POV-Ray : Newsgroups : povray.off-topic : Linux really costs a _lot_ more than $40 Server Time
5 Jul 2026 15:41:33 EDT (-0400)
  Linux really costs a _lot_ more than $40 (Message 171 to 180 of 189)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: Linux really costs a _lot_ more than $40
Date: 26 Nov 2008 13:19:05
Message: <492d9319$1@news.povray.org>
On Tue, 25 Nov 2008 17:28:49 -0800, Darren New wrote:
> Jim Henderson wrote:
>> I prefer that the system let me know about an error condition so I can
>> correct the underlying issue, when it comes to things like filesystem
>> errors.
> Of course you find out about the error. I'd just prefer the system to
> not corrupt the file system when something fails.
Corrupting a single file isn't exactly the same thing as corrupting the
filesystem.....cf reference to our previously crashed RAID arrays.
>> A silent failure wouldn't be useful - no indication of success or
>> failure would be even more confusing, IMO.
> What makes you think it would be silent??
That seemed to be what you were promoting.  My mistake if I misread.
> I take it you've never used a database that has transactions. What
> happens is you get back a message saying "your transaction failed
> because the disk was full" (or whatever the reason), and you don't have
> to do anything to put your changes back to how they were before you
> started. So if you say (for example) "delete all the .doc files from
> this directory", and one of them isn't deletable, none of them get
> deleted, and you're told which one can't be deleted.
I've dealt with transactional systems quite a bit, now I see what you
were saying - treat the "package" update as a single transaction.
Somehow I missed that before.  I guess it's been a busy week trying to
wrap things up before the holiday. :-)
>> A good case to be made for doing updates on the local machine rather
>> than the remote machine.  Like I said, management procedures in place
>> for non- standard deployments.
> Right. That's what I'm saying.  Management procedures to work around the
> lack of functionality.
But there again we're talking about configurations that aren't terribly
common these days - they used to be, sure - I can remember Sun systems
with diskless workstations because the versions with disks were so much
more expensive - so the system was completely remotely booted from a
4/290.
>>> Cool. What's the system call in Linux that lets me change three files
>>> consistemtly?  I.e., I have files /tmp/One, /tmp/Two, and /tmp/Three,
>>> and I want to rename them respectively to /tmp/1, /tmp/2, and /tmp/3,
>>> and I never want any possibility of an "ls" operation on the /tmp/
>>> directory to show my /tmp/One and /tmp/3 at the same time, or /tmp/1
>>> and /tmp/Three.  Is there some way to accomplish that?
>> Again, if it's handled as part of the system update, the updater takes
>> care of that for you, not the system.
> That didn't answer the question.  How does the updater make sure that
> you never see a half-renamed collection of files, even assuming we're
> only talking about the updater here?
Because it deals with the individual package updates one RPM or delta
file at a time.
>> You want to implement a filesystem as a database, knock yourself out.
>> ;-)  It's overkill for most applications.
> Not really. ext3 and reiser and all that are already implemented with
> transactions. You just can't get to them.
Where there's a will, there's a way - it is all open source code, so it
wouldn't be impossible to implement for someone who was really determined
to do so.  :-)
Jim
Date: 26 Nov 2008 13:22:46
Message: <492d93f6$1@news.povray.org>
> Your point is that updating a file while it's open and has a shared text
> segment would cause a problem.
No, my point is that there are numerous ways that things can fail, and if
your OS doesn't supply the right tools, you wind up writing ad-hoc manual
work-arounds to recover when the program tells you it failed.
> My point is that if you're *updating* the
> file, the inode changes *unless* the file is being overwritten by an
> unmodified version of that file
Uh, not according to my runs of gcc. Maybe the SuSE updater works that way,
but that just reinforces my point: they have to have an ad-hoc
application-specific work-around for the problem.
> The SUSE updater, though, applies patches, so only files that have
> changed would get updated.......so again, not seeing what the problem is
> here.
That you're discussing something different from what I'm trying to talk about?
You're failing to understand that I'm pointing out something entirely
different than what you're arguing.  I'm pointing out that UNIX has
traditionally addressed limitations in UNIX with ad-hoc manual and/or
application-specific work-arounds, while most other systems incorporate into
the operating system those operations that most applications need. When I
say "it doesn't need to be this bad," you keep answering with "in this one
case, it's possible to work around the problems most of the time if you're
careful."  That isn't the point, tho.
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
Date: 26 Nov 2008 13:29:53
Message: <492d95a1$1@news.povray.org>
No. But since the file system already supports not corrupting the file
system, why wouldn't it support not corrupting the file?
