POV-Ray : Newsgroups : povray.off-topic : Processor speed Server Time
7 Apr 2026 10:31:36 EDT (-0400)
  Processor speed (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Processor speed
Date: 28 Oct 2008 13:25:04
Message: <49074aef@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Is integer addition faster or slower than floating-point addition?
  Impossible to say. It depends on the processor type, the integrity of
the pipelines, the combination of instructions, and tons of other things.
  It also depends on what you are doing. If you are loading the values of
two variables into the FPU, calculating the addition, and then storing the
result into a variable, then that's definitely slower than integer addition
because the loads and stores consume a lot more clock cycles for the FPU.
  If you are measuring purely the clock cycles taken by one single addition,
disregarding everything else, then they are probably equally fast (although
with modern Intel/AMD processors I cannot even say that for sure, as they
have microcodes which take fractions of a clock cycle and weirdness like
that).
> How about multiplication?
  It depends on the processor. Some processors have 1-clock-cycle FPU
multiplication, while others don't. Some have special circuitry for
calculating CPU register multiplication in 1 clock cycle, others have
a small fraction of that circuitry which calculates it in 2 or a few
clock cycles, and yet others calculate it with the FPU (which curiously
makes integer multiplication slower than floating point multiplication).
> How do trigonometric functions compare?
  What do you think?
> Is single precision any faster than double precision?
  Only if we measure with the pipeline and cache capacity requirements.
> Are 8-bit integers faster than 16-bit integers?
Date: 28 Oct 2008 15:28:55
Message: <490767f7@news.povray.org>
> that).
Interesting. I have always heard that floating-point arithmetic is much
slower than integer arithmetic. (That's why they invented the FPU, but
it's still slower.) So you're saying they're actually roughly the same
speed now?
 From one table I saw, integer multiplication is significantly slower
than integer addition, and integer division is markedly slower again. I
don't know if the same holds for floating-point though, or how fast/slow
floating-point arithmetic is compared to integer arithmetic in general.
>   What do you think?
I think they're slower, but how much? 2x slower? 20,000x slower? I have
no idea.
OK, cool. So basically there is no way I can tell whether implementing
an algorithm one way or the other will yield the best speed. Yay, me. :-/
http://blog.orphi.me.uk/
Date: 28 Oct 2008 15:31:47
Message: <490768a3@news.povray.org>
It won't tell you everything about the speed of the final program, but I
can't imagine it'd be hard to write some test programs and then time
them to determine some of these answers for yourself.
Date: 28 Oct 2008 15:34:04
Message: <4907692c@news.povray.org>
I guess I'm still used to the Old Days of computing, when the speed of
the CPU was the primary bottleneck. Of course, these days the memory
subsystem is the primary bottleneck - to the point where algorithms
which are "less efficient" on paper can actually run faster in reality
if they have superior cache behaviour.
Obviously, cache behaviour is something I have absolutely no control
over, so there's no point worrying about it.
Date: 28 Oct 2008 15:36:26
Message: <490769ba@news.povray.org>
Not only that, but modern processors can get a significant speed boost
based on the order of instructions presented. e.g. if you have 2
instructions, one dependent on the previous, it's entirely possible to
move an instruction between those two to take advantage of the
processor's pipelining. But, then you have to know what instructions
each pipeline can handle, and those 2 instructions cannot share any
resources. e.g. You may have something like:
(my x86 assembler is a bit rough so my syntax may be off.)
mov ecx, 10h
add ecx, ah
mov ebx, [var1]
add ebx, 16
The above could be rearranged to give better performance:
mov ecx, 10h    ; p1
mov ebx, [var1] ; p2
add ecx, ah     ; p1
add ebx, 16     ; p2
~Mike
Date: 28 Oct 2008 15:41:54
Message: <49076b02$1@news.povray.org>
Not entirely true; If you want good speed I think it's worth trying to
code things so all the necessary memory will fit within your cache.  Of
course this will put a limit on the size of problem you can solve
without slowing things down a bit.  I'm sure that someone like Warp
could give you more detailed pointers, although if you're doing this in
haskell it may not lend itself to this sort of optimization as well as,
say, C++.
Date: 28 Oct 2008 15:50:10
Message: <49076cf2$1@news.povray.org>
> Not entirely true;
Well, no. You can use large arrays and access them in a specific order
in an attempt to improve cache coherancy. But beyond that, in a GC
language where the runtime randomly allocates and rearranges data in RAM
from time to time, you really have very little control.
Date: 28 Oct 2008 16:24:10
Message: <490774ea$1@news.povray.org>
>>> implementing an algorithm one way or the other will yield the best
>>> speed. Yay, me. :-/
>> I can't imagine it'd be hard to write some test programs and then time
Depends on what language you are using.
Even today some programs are written to use only internal registers -
only using external memory when absolutely necessary.
Also, depending on what processing unit you are using it could be faster
to count down to zero than up to a given number - based on the machine
instructions available and the time cost of each instruction.
When you get into high level languages you are going to lose some
efficiency in execution because the focus starts towards ease of actual
programming vs execution efficiency.
You get to a point where the program just runs and the compiler gives
little care to optimizing the execution speed.  It's easier to program,
but at a cost.
Tom
Date: 28 Oct 2008 19:13:15
Message: <49079c8b@news.povray.org>
  Intel processors have reordered instructions automatically since the
Pentium Pro (AFAIR).
Date: 28 Oct 2008 19:24:29
Message: <49079f2d@news.povray.org>
  An FPU addition has taken 1 clock cycle since probably the 486 (the
version which had the integrated FPU), or at most the Pentium.
  The first Intel processor to have a 1-clock-cycle FPU multiplication
was, if I remember correctly, the Pentium. (You can believe this requires
a rather large percentage of the entire area of the microchip.)
  Of course the Pentium was not the first processor to have a 1-clock-cycle
floating point multiplication. Many RISC processors had that probably 10
years earlier. It's old technology.
  Division is much more complicated than multiplication, which is why
it has always taken (and will most probably always take) quite many clock
cycles to compute.
  Of course the actual throughput of the FPU in most programs is slower
than that because of all the data which has to be transferred between the
memory and the FPU. You can write specialized code (usually in ASM) which
takes full advantage of the FPU by calculating as much as possible without
having to constantly load and store the values from/to memory, but compilers
are not even today very good at making this kind of optimization. If you
examine the assembler output of a compiler, you will usually notice that
it loads and stores FPU registers *a alot*, often more than would be
necessary.
  This may be one of the reason why XMM, SSE and other SIMD chips have
been developed, ie. so that with a new protocol it would be possible to
write code which utilizes the auxiliary chip better.
> So you're saying they're actually roughly the same speed now?
  When counting in clock cycles they have been about the same speed since
the 486. The FPU is just a bit hindered by a more complicated data transfer
between the memory and the FPU.
