POV-Ray : Newsgroups : povray.off-topic : Linux really costs a _lot_ more than $40 Server Time
4 Jul 2026 23:01:47 EDT (-0400)
  Linux really costs a _lot_ more than $40 (Message 71 to 80 of 189)
Subject: Re: Linux really costs a _lot_ more than $40
Date: 1 Nov 2008 11:57:52
Message: <490c7c80$1@news.povray.org>
Eero Ahonen wrote:
> I'm not sure about CD-ROM, but at least Grub is able to boot via PXE.
I've done more experimenting with this, now that I have a Vista machine
I can wipe and restore easily.  I wouldn't recommend trying this without
a complete-machine backup.
At least on the 64-bit OSes (Vista x64 and Suse11 x64) it seems that the
default MBR for either will now try to boot the active partition. That's
nice.
And in spite of the baroque advice on the intratubes, it's pretty
trivial to set up the same mechanism to get Vista to boot Linux without
any extra software necessary (assuming you don't have only a recovery
disk or some other lossage like that).
Install Vista. If it's already installed, shrink the partition from
inside Vista (since it is claimed Linux messes that up on Vista's NTFS).
Install Linux, but don't set the active partition or install grub to the
MBR. (I install it all in one primary partition, just because it's easy
enough to back up only what you want to in Linux.)
Figure out which boot block boots Linux. In my case, it's the boot block
of that one primary partition. It's probably the boot block of whatever
/dev/sda? that holds your root partition. Use dd to make a copy:
dd if=/dev/sda2 bs=512 count=1 of=/media/my-usb-stick/linboot.bin
Boot back to Vista. (If you messed up, boot the Vista disk, go to
recovery, start a command prompt, and use diskpart to set the Vista
partition active.)
Copy x:linboot.bin to (say) the root directory. (Where x: is your usb
stick, obviously.)
Then, tell Vista about it, which goes something like this:
bcdedit /create /d "SuSE 11 Linux" /application bootsector
This will print out a GUID, which you should copy into the copy buffer.
Then bcdedit this, pasting in the GUID for each "<paste>"
bcdedit /displayorder {current} <paste>
bcdedit /set <paste> device partition=C:
bcdedit /set <paste> path \linboot.bin
And if I remember right, that's all you need to do. The next boot will
give you a choice of Vista or Linux.
The advice on the intertubes is to download a replacement for bcdedit
with its own version of grub (which doesn't work, at least with my
suse). It worked when I told it to boot via LILO oddly enough. :-)
One of these days, I'll get around to making my own site for putting up
stuff like this I've figured out that can actually be searched.
Date: 1 Nov 2008 12:11:16
Message: <490c7fa4@news.povray.org>
Eero Ahonen wrote:
> To exactly how many pieces of hardware have you lost the support on
> Linux while upgrading to a newer version of Linux?
That's a very good point.
The webcam is the only one I can think of. (See
http://kerneltrap.org/node/3729 not that it affected me personally)
(I resist the urge to be snarky and talk about losing hardware to new
drivers.
http://fixunix.com/linux/539688-linux-will-destroy-your-hardware.html
Pretty funky story there.   ;-)
I also wonder about the people who use the closed-source video drivers -
do they really keep working with new kernels and ABIs and all? Or does
ATI release a new driver periodically? I honestly don't know, so I'm
honestly asking.
As well, going from 98 to an NT-based kernel killed a lot of software
that bypassed the OS and (for example) frobbed the serial ports
directly. And I wouldn't bet that every video and sound card worked
smoothly on every upgrade of OS, even from 2000 to XP. One of the nice
things about Matrox video cards is they (at least used to - haven't
checked lately) would release drivers for new cards and old OSes, and
for old cards and new OSes.
> If your hw works with Linux now, it'll work for the number of years,
> even if you do update your software. As far as I've understood, if your
> hw works with 2k or XP, you can't be sure it'll still work with Vista.
I'm not sure about Vista 32-bit, but Vista 64-bit requires signed
drivers that have passed MS's testing, because MS was tired of taking
the flack for crappy drivers taking out the OS. If the HW vendor wanted
you to buy a new card rather than keep the one you have, you're pretty
SOL. :-)
Again, sure, your hardware may continue to be supported, but that's
because the drivers are open-source. They don't "keep working" for new
releases, they "get fixed" for new releases. If someone doesn't fix it,
it won't work after they change the ABI again.