Yes, exactly. Which is hard to do on a file system that doesn't support
transactions, because UNIX traditionally layered transactions and locking on
top of the file system in an application-specific way, just like it layers
"login" on top of the permission system in an application-specific way.
Hence, you have people creating unwritable lock files to lock things, and
the file system can't support things like temp files that only survive until
you log out, and things like that.
> common these days
Sure.  But again, you're looking at the one example and failing to generalize.
> file at a time.
You still didn't answer the question. Look at the actual question:
     consistently?
You said the Linux journaling file systems let you have file system
transactions. I believe it might be there, but I've never found it; it might
be something new. What's the system call?
> to do so.  :-)
Sure. But you implied it's already there.
I just pine for the days when it was possible to write a program that ran
reliably even in edge conditions, rather than being impossible to ensure
that things work correctly because the underlying systems are so half-ass. :-)
Date: 26 Nov 2008 15:41:00
Message: <492db45c$1@news.povray.org>
>> text segment would cause a problem.
> if your OS doesn't supply the right tools, you wind up writing ad-hoc
> manual work-arounds to recover when the program tells you it failed.
>> My point is that if you're *updating* the file, the inode changes
>> *unless* the file is being overwritten by an unmodified version of that
>> file
> way, but that just reinforces my point: they have to have an ad-hoc
You didn't modify the code between compilation runs.  I did - and got
different inodes.
>> is here.
> about?
I'm keeping to the initial point of discussion, which was a perceived
problem with the SUSE updater application.
Jim
Date: 26 Nov 2008 15:46:43
Message: <492db5b3@news.povray.org>
<shrug>  Maybe it does.  I'm not a kernel developer.
> locking on top of the file system in an application-specific way, just
> like it layers "login" on top of the permission system in an
Just at a guess, abstraction layers tend to impact performance.  Look at
the performance of a fuse-based NFS server vs. a kernel-based NFS server.
>>>>> files consistemtly?  I.e., I have files /tmp/One, /tmp/Two, and
>>>>> /tmp/Three, and I want to rename them respectively to /tmp/1,
>>>>> /tmp/2, and /tmp/3, and I never want any possibility of an "ls"
>>>>> operation on the /tmp/ directory to show my /tmp/One and /tmp/3 at
>>>>> the same time, or /tmp/1 and /tmp/Three.  Is there some way to
>>>>> accomplish that?
>>>> takes care of that for you, not the system.
>> file at a time.
>      consistently?
> might be something new. What's the system call?
I'm not a kernel developer, so I don't know what the system call is.
That would be a question for the kernel developers. :-)
>> determined to do so.  :-)
It seems to be IME.  Maybe that's because it's an application-specific
solution implemented - but I point back to the start of the discussion
where you cited problems with the SUSE updater application.  I was
answering that question (at least initially), not getting into a
discussion of kernel-level system calls for transactional dealings with
multiple files, because I'm not a kernel guru.
> ran reliably even in edge conditions, rather than being impossible to
> ensure that things work correctly because the underlying systems are so
> half-ass. :-)
Well, most development is done to the 80/20 rule rather than to "edge
conditions" for economic reasons (at least that's what I'm told).  OSS is
a wonderful thing, though, because those who want to develop to those
"edge conditions" can do so.  :-)
Jim
Date: 26 Nov 2008 17:45:51
Message: <492dd19f$1@news.povray.org>
> different inodes.
Of course I did.
OK.
Date: 26 Nov 2008 20:47:00
Message: <492dfc14$1@news.povray.org>
Actually, it was along the lines of "I wish the Suse updater let me have
multiple programs accessing the database it keeps." :-) Since BDB apparently
allows for multiple readers and writers, I'm not sure there's any
infrastructure reason the updater wouldn't.
Date: 1 Dec 2008 13:14:05
Message: <4934296d$1@news.povray.org>
> apparently allows for multiple readers and writers, I'm not sure there's
> any infrastructure reason the updater wouldn't.
On that point we are agreed. :-)
Jim
Date: 1 Dec 2008 13:14:34
Message: <4934298a$1@news.povray.org>
>> different inodes.
> Of course I did.
That's not what I read in your post.  I duplicated with the code staying
the same, but not with it changing.
> OK.
Jim
Date: 1 Dec 2008 13:55:06
Message: <4934330a$1@news.povray.org>
I take advantage of X windows, ya see. :-)
I find it really hard to believe GCC will compile a program, then read the
output file to see if the result is the same, and if not, only then will
unlink the old code and write the new code.
I'll give it a try next time I'm in Linux, tho.  I suspect it's more some
options on the compiler or file system we have set differently or something.
