Subject: Re: Phone for Invisible...
Date: 25 Nov 2008 07:43:35
Message: <492bf2f7@news.povray.org>
scott wrote:
> sub-pixel. In current displays it doesn't matter if your display gets a > bit darker after a year or two of use, but it will be a bit annoying if > you get a permanent imprint of the windows task bar at the bottom of > your monitor :-)
You mean there'd be a real reason to have a screen saver again? LOL!
Date: 25 Nov 2008 09:07:40
Message: <492c06ac$1@news.povray.org>
Yeh it looks like it! Actually there is a SOny 11" OLED TV on Amazon, I was
reading through the user manual (from the Sony website) and it said that is
shifts the image around every so often to avoid burn-in.
I would be more concerned though about people who use their computers a lot,
I mean my screen saver is hardly ever on because I'm mostly at the computer
during the day. There's a timer on my old monitor (that I just use as a
secondary display for my laptop now) which says it's been on for 6519 hours.
I would hazard a guess that for the majority of that it's said "Start" at
the bottom left corner! Even with standard LEDs, after 6000 hours you are
going to see at least a 10% drop in brightness (which you hardly notice on
LCD because it affects the whole image), I think this would be quite visible
if it varied pixel by pixel though.
Date: 25 Nov 2008 09:27:19
Message: <492c0b47@news.povray.org>
scott <sco### [at] scottcom> wrote:
> Yeh it looks like it! Actually there is a SOny 11" OLED TV on Amazon, I was > reading through the user manual (from the Sony website) and it said that is > shifts the image around every so often to avoid burn-in.
Wouldn't help with larger areas with an uniform color...
Date: 25 Nov 2008 10:23:18
Message: <492c1866$1@news.povray.org>
>> Yeh it looks like it! Actually there is a SOny 11" OLED TV on Amazon, I >> was>> reading through the user manual (from the Sony website) and it said that >> is>> shifts the image around every so often to avoid burn-in.>> Wouldn't help with larger areas with an uniform color...
Agreed, but at least the moving around should stop any recognisable pattern
burning in - like the word "Start" or "88:88:88" where the clock is - it
would just be more of a dark blur in that area.
I guess this is primarily a TV so there probably won't be the same issues as
with a computer monitor or any other display where static information is
shown in certain areas of the screen.