The closed-source nature of Windows drivers means there's a much smaller
group of people who can fix drivers for the hardware, and they usually
don't have too much incentive to do so.
Date: 1 Nov 2008 12:17:02
Message: <490c80fe$1@news.povray.org>
Warp wrote:
>   Not so with Windows. Microsoft *must* sell a completely brand new version
> of Windows each n years. Of course people wouldn't buy the new version if
> it was basically identical to the old version, with just internal invisible
> improvements, and perhaps a few new programs (which would work in the old
> version anyways).
I agree.
Actually, I've found a bunch of new good stuff in Vista. It's just hard
to explain to someone who only uses the computer casually. How do you
explain to someone who knows nothing about computers why the backup
utility is superior in the event of a disk crash, for example? Or why
RAID support is improved?
MS has to not only do stuff to improve an OS that's already pretty darn
mature, but also has to make it visibly enticing at first glance,
regardless of what's under the hood.
Of course, MS also has to make it nicer for hardware sellers, since
that's something like 85% of their sales last I heard. So driver stuff
has to be easier, installation has to be easier (even tho most users
never see that), branding has to be easier, and so on.
It's a funky world, comparing commercial to free software.
Date: 1 Nov 2008 12:38:26
Message: <490c8602@news.povray.org>
Darren New wrote:
> It's just hard to explain to someone who only uses the computer casually.
For example, try to explain to someone who doesn't know the difference
between a root account and a normal account why UAC is a good thing. :-)
As far as I can tell, UAC is sudo and nothing more or less, except that
even the root account is required to use sudo to do rooty things, unless
you turn it off. Seems like a reasonable comprimise.
Date: 1 Nov 2008 13:05:09
Message: <490c8c45@news.povray.org>
> honestly asking.
No, and in fact Ubuntu 8.10 currently has worse video performance than 8.04
on nVidia cards. Until nVidia makes an updated driver to work correctly
with the kernel used on 8.10.
Or at least that's what I understood.
Date: 1 Nov 2008 13:56:25
Message: <490c9849@news.povray.org>
  And in many cases they only can do that by breaking the basic engineer
rule "if it works, don't fix it", as well as making the UI so heavy that
you need a supercomputer to run it.
  AFAIK Windows is the only OS out there for which each version has been
slower than the previous version (even with all the eyecandy turned off).
Clearly their priorities are not in efficiency.
Date: 1 Nov 2008 14:12:19
Message: <490c9c03$1@news.povray.org>
On Sat, 01 Nov 2008 13:25:52 +0200, Eero Ahonen wrote:
> That must be the cheapest bonk-line LJ's. All real-printer LJ's I've
> seen have talked PostScript and various PCL versions and are supported
> very widely.
Could be - I don't recall where I saw it, but yeah, in general, if it
support PCL or PostScript, you're good to go.
Jim
Date: 1 Nov 2008 14:12:36
Message: <490c9c14$1@news.povray.org>
On Sat, 01 Nov 2008 13:29:30 +0200, Eero Ahonen wrote:
> Jim Henderson wrote:
>> Oh, that's not Grub, that's SYSLINUX - Grub is hard-disk only to the
>> best of my knowledge.
Is it?  That's new...I've always used PXELinux...
Jim
Date: 1 Nov 2008 14:15:04
Message: <490c9ca8@news.povray.org>
> Linux while upgrading to a newer version of Linux? The difference
> between Linux and Vista here is that if your device worked with Zoot
> (RedHat 6.2) and 2.2 -series kernel, it most probably still works with
> newest SuSE and 2.6 -series kernel - at least if you're still able to
> physically plug the device in.
Arguably, that's only if the driver is part of the kernel build.  I've
got an old flatbed scanner here that the kernel drivers were no longer
developed for after 2.2 kernels.  No matter, because I got a new scanner.
If the code is no longer maintained, then changes in the kernel can (and
do) prevent the module from building at all.
Jim
Date: 1 Nov 2008 14:16:45
Message: <490c9d0d$1@news.povray.org>
On Sat, 01 Nov 2008 09:38:26 -0700, Darren New wrote:
>> casually.
Except that something like kdesu asks you once for the root password (per
run), but UAC asks you incessantly (in my own experience - which is
somewhat limited) whether or not you want to allow X, Y, or Z to happen.
It's not content with just asking once.
Jim
