcom> wrote:
>Now I thik
Now I'm thick (think).
Regards
