![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://texturegarden.com/java/rd/
Some seriously interesting stuff happening in there. Now if I could just
figure out the equations involved...
(One day I really must learn how to comprehend differential equations!)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I thought you were trying to simulate an organ pipe. Still, I think you'd
have more chance making one from wood than getting a simulator working that
produces a recognisable organ sound :-)
What bit don't you understand about the reaction/diffusion equations?
There's nothing in there different to the wave equation.
In each cell, U and V are the amount of each chemical.
dU/dt = Du * L(U) - U*V^2 + F*(1 - U)
dV/dt = Dv * L(V) + U*V^2 - (F + k)*V
Du, Dv, k and F are constants. L(x) is the Laplacian operator, which you
know from the wave equation (2nd differential in each direction added
together).
So just calculate the right side of those equations, and that will tell you
how much U and V should change.
Seems simple enough to me to implement if you've done the wave equation.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You know me - if there's a way to use mathematics to produce trippy
visuals, it must be done! ;-)
> Still, I think
> you'd have more chance making one from wood than getting a simulator
> working that produces a recognisable organ sound :-)
Well, I suspect I'm doomed to fail either way, but hey! :-P
> you know from the wave equation (2nd differential in each direction
> added together).
> you how much U and V should change.
The hard part is FINDING THIS EQUATION! >_<
I've found several sites about this stuff, but none of them present a
formula I can comprehend. Now that I have a working formula and I know
what all the variables are supposed to be, I stand a chance...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wikipedia has a more general form under the "Reaction Diffusion Equation"
page, the U*V^2 + F... bits on the right side are specific, and the ones I
posted are from the "Grey-Scott model". I only know that because there was
a chapter in GPU Gems where they implemented it :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Equation" page, the U*V^2 + F... bits on the right side are specific,
> and the ones I posted are from the "Grey-Scott model". I only know that
> because there was a chapter in GPU Gems where they implemented it :-)
LOL! Yeah, everybody uses the Grey-Scott model, apparently. (Probably
because it's the only one they can find equations for!)
Now we know what Doc Brown was yelling about all those times he said
"Grey-Scott!" ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
