POV-Ray : Newsgroups : povray.off-topic : You lose some... Server Time
16 May 2026 12:26:53 EDT (-0400)
  You lose some... (Message 22 to 31 of 31)
Subject: Re: You lose some...
Date: 5 Oct 2008 09:51:11
Message: <op.uij0rkwh7bxctx@e6600>
On Sun, 05 Oct 2008 15:36:45 +0200, andrel <a_l### [at] hotmailcom>
wrote:
> Didn't we code that more like out.append("0" + c[i]) just to confuse the
> readers?
Nitpick: It has to be '0', not "0".
You could also do it like this:
	out += c[i]["01"];
If you were in a particularly foul mood, you could write it like this:
	out += c??(i??)??("01"??);
FE
Date: 5 Oct 2008 09:51:41
Message: <48E8C6BB.4040202@hotmail.com>
On 05-Oct-08 15:36, andrel wrote:
> On 05-Oct-08 6:42, Chris Cason wrote:
>> Slime wrote:
>>>>     for (unsigned int i=0; i<c.size(); i++)
>>>>       if (c[i]) out.append("1"); else out.append("0");
>>> This isn't the cause of your crash, but I recommend not squishing
>>> your code together like that. Keep each statement on a separate line
>>> and use brackets around anything that's not a single simple statement:
>>>     for ( unsigned int i = 0; i < c.size(); i++ )
>>>         if ( c[i] )
>>>             out.append( "1" );
>>>         else
>>>             out.append( "0" );
>> If he wants brevity he could also code it like this:
>>   for (int i = 0; i < c.size(); i++)
>>     out.append(c[i] ? "1" : "0");
>> which is just as valid and avoids running the if/else together.
> readers?
Been a long time since I actually did write sufficient amount of C. :( I
think I meant the character constant '0' and not the string "0".
Date: 5 Oct 2008 09:54:55
Message: <48E8C77C.9060509@hotmail.com>
>> the readers?
Yeah I remembered too late.
>     out += c[i]["01"];
Is that C or C++?
what += does??(that??)??("Mean"??)
Date: 5 Oct 2008 10:03:35
Message: <op.uij1b8k97bxctx@e6600>
On Sun, 05 Oct 2008 15:56:12 +0200, andrel <a_l### [at] hotmailcom>
>>     out += c[i]["01"];
> Is that C or C++?
Either.
??( is an alternative token for [. Similarly for ??) and ].
FE
Date: 5 Oct 2008 10:38:24
Message: <48E8D1AE.7020501@hotmail.com>
I don't remember that one. I seem to have dislocated my k&r and bjarne
books and I seem not to be able to find that on the web either. Are you
sure that that isn't just a compiler/hardware specific hack?
Date: 5 Oct 2008 11:12:44
Message: <48e8d96c@news.povray.org>
http://en.wikipedia.org/wiki/C_trigraph
Date: 5 Oct 2008 11:18:35
Message: <op.uij4s9vt7bxctx@e6600>
On Sun, 05 Oct 2008 16:39:42 +0200, andrel <a_l### [at] hotmailcom>
Yes, I am sure. They are called trigraphs and are listed in section 2.3 of
the C++ standard.
Strictly speaking, they are not actually alternative tokens. They are
substituted before any other processing of the source.
There is a set of actual alternative tokens though. They are sometimes
called digraphs. You could thus write:
	out += c<:i:><:"01":>;
FE
Date: 5 Oct 2008 11:46:46
Message: <48E8E1B4.3050004@hotmail.com>
Thanks warp and frederick. This wiki page still keeps me wondering when
these trigraphs were introduced. Must be before the 1994 digraphs (which
is indeed long after my sort of formal training in C).
I could not find them with google. searching for ??) did not give any
result. Any of the google wizards know what I should have asked? (Apart
from trigraph, because that was the term I didn't know, otherwise I
would not be looking)
Date: 5 Oct 2008 12:22:55
Message: <op.uij7sgtx7bxctx@e6600>
On Sun, 05 Oct 2008 17:48:04 +0200, andrel <a_l### [at] hotmailcom>
wrote:
> This wiki page still keeps me wondering when these trigraphs were
> introduced. Must be before the 1994 digraphs (which is indeed long after
Late eighties I think.
FE
Date: 5 Oct 2008 17:31:07
Message: <48e9321b$1@news.povray.org>
Orchid XP v8 nous illumina en ce 2008-10-04 14:37 -->
> Hmm, and I though everything was going so well. :-/
> OK, any C++ experts have any idea why this code snippet causes my
> program to crash at runtime?
>   typedef std::vector<bool> Codeword;
>   std::string codeword(const Codeword &c)
>     std::string out;
>     return out;
> "Unhandled exception at 0x00414166 in Huffman01.exe: 0xC0000005: Access
> violation reading location 0x00000004."
> The code looks fine to me - but what I do know?
Maybe you have an uninitialised pointer.
Do you get any output? If you don't, it mean that the variable "c" don't get
initialised properly.
Look at the caller. Maybe the variable that is supposed to be passed is in fact
a null, or an uninitialised pointer, or maybe a constant.
"The way England treats her prisoners, she doesn't deserve to have any."
        --Oscar Wilde
