POV-Ray : Newsgroups : povray.off-topic : And you thought Andrew was a geek Server Time
6 Sep 2024 15:18:35 EDT (-0400)
  And you thought Andrew was a geek (Message 1 to 10 of 12)
Subject: And you thought Andrew was a geek
Date: 28 Nov 2008 02:52:57
Message: <492fa359@news.povray.org>
Courtasy of one of the SQL MVPs (and reposted with his permission)
Here's the Mandelbrot set in T-SQL.
Why? Because we can....
-- ORIGINAL AUTHOR: GRAEME JOB
-- ORIGINALLY CREATED: 12-OCT-2008
-- ADAPTED BY: STEVE KASS
-- BECAUSE: IT'S EVEN SHORTER AND FASTER
WITH GEN(V, IV) AS (              -- DIM GENERATOR
   SELECT CAST(0 AS FLOAT) AS V, 0 AS IV UNION ALL
   SELECT CAST(V + 0.031 AS FLOAT) AS V, IV + 1 AS IV
   FROM GEN
   WHERE IV < 100
),XGEN(X, IX) AS (              -- X DIM GENERATOR
   SELECT -2.2+V AS X, IV AS IX FROM GEN
),YGEN(Y, IY) AS (              -- Y DIM GENERATOR
   SELECT -1.5+V AS Y, IV AS IY FROM GEN
), Z(IX, IY, CX, CY, X, Y, I) AS (           -- Z POINT ITERATOR
   SELECT IX, IY, X, Y, X, Y, 0
   FROM XGEN, YGEN
   UNION ALL
   SELECT IX, IY, CX, CY, X * X - Y * Y + CX, Y * X * 2 + CY, I + 1
   FROM Z
   WHERE I < 26
   AND X * X + Y * Y < 16
), ZR(IX, IY, C, R) AS (
   SELECT
     IX, IY, CASE WHEN I > 25 THEN ' ' ELSE SUBSTRING('
.,,,-----++++%%%%@@@@###',I,1) END,
     ROW_NUMBER() OVER (PARTITION BY IX, IY ORDER BY I DESC)
   FROM Z
   SELECT
[0]+[1]+[2]+[3]+[4]+[5]+[6]+[7]+[8]+[9]+[10]+[11]+[12]+[13]+[14]+[15]+[16]+[17]+[18]+[19]+
[20]+[21]+[22]+[23]+[24]+[25]+[26]+[27]+[28]+[29]+[30]+[31]+[32]+[33]+[34]+[35]+[36]+[37]+[38]+[39]+
[40]+[41]+[42]+[43]+[44]+[45]+[46]+[47]+[48]+[49]+[50]+[51]+[52]+[53]+[54]+[55]+[56]+[57]+[58]+[59]+
[60]+[61]+[62]+[63]+[64]+[65]+[66]+[67]+[68]+[69]+[70]+[71]+[72]+[73]+[74]+[75]+[76]+[77]+[78]+[79]+
[80]+[81]+[82]+[83]+[84]+[85]+[86]+[87]+[88]+[89]+[90]+[91]+[92]+[93]+[94]+[95]+[96]+[97]+[98]+[99]+[100]
   FROM (
     SELECT IX, IY, C FROM ZR WHERE R = 1
   ) AS P(IX,IY,C) PIVOT (MAX(C) FOR IX IN (
[0],[1],[2],[3],[4],[5],[6],[7],[8],[9],[10],[11],[12],[13],[14],[15],[16],[17],[18],[19],
[20],[21],[22],[23],[24],[25],[26],[27],[28],[29],[30],[31],[32],[33],[34],[35],[36],[37],[38],[39],
[40],[41],[42],[43],[44],[45],[46],[47],[48],[49],[50],[51],[52],[53],[54],[55],[56],[57],[58],[59],
[60],[61],[62],[63],[64],[65],[66],[67],[68],[69],[70],[71],[72],[73],[74],[75],[76],[77],[78],[79],
[80],[81],[82],[83],[84],[85],[86],[87],[88],[89],[90],[91],[92],[93],[94],[95],[96],[97],[98],[99],[100])
) AS Piv
Requires SQL 2005 or higher.
Subject: Re: And you thought Andrew was a geek
Date: 28 Nov 2008 03:15:00
Message: <web.492fa75bac6f151465d3b2410@news.povray.org>
What do you say about us to them?
Date: 28 Nov 2008 03:28:10
Message: <492fab9a@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> wrote in message
news:web.492fa75bac6f151465d3b2410@news.povray.org...
> It can't be much good :)
Don't think I've said anything. We mostly talk SQL. No surprise there
Date: 28 Nov 2008 07:08:07
Message: <492fdf27@news.povray.org>
  A version of this?
http://thedailywtf.com/Articles/Stupid-Coding-Tricks-The-TSQL-Madlebrot.aspx
Date: 28 Nov 2008 07:38:31
Message: <492fe647@news.povray.org>
news:492fdf27@news.povray.org...
>  A version of this?
Yup.
One of the guys looked at it and said to himself, I can make that more
efficient, and proceeded to do go
Geek level 1 - writing something useless just for fun
Geek level 2 - rewriting it to make it run faster.
Date: 28 Nov 2008 07:42:15
Message: <492fe727$1@news.povray.org>
Geek level 3 - rewriting it in an exotic Turning-complete gibberish
language just to prove you can.
Date: 28 Nov 2008 08:05:03
Message: <web.492febe9ac6f151465d3b2410@news.povray.org>
Rather you than me, then :)
Date: 28 Nov 2008 08:08:45
Message: <492fed5d@news.povray.org>
  There is certain fun in stressing programs or devices with unusual code.
  It's a shame that almost no printer nowadays supports reading and
interpreting PostScript anymore (nowadays almost every single one of them
has a OS driver which interprets the PostScript on the computer and only
then sends the chewed up page data to the printer), but in the good old
days when PS files were sent *raw* to printers and the printer interpreted
it, it was fun to send a PostScript Mandelbrot for them to ruminate about.
http://warp.povusers.org/MandScripts/ps.html
  Remember that back the first year I was at the University I tried it with
a printer there, and it took it something like a half an hour to print it.
Many years later I tried it again with a newer printer, and it had printed
it before I could get from the computer to the printer.
Date: 28 Nov 2008 08:12:42
Message: <492fee4a$1@news.povray.org>
Hey, I STILL DO THIS! :-D
I know most cheap printers don't support PostScript, but IME
industrial-grade laser printers still accept raw PS as input. (E.g., our
recently-purchased HP LaserJet 4250 accepts it just fine.)
I think it's just cheaper to make the host do it then put a powerful
computer inside the printer itself. Makes the printer cheaper.
(Do you remember the scandle of "win modems"?)
Date: 28 Nov 2008 10:42:51
Message: <4930117b$1@news.povray.org>
INSERT INTO laughable_things (name,scale) VALUES('povray.off-topic',5);
COMMIT;
