POV-Ray : Newsgroups : povray.off-topic : Linux really costs a _lot_ more than $40 Server Time
4 Jul 2026 12:26:56 EDT (-0400)
  Linux really costs a _lot_ more than $40 (Message 180 to 189 of 189)
Subject: Re: Linux really costs a _lot_ more than $40
Date: 1 Dec 2008 13:55:06
Message: <4934330a$1@news.povray.org>
Jim Henderson wrote:
> That's not what I read in your post.  I duplicated with the code staying
> the same, but not with it changing.
I take advantage of X windows, ya see. :-)
I find it really hard to believe GCC will compile a program, then read the
output file to see if the result is the same, and if not, only then will
unlink the old code and write the new code.
I'll give it a try next time I'm in Linux, tho.  I suspect it's more some
options on the compiler or file system we have set differently or something.
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
Date: 1 Dec 2008 14:15:21
Message: <493437c9$1@news.povray.org>
> the output file to see if the result is the same, and if not, only then
> will unlink the old code and write the new code.
OTOH it could check mtime of the source and the binary and choose the
way to work. But somehow I even that hard to believe.
-Aero
Date: 1 Dec 2008 14:29:33
Message: <49343b1d$1@news.povray.org>
Except it would have to pretty much compile everything anyway, since
environment variables, command line options, and include files can all
affect the results too. And anyway, I changed the file between runs.
Date: 1 Dec 2008 18:36:22
Message: <493474f6@news.povray.org>
>> staying the same, but not with it changing.
It probably looks to see if the source file changed since the last
compilation (not sure how it tracks that).  All I know is that when I
didn't change the code, the inode stayed the same, and when I did, it
didn't.
> some options on the compiler or file system we have set differently or
> something.
Could be.
Jim
Date: 1 Dec 2008 21:57:13
Message: <4934a409$1@news.povray.org>
I find it hard to believe that GCC would be that broken.
Date: 1 Dec 2008 23:20:31
Message: <4934b78f$1@news.povray.org>
<shrug>  I'm just goin' by my observation.....if you've got a better
explanation, I'm all ears.
Or maybe that's "eyes". ;-)
Jim
Date: 2 Dec 2008 14:30:49
Message: <49358ce9@news.povray.org>
Dunno. Like I said, it may be the compiler version or something. Now, if
you're talking Java, I could understand this, because the Java equivalent of
#include looks at .class files to see if something needs to be recompiled.
I.e., "make" is sort of built in to Java compilers.
darren@dog:~/test> gcc -v
Using built-in specs.
Target: x86_64-suse-linux
Configured with: ../configure --prefix=/usr --with-local-prefix=/usr/local
--infodir=/usr/share/info --mandir=/usr/share/man --libdir=/usr/lib64
--libexecdir=/usr/lib64
--enable-languages=c,c++,objc,fortran,obj-c++,java,ada
--enable-checking=release --with-gxx-include-dir=/usr/include/c++/4.3
--enable-ssp --disable-libssp --with-bugurl=http://bugs.opensuse.org/
--with-pkgversion='SUSE Linux' --disable-libgcj --with-slibdir=/lib64
--with-system-zlib --enable-__cxa_atexit --enable-libstdcxx-allocator=new
--disable-libstdcxx-pch --program-suffix=-4.3
--enable-version-specific-runtime-libs --enable-linux-futex
--without-system-libunwind --with-cpu=generic --build=x86_64-suse-linux
Thread model: posix
gcc version 4.3.1 20080507 (prerelease) [gcc-4_3-branch revision 135036]
(SUSE Linux)
darren@dog:~/test> ls -l
total 28
-rw-r--r-- 1 darren users 67 2008-12-02 10:25 a.c
-rw-r--r-- 1 darren users 67 2008-12-02 10:26 b.c
-rw-r--r-- 1 darren users 22 2008-12-02 11:07 c.c
-rw-r--r-- 1 darren users 22 2008-12-02 10:25 d.c
darren@dog:~/test> cat a.c
#include "c.c"
int main() { write(1, "Hello " XYZ, 12); return 0;}
darren@dog:~/test> cat b.c
#include "c.c"
int main() { write(1, "Zing! " XYZ, 12); return 0;}
darren@dog:~/test> cat c.c
#define XYZ "World\n"
darren@dog:~/test> cat d.c
#define XYZ "xyzzy\n"
darren@dog:~/test> gcc a.c ; ls -li a.out ; ./a.out
1818787 -rwxr-xr-x 1 darren users 11120 2008-12-02 11:07 a.out
Hello World
darren@dog:~/test> gcc b.c ; ls -li a.out ; ./a.out
Zing! World
darren@dog:~/test> cat d.c >c.c
1818787 -rwxr-xr-x 1 darren users 11120 2008-12-02 11:08 a.out
Hello xyzzy
Zing! xyzzy
darren@dog:~/test> cat a.c >b.c
Hello xyzzy
darren@dog:~/test>
Nothing I did changed the inode number of a.out, in spite of getting
different output every time I ran it.
Date: 2 Dec 2008 15:03:07
Message: <4935947b$1@news.povray.org>
> equivalent of #include looks at .class files to see if something needs
> to be recompiled. I.e., "make" is sort of built in to Java compilers.
Might be.  What filesystem are you using?  Maybe it's a question of the
inode allocation system, number of free inodes and the like?
Jim
Date: 2 Dec 2008 15:17:52
Message: <493597f0$1@news.povray.org>
ext3. I don't think that's it. If I delete the a.out and run gcc again, I
get a different inode number.
Date: 2 Dec 2008 16:27:33
Message: <4935a845$1@news.povray.org>
> I get a different inode number.
Interesting; I also am running ext3 here....
Jim
